Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Compressor keep working but the pressure do not go up
  • 128 Answers
Sounds like regulator
Posted on Aug 29, 2010
Miller Plasma not cutting properly keeps ruining tips
It may be an air pressure problem. Plasma cutters require a constant flow of air at a certain pressure to work properly. If the compressor can't keep up and the pressure drops it can create problems. Have someone watch the pressure gauge while you're cutting to see if the pressure remains steady. You may need to adjust the compressor pressure switch or you may need a larger compressor.
Hope this helps.
Bob
Mar 27, 2015 | AO Smith Miller / LSI / Home / Nordyne...
My craftsman 3gal. compressor starts and run but no pressure is building up.it just keeps running and the gauge remains at 0 psi.
Is the petcock down below open or closed? If open, then screw it closed. Also, is the compressor portion connected to the motor working as it should? As the motor reciprocates, it should operate the compressor piston that pumps air pressure into the tank. Maybe something is broken there.
Nov 04, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Compressor keeps blowing release valve
Compressor pressure switch not working properly. Remove cover over pressure switch. Drain air out of tank. pressure switch contacts should open. If contacts do not open they may be stuck or welded close. Remove power and gently pry contacts apart. If they where welded together this will correct. If this doesn't correct replace pressure switch
Jan 16, 2011 | Porter Cable Cable 135 PSI, 15 Gal. Oil -...
The air conditioning compressor keeps kicking in and out when on max cool then warms up then kicks back on it's cold when it's working but I can't seem to keep it engaged I've checked the connection to the...
The a/c system is probably low on freon. The pressure sensor sees a low pressure reading on the low side and it turns the a/c off so the compressor does not burn up.
Sep 21, 2010 | 2006 Hyundai Sonata
I have a champion air compressor that has power but will not turn on? I see 2 wires on the top that look to be disconeccted the are from the pressure switch to the compressor itself
loose wires would probably keep it from working
if you could view a working one at a store you could see how to reconnect the pressure switch.
by being disconnected the compressor probably thinks the pressure switch is open so as to show a fully pressurized tank
Jan 02, 2010 | Champion International Air Tools &...
MY COMPRESSOR JUST KEEPS RUNNING AND WONT REACH MAXIMUM PRESSURE AND SHUT OFF. I CAN SHOOT NAILS BUT IT WONT SHUT OFF DOWN.
The compressor itself sound like it is bad. You might see what it cost to repair it. It might be cheaper to get another one...keep in mind if you do a lot of work with it that a 2 stage compressor will cool better and you won't have this type of problem again.
Oct 19, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Hitachi EC 12 Air Compressor does not keep pressure
to repair this problem (a) the pressure switch is not working,(b) check valve or non return valve sticking(stripe down repair and refit)
Sep 28, 2009 | Hitachi EC12 Portable Electric 2hp Air...
2004 Chevolet Silverado blows hot air and snowflake button blinks when pressed
Blinking or chattering of the compressor clutch usually indicates low "freon" charge.
Jul 09, 2009 | 2004 Chevrolet Silverado 2500HD
The compressor relief valve keeps popping, compressor runs
What pressure is it popping off at? You might have to adjust the pressure switch to a lower setting.
Apr 01, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
26 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
