Question about Motorola Mobility MOTORIZR Z3 Cellular Phone
My Motorizr red (end) button hasn't worked for about 8 months. Four days ago, my phone shut off (not sure why), and I can't turn it back on. When I plugged it in, the screen lit up charging and then charged but won't turn on. I went to T-Mobile, and they said there was no other way to turn it on, and I'd have to get another phone. I find that hard to believe, and if it's true, I'll never get another Motorola. Can you help? Linda Miscavish
  • gte1linda Aug 29, 2010
    Please review original post.
  • 2,973 Answers
Linda,
If the charging showed up on a dead screen then the phone is not dead. This is a feature with all phones. There are two reasons for the phone to not power on. Dead battery (not so in your case) and a bad power on switch. All phones have a power on switch. And everything can be replaced. After all it was made by humans. But when you want to sell a new phone nothing can be repaired. And thats what happened to you. 'Crooked dealer' is all I can say. Too late now. But you must go to a different dealer/service center and ask them to replace the switch. And you will have two phones. What do you do with this one then?
Posted on Aug 29, 2010
  • 17,130 Answers
Possible fault in your main board. Since the harware failure will cost mpre than a new phone , the companies take the policy to advice thus. We have come to an age where the cost of this device has ONLY reduced with Better technology due the high demand of Man's personal assistance.
I would advice you to checck the numerous models that are flooding the market which will suit your requirement.
In the long run you will have to forgo old models as even batteries will not be availabel for the said model and you will end up buying old batteries that remain on shelf which might give less life.
Also if you are lucky to find another set discarded for display damage or battery, it might work out cheaper.( plenty around)
BUT do not spend more but use your logic.
I hope my advice helps.
My 62hm95 will not come on now had the bulb replace four months ago worked great then nothig the red led stays on and the green one blinks what do i do now???
Some of these sets have a "quick on" feature which runs the lamp all the time and when set is shut off it dims down 60% but does not go off--this can drastically shorten life of lamp.
If you saw the picture at turn on (7 or 8 seconds) you have this feature and it is engaged----that new lamp may be history---I would also look from side/rear to see if lamp fires up even briefly---remove lamp also to make sure not shattered inside.
Oct 24, 2012 | Toshiba 62HM95 62" DLP HDTV
Dont know how to turn on
To turn on the phone, ensure the battery is well charged. Lets say, for about 2 hours, then you unplug the charger, then you press and hold the red button in the right or the end call button. Hold it for about 8 seconds, it will turn on. It might even turn on before the 8 seconds is complete. Once the light comes on, release the red button.
Thank you for using fixya.
Caseytech
Sep 13, 2011 | Motorola Mobility MOTORIZR Z3 Cellular...
How to turn on
To turn on the phone. First ensure the phone is properly charged, for about 2 hours. Then you press and hold the end call button or the red button that is on the right hand side for about 8 seconds, it will turn on, it might even turn on before the 8 seconds is complete.
The moment you see the phone light come on, release the red button.
Caseytech
I have the same problem!!!! I just dropped mine 2 hours ago!!
http://www.fixya.com/support/r3771170-phone_water_damage
Jun 04, 2009 | LG Vu CU920 Cellular Phone
I bought a Samsung Omnia about two months ago and have hardly used it but for about two weeks now it just keeps shutting off on it's own even when the battery is fully charged. Sometimes it goes off as...
you need to hard reset it. it will be like factory setting. follow below procedure to hard reset. you will loose personal data on phone memory like contacts,sms,settings, etc.
  1. Press reset pin button ONCE (do not hold)
  2. Once you see the Samsung Omnia appears on the screen, immediately press the SEND and END key simultaneously
  3. Then the screen appears asking you whether you are sure to format
  4. Press SEND to format or END to cancel
Jan 01, 2009 | Cell Phones
How to replace small metal circular buttun cover (menu button)
Just call t-mobile and tell them the problem. If u still have a warenty they should send u another one. I had the same problem a few months ago.
Nov 03, 2008 | Motorola Mobility MOTORIZR Z3 Cellular...
3G and battery life
hold the red end call button down until it turns off
Aug 20, 2008 | Motorola Mobility MOTORIZR Cellular Phone
Not turning on
Power supply board pull,then remove original solder on 5 volt
regulator pins then resolder + replace 4 amp fuse........T.
Oct 25, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
My screen will turn on, but will not proceed.
hi
it seems you have a prob in the keypad flex. have it replaced and your prob is solved.
Oct 12, 2007 | Motorola Mobility RAZR V3
Motorola Mobility MOTORIZR Z3 Cellular Phone Logo
19 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
