Question about Philips SoundBar DVD Home Theater with Ambisound
I have a HTS 8100/59 and the sound has dropped to the extent that it can just be heard when the volume is on max
2 Suggested Answers
SOURCE: Philips HTS 8100 purchased 06/23/08, sound has
did you find an answer? i have the same problem.
Posted on Feb 22, 2010
Radio developed fault. Sudden max audio output which cannot be reduced by volume control.Just before fault, a click was heard in the back of the car.
If you have steering wheel mounted controls then play with the volume switch and see if that drops the volume, if not unplug the steering wheel control harness for the radio an if that makes no difference then the radio is defective.
Feb 08, 2016 | 2003 BMW 5 Series
I just bought a Coby home theater system 5.1 surround sound dvd/cd/ player model#765. I've got it all hooked up but I have one problem, when I want to listen to my tv stations through the home theater...
Hi - Your Home Theater System and your TV should have separate volume controls. You should be able to control each individually. Start by checking the volume level on your TV with your HTS shut-off. Turn the volume on your TV all the way down to 0.
Next, turn your HTS on and check the volume level there. Is it still loud? If so, try turning the volume down on your HTS. That should do the trick. If its not loud then you know you can control the volume on either the HTS or the TV. If this answer does not help, then please write us back with a little more detail. Thanks.
Feb 28, 2011 | Audio Players & Recorders
I have a sony home theater system. my cable box volume is all the way up but still with watching TV the volume is so low, eventhough the volume on the sony system is set to "MAX". also i get a...
First, TURN THE VOLUME DOWN. We don't test with max volume any more than we start our cars with the accelerator floored.
How is the audio from your TV getting to the HTS? Name names and be specific.
Your TV audio output may be dependent on its volume control. Many TV's have a FIXED setting in their setup so you can lower or turn their speakers off while letting REAL electronics and speakers handle the sound duty.
OR, you could (and should) bypass the TV entirely as an audio source and go to the cable box's audio output.
Feb 05, 2011 | Audio Players & Recorders
Is my tv audio doomed or will the home theatre system work anyways.
some devices these days have a built in volume control, try using your remote for which ever dvd player or satalite bix you use, on push the volume up button on it while you have the volume on the tv maxed out so that you will be able to tell a defference if it works or not.
Jun 02, 2009 | Philips HTS 6600/12 Home Theatre...
Do they sell extentions for the speaker wires for the HTS-3565d?
you best bet for that much wire needed would be to go out to eather wal-mart or radio shack and get a spool of speaker wire normaly the mid range wire is a good bet for home use
Mar 27, 2009 | Philips HTS-3565 Theater System
Volume will not maintain level
To fix the problem, I reset the iPod.
Feb 13, 2009 | Apple iPod MA446LL/A MP3 Player
I have a Vizio 42' and a cable box and there's a constant humming
I think I had the same problem. This is how I fixed it.
I have my vizio 42 hooked up to a Harmon Kardon surround sound, and the digital cable box. Essentially, I can adjust the volume 3 ways - through the tv, cable box or av receiver. The humming sound happens when you have the volume maxed out on the av receiver and not the cable box.
For example, the sound level on my Harmon Kardon goes from -10 (lowest) to 10 (loudest), with 0 being the middle ground. The buzzing was happening when the Harmon Kardon was set to 10, and I was using the cable box volume to adjust the sound. To fix it, I turned down the volume on my receiver to 0, which may be about 50% max volume of the receiver. Then, I switched devices and used the volume on my cable box. This got rid of the static I was getting. Hope that helps.
Jan 09, 2009 | Vizio VX32L Television
HTS 6500/37 sub woofer
the reciever should have a "subwoofer level" setting, or a "bass level control" If you cannot find this then try to place the "sub-woofer" away from walls and elevate it from the floor. This will reduce it's loudness/ intensity at annoying frequencies...
Good Luck
Jul 25, 2008 | Philips HTS-6500/37 System
Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
Dec 17, 2007 | Audio Players & Recorders
Philips SoundBar DVD Home Theater with Ambisound Logo
50 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
