Question about Cargo Pilot for Windows
It says there is an error at the beginning with the collecting airports
Where can i buy this watch
HI there
In all better and expensive watchmakers and of course at most international airports.
enjoy your watch
Kolbrun
Feb 25, 2012 | Giorgio Armani Armani Digital Collection...
Trying to update firmware on y airport extreme but i forgot my password
You need to perform a soft reset of your router. There directions to do this from the Apple web site are:
  1. Connect the AirPort Base Station or Time Capsule to power.
  2. Press and hold the reset button with a pen or pencil for 1 full second, then release it. The light (LED) will begin flashing amber, indicating that the AirPort Base Station or Time Capsule is in soft reset mode.
  3. From the AirPort menu bar item, choose the network created by the AirPort Base Station or Time Capsule (the network name does not change).
  4. Open AirPort Utility in Applications > Utilities on a Mac using Mac OS X, and in Start > All Programs > AirPort on a computer using Windows.
  5. Select the AirPort Base Station or Time Capsule and click Continue.
  6. A window indicating that the device has been reset will appear.
  7. Select "Restore the previous settings" and select OK.
  8. Move through subsequent windows to make changes to your passwords or other settings as desired, clicking Continue after each one.
  9. When you have moved through all of the selection windows you will be able to select Update. Click Update to install the new settings.
  10. Click Continue to allow your AirPort Base Station or Time Capsule to restart.
  11. Quit AirPort Utility.
These directions are from the Apple Support Web Site:
http://support.apple.com/kb/ht3728
Jan 02, 2011 | Apple AirPort Extreme Base Station
Can I down load any thing to get a better wire less connnection, it worked in the beginning but not now any more i have a "AirPort Extreame" wire less router thanks Alex keller
The first choice for AirPort Extreme base stations in this instance is to look at the firmware. Generally, using the most recent firmware version is the preference, but in some cases actually going to an older version may increase stability. Launch the AirPort Extreme Admin Utility (in Applications/Utilities); then select the appropriate Base Station in the left-hand pane. The firmware version currently installed will appear on the right-hand side.
The current version is at least 5.7. However, many folks have corrected dropout issues with their AirPort Extremes by reverting to Version 5.5.1. This link will take you to the download page for 5.5.1. Download the file, and then use the Updater application to install it. A caution in this approach is that you may lose some features that perhaps you had been using, but the rate of success for this approach is significant. You can revert back to your current version (be sure to write it down before you change it) if you wish.
NOTE that you MUST be sure that you are working with the firmware for the AirPort Extreme, and NOT the firmware for the AirPort Express. They are not the same.
Hope that's helpful.
Jan 01, 2011 | Computers & Internet
Flashing yellow light
Do you have the "AirPort Utility" installed on your computer?
If not, you can download it from Apple here: (Click here for Windows) (Click here for Mac)
If you run that and connect to your AirPort Extreme, it will display the error message when you click the "Manual Setup"
Let us know what the error message is and we'll try to help.
Thanks for using FixYa and Happy New Year.
Dec 31, 2010 | Apple AirPort Extreme Router
I am using the airport express to play itunes through my stereo only. I unplugged the unit to move it to a more convenient place and now I cannot to get it to work. It was working well before. I...
From my reading at the Apple support web site, it appears that you may need to download the latest version of the Airport Utility in order to get around this issue.
Additionally, Apple has just recently come up with an update to the firmware for this device.
Try downloading the latest version of the Airport Utility (Mac or Windows) and see if that doesn't resolve the issue.
After installing the latest version of the Airport Utility, try to connect to the Airport Express. If that is successful with the new version, click the "Manual Setup" button to display the "Summary" page for the Airport Express.
Next to the entry for "Version:" there should be a button to press to upgrade the firmware to the latest version (7.5.2). Perform the upgrade by following the on screen directions.
After the upgrade, again attempt to connect to the Airport Express using the Airport Utility. This should work as expected.
Before attempting to use the AirTunes (recently renamed "AirPlay"), make sure that you have the latest version of iTunes installed.
Dec 27, 2010 | Apple AirPort Express Base Station with...
It keeps flashing file! And it's not logging anymore dives.
When the amount of available memory in flash memorybecomes low, "FILE" flashes in the lower left corner ofthe display in all of the submodes of the standard mode as well as in the dive mode. Thewatch automatically switches to the flash memory statusdisplay of the system monitor mode when the water sensor gets wet while thiswarning function is activated. Please note that although it is possibleto use the watch for diving in this state, log data may not be recorded inflash memory during diving. The file error warning function is also activated andadditional log data is not recorded if the duration of a single dive exceeds 2 hours or if morethan 15 dives are made in a single day. The file error warning function may also be activated whenthe water temperature during diving is low. It may not be possible to receive watchsettings by data communication while the file error warning When the watch has switched to the file error warningdisplay, perform the garbage collection procedure in the system monitor mode of the standardmode. Thedisplay returns to normal following completion of garbagecollection. Garbage collection begins when button (C) is pressedfor at least 2 seconds during the flash memory status display. • During the garbage collection operation, an alarmsounds and "G.C." is displayed on the display. When garbage collection is completed,"Done" is displayed on the display. • Garbage collection cannot be performed when"G.C." has changed to "NG" on the battery charge indicator or when the water sensor hasbeen activated. "Fail" is displayed on the disPress button (B) in the system monitor modeof the standard mode to switch the watch to the Flash Memory Status Display. Formatting Flash Memory Formatting of flash memory begins when button (B) is pressed while pressing button (C) simultaneously forat least 2 seconds.play at this time. theoxrysa@freemail.gr
Oct 11, 2010 | Citizen Promaster Cyber Aqualand Nx Dive...
I have Adobe CS3 Master Collection and I am trying to install it on windows vista but it keeps asking for a sr .no
http://www.adobe.com/support/ultra/
this is right to there tech site ,
Troubleshoot installation problems in Adobe Ultra CS3 (Windows Vista) 2008/05/02 What's covered Overview Before you begin Beginning troubleshooting Intermediate troubleshooting Advanced troubleshooting Overview This document can help you to resolve system errors that occur while ...More > Troubleshoot installation problems in Adobe Ultra CS3 (Windows XP) 2008/05/02 What's covered Overview Before you begin Beginning troubleshooting Intermediate troubleshooting Advanced troubleshooting Overview This document can help you to resolve system errors that occur while ...More > Troubleshoot system errors or freezes in Adobe Ultra CS3 (Windows Vista) 2008/05/01 What's covered Overview Before you begin Beginning troubleshooting Intermediate troubleshooting Advanced troubleshooting Overview This document can help you to resolve system errors that occur while ...More > Troubleshoot system errors or freezes in Adobe Ultra CS3 (Windows XP) 2008/05/01 What's covered Overview Before you begin Beginning troubleshooting Intermediate troubleshooting Advanced troubleshooting Overview This document can help you to resolve system errors that occur while ...More > Ultra Creative Suite 3 Read Me
sorry you didnt say what operating system your using
but follow the top link the rest is what is on that page
Mel
Jun 07, 2010 | Adobe Computers & Internet
Internet connection drops within 5 min after (re)booting Airport
Speak with your internet provider, it sounds to me that the apple people didnt know what the problem was without getting down and dirtyy with it so they replaced it hoping for an easy fix. Seems to me that either the internet signal is being interrupted between the isp and your home .. or the motorola modem is having problems. I have never been a fan of motorola modems to begin with. Also the rentals u get from cable companies are used.. and typically subpar bottom of the line equipment that fail often. IF you think you will be using cable internet for years to come, purchase a linksys modem, as it is you are paying $3-5 a month for the rental of the modem. But I digress, speak with your isp and see if they cant troubleshoot the problem.. if 2 airports are having the same problem the chances of it being the airport... slim to none. good luck with all of this post again if nothing changes.
Aug 26, 2009 | Apple AirPort Extreme Router
Cargo Pilot for Windows Logo
26 people viewed this question
Top Cargo Video Game Consoles & Games Experts
James Wishart
Are you a Cargo Video Game Console and Game Expert? Answer questions, earn points and help others
