Question about Rowenta Irons
Calcium buildup - when ironing white specks keeps getting on clothes.
  • 3 Answers
<span id="LblAnswers">.To solve this problem, switch to bottled spring water. Once the water is changed it will take several uses before your iron adjusts to the new mixture and the issue is corrected. </span><br>to speed that up Place the iron in clean or high stream mode if its a feature on your iron if not I would wipe it down with the solution usually 3 parts water 1 part vinegar.&nbsp; Also Rowenta sells a cleaner specifically for their irons&nbsp; and you can purchase it online here is the link its from macys but rowenta brand and is now on sale <br><br><a rel='nofollow' href="http://www.macys.com/catalog/product/index.ognc?ID=64754&amp;cm_mmc=Google_Feed-_-6-_-77-_-%7Bkeyword%7D&amp;kw=%7Bkeyword%7D">http://www.macys.com/catalog/product/index.ognc?ID=64754&amp;cm_mmc=Google_Feed-_-6-_-77-_-{keyword}&amp;kw={keyword}</a><br>
Posted on Aug 29, 2010
Dg5030 steam is not working
Sounds like you may have a buildup of calcium in the water line. Try putting in some LimeAway and letting it sit overnight to clear it out. The drain the LimeAway out refilll and steam a few times on scrap cloth to get all of the cleaner out, see id that solves the problem.
Aug 13, 2014 | Rowenta DG5030 Iron
Tip
Cleaning a Steam Iron White Scale and Brown Water
If you are having problems with your steam iron spitting out brown water or white scale all over your clothing, then you need to read this tip.
Both of these problems are caused by poor quality water being used in your steam iron.
The problems are different in that they are caused by two different types of poor water quality. The brown coloring of the water is usually caused by organic matter or iron mineral in your tap water.
If you are getting white scale on your clothing from your iron then it is usually because of calcium or other minerals in your tap water.
Either of these problems can also contribute to spitting or leaking of the iron when in use.
To clean the inside of the iron you must first empty all the water from the iron. Then fill the iron half full with bottled spring water and then fill to full with vinegar. Run the iron at its hottest setting for 15 minutes and then drain the solution. Fill again with just the bottled spring water. Reheat and then empty. After removing all of the water, turn on the iron and let it sit in the horizontal position for a few seconds to evaporate the last of the water. This will not hurt your iron, but will remove all the moisture before storage.
To keep your iron working well, use bottled spring water, and remember to remove all water before storing your iron. Always allow the iron to cool and store it on its heel.
Using the right water will prolong the life of your iron. Commercial de-scaling cleaners are hard on the inside of the iron and can cause leaks. Do not use distilled water, as it is too pure and will not produce much if any steam.
on Jul 14, 2010 | Irons
Brown water and seems like sand or fine grit comes from iron ,when first put on with the steam
sounds like it is time to de-scale the iron to loosen all the deposits inside the unit.
add some white viegar to the water ( which should be distilled water ) and heat up and let the iron steam out the solution. now add just water to the unit shake it and rinse out with water and drain. now do one more vinegar / water de-scaling and rinse out again. now fill with just distilled water and let it steam out and now your iron should be clean as new.
c...
Feb 12, 2011 | Russell Hobbs 13153 Iron
Cloths steamer not working keeps saying its out of water but its not.
Suspect that your iron's steam holes are being blocked by calcified water (hard deposits)and need to be cleaned. Take one cup of white vinegar to one cup of water and pour it in the Iron. let it sit heating for about 30 minutes. Repeat if necessary. The acidic vinegar will disolve the calcium and unblock the vents. The final one after the vents are clear, 1 tbs of lemon juice to one cup of water gets rid of the vinegty smell.
Jan 10, 2011 | Irons
Our iron keeps shutting off and on. It then spurts out brown liquid from the iron. It is on my wall and it stains our clothes
the brown liquid is rust from leaving the water in the iron. Always dump the water out when you are done ironing. You need to run a descaler through it. you can purchase descaler online. The shutting off and on could be a loose wire.
Aug 11, 2010 | Euro-Pro Shark GI490 Iron
Steam iron residue on suit pants
I would send them to the drycleaners and point out the contamination. If they were mine, I would treat them with a little white vinegar; the white deposits are caused by a buildup of calcium in your iron. Don't put the vinegar directly on the trousers but use a clean cloth with some vinegar on it and gently massage the deposits.
It may stink, but it is wise to now and then run it warm (only) with some white vinegar which will dissolve the deposits. Put it on a heat-proof surface (such as a stove grate) so it can stand flat otherwise not all of the deposits will get soaked with vinegar. After letting it soak warm, run several tanksful of plain water to remove the vinegar and shake it over the sink in case there is chunks (very well could be) that have been loosened.
Mar 27, 2009 | Rowenta DG-980 Iron
Rust coming from iron
See if you can get a hold of some CLR (Calcium, Lime, and Rust). It's a cleaner most drug stores and hardware stores carried in the states. Pour that into the system and then flush it out. Make sure the CLR isn't in the iron before you use it again.
Use filter water in your iron in case there is rust or sediment in the tap.
Aug 11, 2008 | Rowenta Powerglide DM273 Iron
How to clean
heres a link to help you out , also I recommend to get "CLR" cleaning product , hope it helps AJ
Jun 12, 2008 | Rowenta DX6700 Iron
Brown gunge and white deposits keep coming out of the steam holes on the sole plate. We have tried de-scaling but it has had no effect. This iron has had very little use since we bought it about 18 months...
Try filling full-strength white vinegar instead of water. Then allow to steam out on scrap cloth. The white deposits are likely to be calcium. The brown gunge may be rust. When the deposits are minimized, use only distilled or bottled water from then on.
Mar 15, 2008 | Rowenta Perfect Iron
CALCIUM BUILDUP COMING OUT OF THE STEAM HOLES...
Hi, the other two responders were correct, use clear or filtered drinking water only. Also, use your iron until it runs dry and use burst of steam or self cleaning function to clear out the last bits of water, being sure it is empty before putting it away. Several cycles of this using and purging process will clean the iron without chemicals. Standing water that evaporates is just like a tea kettle with water left in it, all the white mineral deposits settle to the bottom, and the water dissolves the mineral salts, and when dissimilar metals are wet (think of a an old flashlight battery and the corrosion that occurs if left in storage.
Dec 04, 2007 | Rowenta DX6700 Iron
Irons Logo
137 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
