Question about Gateway GT5408 PC Desktop
Startup 3 beeps then monitor tries to turn on but nothing what is it/?
    Guru:
  • 266 Answers
RAM sticks are having problem.Just open the CPU cover and clean the RAM slots and refix RAMs. You can put one by one if you have multiple RAMs. check with different RAM slots.If you still get this sound you need to get new RAMs
RAM will look like as in below picture
Posted on Aug 29, 2010
4 Suggested Answers
SOURCE: ASRock K7S41 / K7S41GX, sound 3 Beeps 3 times, then power off automatically
I had 3 beeps, pause, 3beeps, pause and so on.
Defective SMD transistor near the ATX power connector. Original is a 2SB1202 (marking B1202).
I bought a 2SB1203 which is stronger and soldered it in. The K7S41GX board runs as fresh as from the dealer.
Posted on Nov 20, 2008
yboyandrei
  • 828 Answers
SOURCE: Sony pcv-rz22g startup long beeps nothing on screen
Long beeps appears that VGA card are not connected properly. check on it. if not tells us how many beeps you hear...
Posted on Aug 05, 2009
  • 324 Answers
SOURCE: computer makes low beeping noise when i try to
please remove your RAM and fix it again correctly
Posted on Sep 15, 2009
On startup, 3 beeps
the beep codes are different for each BIOS mfg.
you can easily get a list of codes and their meanings from the internet.
Sep 04, 2012 | ZT Group Cisnet PC Desktop
Dell Dimension 9200 beeps on startup, with nothing...
A beep code of 3-3-4= Video Memory(RAM) Test Failure that would explain why you get nothing on your screen the first thing you would need to do is disconnect your monitor and try it on another computer. if it works fine then the problem is your video card. If that the case and the video card is intergrated with the motherboard, you will need to repalce the motherboard --- Sorry-- Please vote me a 10 when this works
May 20, 2010 | Dell Dimension 9200 PC Desktop
VA1703wb... Monitor beeps when I turn on the pc then goes black
Please read below and look at the pictures of failed VIEWSONIC nd othe monitor before try to DIY repair.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 06, 2010 | ViewSonic VA1703wb Monitor
Screen went blank, have yellow indicator on monitor, try to reboot, getting three beeps, nothing more.
One beep during startup is "good", but THREE is not good.
Three beeps means a hardware fault -- probably that the video-adapter on your computer has failed.
Connect the monitor to another desktop/laptop, to confirm that it still works.
Turn the computer off, and disconnect the power-cord.
Remove all the RAM, and then re-insert just one stick.
Reconnect the power, and try to boot.
If you still get THREE beeps, turn it off.
Disconnect the power-cord, and reinsert the remaining RAM sticks.
If you still have the problem, then it's time to replace the video-card on your computer. Take the computer to a computer-store, so that they can sell you a video-card that will be compatible with your motherboard.
Hopefully, if you buy the video-card from them, they will install it for a modest fee -- ask them.
Dec 31, 2009 | Intel D945GTP Motherboard
My bios speaker will beep on startup but nothing more. What avenue should I approach to get past this part of startup?
First you need to know which BIOS you have and how many beeps it is producing... these beeps are the POST - Power On Self Test. They tell us if there are problems such as missing keyboard, video card not working, memory faults etc...
Then you need to go to the appropriate BIOS site and see what the number of beeps mean.
If it is a single beep - it means all is well...
As you are not getting anything more you should check to see if the Hard Drive (HD) light flashes - if so - the HD is probably operating ok and loading your system but there is either a problem with your monitor or video card... borrow another monitor and see if that helps...
But it all depends on the number of beeps you get and what kind - long and short beeps (like morse code).
If this helped you at all please vote!
Oct 06, 2009 | Asrock M266A Motherboard
My monitor goes to sleep mode at startup & can't access safe mode
Turn the computer off, open the case and remove the RAM. Does the computer beep when you turn it on with no RAM? If not, your motherboard is dead.
If your computer beeps, turn it off again and try putting one stick of RAM in. If the computer doesn't turn on normally, try the other stick of RAM.
Also, try taking out the video card and putting it back in.
Good luck,
Jason
Jan 25, 2009 | E-Machines eMachines Desktop PC
Motherboard startup problem!!
If your video is running off the card then remove the cable and plug it into onboard vga. Then remove the card from the slot. That should solve it then you will need to reinstall drivers for video card. If your monitor is running from onboard video then you will need to remove the card then try turning it on.
Dec 25, 2008 | Compaq Evo D310M 845G P4 Motherboard
Computer beeps 3 time when turned on.
normally 3 beeps (might be one long and two short) means it's the video card, try another slot if possible.
If no other slot is available, then clean the contacts off the graphics card with a #2 pencil eraser, taking care not to touch the contacts afterward, and then re-insert the card.
if still nothing, try another video card.
Jun 22, 2008 | Computers & Internet
Gateway GT5408 PC Desktop Logo
149 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
