Question about Kenmore Dryers
We have a Kenmore gas dryer model #76832500. The ignitor glows and the gas will light for a short period of time and then go out. Once the dryer cools down it will light again. Our manual shows there are 2 coils one is a 2 terminal and the other is a 3 terminal. Which one do we need to replace?
  • Douglas Jensen Aug 29, 2010
    Before you start replacing parts, have you checked the rear outlet of your dryer and your venting for blockage? Also check the outside vent flap. Douglas
  • 4 Answers
The 3 pin coil is your booster and holding coil and it ignites the 2 pin secondary coil. Is the flame blue or yellow? I would change both. Coils are a lot cheaper than the whole gas valve assembly.
Make sure to check the dryer's airflow. If the dryer is ducted, pull the machine away from the duct and try starting it again. Does the dryer have some sort of electronic control which is sensing an error and terminating the heating circuit? If there is it would be a box type thing located near the gas valve and it would have lights flashing on it. If that's the case, it's a new problem in itself as you would need an error code listing to begin looking.
Assuming air flow is good and gas supply pressure hasn't dropped (also check that gas inlet hose is kink free) and it is the coils that are failing, change both and fix your problem
Posted on Aug 29, 2010
Kenmore gas dryer #41793142300 electronic start doesnt heat up
if you first have heat and then like 10 to 20 minutes later no heat you could have bad gas coils,on most gas dryers there's a plastic cap you can pop off on the front panel so you can look in and see the ignitor,if at first the ignitor glows orange and the flame lights then after a few minutes the ignitor glows orange and the flame doesn't light you have bad gas coils,they are located on the top of the gas valve,easy to change.part number 5303931775 go here and look at part 71
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-41793142300/0582/0151200/R0310102/00005?blt=06&prst=0&shdMod=41793142300
Mar 25, 2013 | Dryers
The Kenmore dry glow plug lights but the gas only comes on initially. After a few min the gas goes out and the plug glows periodically but no flame
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 27, 2011 | Kenmore Dryers
Hi, I have a Kenmore gas dryer model 417. I can't
Sounds like the coils on the gas valve are bad.
May 26, 2011 | Kenmore Dryers
Dryer is blowing cold air
If electric then the thermostat or the heating element has failed.
If gas: First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Feb 22, 2010 | Kenmore Dryers
GNSR465EB3WW
Jan 18, 2010 | Kenmore Dryers
Kenmore dryer heats up at first and I can see the flame, then after about 1 minute the flame is gone.
On a gas dryer, if the ignitor is working and the gas lights and then goes out after a short period of time and the ignitor continues to operate, then check the gas valve coils. These electrical coils are right above the gas valves. When these solenoids are energized, they open the gas valves and permit gas to flow to the burner. They can be tested with a multimeter for continuity. A lack of continuity indicates a bad solenoid. If found faulty it is recommended that both (all) be replaced at the same time. Hope this helped and best wishes.
Aug 18, 2009 | Kenmore Dryers
Dryer Model DE306 has stopped heating
Aug 13, 2009 | Dryers
My Maytag model # mdg6000bww doesn't heat up?
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Jul 18, 2009 | Maytag MDG2600BWW Gas Dryer
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
Jul 11, 2009 | Dryers
Kenmore elite gas dryer
Does the ignition glow when you start the dryer? if so you have power to gas valve and ignition system. if not you may have an open thermostat or thermalfuse.
If the ignitor just sits there and glows all day, you have other problems, It could be a gas valve, or ignitor sensor.
Jun 04, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
51 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
