Question about Dishwashers
Standing water in the bottom after every cycle. No steam is exhausted upon the dry cycle. hasnt been used for years. not quite sure what the problem is.
  • 5,081 Answers
Since the drain pump will pump the water out using the "cancel/drain" button, your problem is likely to be in the drain hose system or the garbage disposal downstream from the drain pump. Check for kinks in clogs in the drain hose. Grease can build up in the portion of the drain hose just before it attaches to the garbage disposal.
Please give the brand and model number for more exact details.
Posted on Aug 29, 2010
My Whirlpool Duet DRYER--the clothes are wetter than when I put them in & there is now water sitting in the bottom. It does have a steam setting, but I'm not using that one. It's 4 years old.
Check your exhaust vent! If you have an obstruction, the steamy air will have no where to go, then your air-conditioning temps inside can cause the water to condense in the vent tube... Even if the vent is just open to the hot summer air and the clothes sit in the machine the difference in temps between inside and outside can cause these symptoms...
Jul 25, 2016 | Whirlpool Duet High Efficiency Gas Dryer...
Fan is noisy intermittently well after wash is finished
It depends on what model you have. The fan is usually operating when the dry cycle is on. The dry cycle can be quite long compared to the actual wash (which ends when the rinse water is drained out). The dry cycle uses the steam in the dishwasher to circulate around the dishes. The fan keeps running until the full cycle is complete. If you are hearing heavy noises when the fan is running, then the bearing of the fan maybe damaged and you need to replace the fan.
Jan 02, 2014 | Fisher and Paykel Dishwashers
Water collects in door during drying cycle
The drain hose for the dryer fan is blocked. If you remove the outer door (six Screws three bottom screws down either side) you will see a hose that runs from the bottom of the fan to the top of the detergent dispenser, removed hose and clean this will resolve the problem
Jun 27, 2010 | Miele 24 in. G693 Free-Standing Dishwasher
No steam on Capresso Impressa S8
Most likely problem is over temp cut out switch. Small diode attached to the boiler to prevent damage during boil dry, or fault in the heating element itself. Difficult machines to repair and best handled by a service technician.
Sep 13, 2009 | Jura Capresso Impressa S8 Coffee Maker,...
FDW60 has standing water in the bottom and will not fill up
You most likely have a stubborn clog in your kitchen drain. Try filling the sinks with warm soapy water and then letting the water drain while also turning on your garbage disposal. Sometimes the extra water pressure will help push the clog through.
Jun 16, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher maytag 945 awq
Door gasket or sealOver time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Nov 08, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
Tub still wet/ not drying
YOU NEED RINSE AID ! ! Make sure your selection option is HEATED DRY.Please rate this !
Jun 06, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Leaking Breville Esp6
sorry this is out of my leage someone elso will have to help.
May 16, 2008 | Breville ESP8XL Espresso Machine
Drying cycle
Is the drying fan rotating(you should hear this)? Or the watertap closed. It uses cold water to make the steam into condense. If tap is closed, the machine has no water to cool the steam with. Check lint filter.
Jan 22, 2008 | Candy CNW156 Front Load Washer / Dryer
CALCIUM BUILDUP COMING OUT OF THE STEAM HOLES...
Hi, the other two responders were correct, use clear or filtered drinking water only. Also, use your iron until it runs dry and use burst of steam or self cleaning function to clear out the last bits of water, being sure it is empty before putting it away. Several cycles of this using and purging process will clean the iron without chemicals. Standing water that evaporates is just like a tea kettle with water left in it, all the white mineral deposits settle to the bottom, and the water dissolves the mineral salts, and when dissimilar metals are wet (think of a an old flashlight battery and the corrosion that occurs if left in storage.
Dec 04, 2007 | Rowenta DX6700 Iron
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
