My air is 82 inside but the unit outside is blowing a cool air instead of hot/warm like our neighbors.
  • 674 Answers
If the unit is not blowing warm/hot air then either your compressor isn't working or your refrigerant charge is low. Make ure that the compressor is running. If you can't hear it over the fan you can disconnect a fan lead and then see if you hear it. If it's not running then verify that it has power to it then check the capacitor. If you don't have a meter to check it with then you can take it to a heating and air supply to get it checked. Replace it if necessary. If the capacitor is good then check the compressor windings for continuity using and ohmmeter. If the compressor is running then get the refrigerant charge checked.
Posted on Aug 29, 2010
Ac unit isn't blowing
It sounds like your freezing up at the coil, which in turn, blocks airflow across coil and only a small amount of air comes out of the vents. This also explains the cold air coming from fan on the outside unit, since the system cannot absorb the heat from the inside of the house through the coil. Your air outside is usually blowing out warm to hot air because thats the heat it rejects out of your system. I would turn the thermostat to "OFF" and turn just the fan setting to "ON" instead of Auto, this thaws the system out faster. Give it time to fully thaw, make sure filters are clean, and check airflow. If airflow is back to normal, your problem is more than likely the charge of refrigerant. If you have to call a technician out, make sure the unit is not frozen at all before they get there, they would not be able to do anything with the system froze. Hope this helps and good luck!
Jun 18, 2012 | Heating & Cooling
1998 gmc surburban. front blows 82 degrees, rear blows 48 degrees. ambient is 91 degrees. this is with max-recirc-full tilt.the valve for the heater core does not change position no matter where i put the...
Hi John,
Your right with your diagnostics, you have a blend door problem. If your switching to cool air and it is still hot then you also have a heat exchange unit fault, this is the component that changes the water flow from hot to cool by shutting off. If it is not operating correctly this will give you constant hot air no matter where you temperature switch is positioned.
As for the warm air while the engine is cold, sounds like the blend door is still open to atmosphere tempreture and if it is hot outside will pull that hot air into the inside of the vehicle.
Have the heat exchange valve checked, and the only way the check blend door operation is to remove the wiring from the blend doors and have the circuit tested. If the circuit is ok then the blend doors will need to be replaced.
Hope this helps
Jul 24, 2011 | 1998 GMC Suburban
Cold air blows outside and hot air inside
Make sure it is in cooling mode. Sounds like you may have a problem with the reversing valve but you would want to check the pressures in the system first and make sure the charge isn't low.
May 02, 2010 | Heating & Cooling
Our AC (Heat pump)is blowing hot air in the afternoons as the temperature outside rises. We have had the freon checked and it is okay. The AC will blow hot air for about 30 minutes then blow cool air. Our...
Your unit may be going into a defrost cycle. If so sounds like a bad defrost board. It sends a signal to electric heaters inside to come on. Change board and sensor
Jul 28, 2009 | Whirlwind FH-778 Air Conditioner
Outside unit will not start...while inside unit blows warm air
probably a.c. was left with out a gas,and compressor will not start and there is no cooling.
Jul 04, 2009 | Heating & Cooling
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
Intertherm not cooling correctly
Sound like air flow problem to me, the inside and the outside. check the inside filter to see if it's clean and clean the outside condenser coils by washing it.
Aug 23, 2008 | Intertherm P3RA-048K Air Conditioner
Carrier Air Conditioner, cool air then runs luke warm air
Have you checked the freon level in this unit? If you are low or there is a leak it could be the problem. Hope this helps.
Jul 19, 2008 | Carrier 36KCARMS Air Conditioner
Dehumidify mode also cools
Some units do cool/dehumidify only im afraid why cant you let the unit dump its hot air into the room then it wont heat or cool the room?
Sep 03, 2006 | Danby DPAC9031 Silhouette 9,000 BTU...
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
