Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
We recently washed a load of clothes only to find water all over ther place. i couldnt find anything in the hose or the pump and cant figure out where the water came from. i am also getting the dreade F1 code but that has cleared itself now. we already replaced the board after the last F1 episode and i think i really hate this machine!! any suggestions would help
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error code F1 indicates primary control failure and to resolve this you’ll have to replace the machine control assembly. Yes you are right, this error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 29, 2010
My machine seams to go slow with a light load 500mb h/duty
500mb from memory was a Hoover top loader ??? It could be just the belt slipping underneath, but also have a look inside the drain pump hoses for blockages. These were notorious for blocking with coins and other foreign objects. . If the machine couldnt pump out properly, when it went onto spin, it would only go very slow as the machine wasnt able to build up any speed with a full load of clothes and water.
Jul 26, 2011 | Washing Machines
When draining the water from the drum, the pump sounds lime it is cavitation or surging. The cloths are also not as dry as they should be when coming out of the washer.
Sounds like there may be something obstructing the flow of water either inside the pump or from the pump to the drain hose. It requires disassembly. To access the pump, remove the 4 door screws that secure it to the frame and remove the frame, of course, remove plug first. The pump is located in the right mid rear section and has hoses and a water level switche attached to it. if you have a big towel, place it around the pump to capture the water and remove the clamps securing the hoses to see if there is anything in there. If not remove the drain hose and run a snake through it to see if there is an obstruction there. If not, you may need a new pump,.
Nov 20, 2010 | Maytag Neptune MLG2000A Front Load Stacked...
Water leaking from underneath machine
Open the top table. Check water inlet hose for damage or tear at the connecting places.
Pour water in the wash drum externally from from front side and see whether leak is present. If leaks, drum is having problem or the drain hose damaged before the drain valve end.
Mar 30, 2010 | Tricity Bendix AW1000W Front Load Washer
Bosh wasmachine doesn't was clothes
Remove hose at washer connection and check screen filter not blocked with grit from pipes. Check screen at tap end also. If both clear, machine may need water valve replaced.
Mar 23, 2010 | Bosch Axxis+ WFR 2460 Front Load Washer
Water goes down into washer, but does not seem to
Well if this is a front loading GE and it has a pump similar to the Frigidaire Models (who knows who makes what for whom) there is a check valve that closes on the pump where the hose connects to the drain hose if this has fallen apart or off the pump will allow the water to drain into the hose rather than staying in the wash tub without knowing the model number it is difficult to be certain of this. If yours has the small access panel on the front with two screws at the bottom most likely the pump check flap (small piece of rubber on the pump outlet) is probably shot. Only other thing is to make sure the drain hose has not changed position and causing siphoning of the wash tub.
Mar 02, 2010 | GE Washing Machines
How are clothes getting into pump..kenmore 3.5 front loader
Have you been loading to many clothes in the washer at one time maybe ?
Jul 27, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
(Kenmore wahsher, top load) dirts and threads on washed clothes
You'll need to pull the hoses off the pump and inspect the inlet strainer and pump impeller for debris.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 02, 2009 | Kenmore Washing Machines
Black marks on clothes
I had a similar problem. We has placed the waste water hose into an old tub next the machine. The plug hole int he sink has become blocked with lint. When the washing maching was pumping water into the tub, the tub would fill with water, which would rise a level higher than the washing machine waste hose. What this appeared to do was cause the machine not to be able to properly pump out water, leaving this horrible back stuff in the wash which would end up all over the wash. Ensuring the plub hole in the tub was clear solved the problem immediately!
Mar 01, 2009 | Fisher Paykel EcoSmart GWL15
Water in filter ,pipe doesnt seemed blocked couldnt find anything undid it all
DEFINATELY A BLOCKAGE OR RESTRICTION ON THE DRAINAGE SIDE.DISCONNECT THE PIPING COMMING FROM THE DRUM TO THE DRAIN MOTOR. MAKE SURE ALL IS CLEAR. REMOVE PUMP AND OPEN PUMP HOUSING TO INSPECT.(BLADE COULD BE LOOSE ETC). FINALLY RUN WATER INTO DRAIN PIPE AND EXPELL WATER BY BLOWING HARD.IF BLOCKED, RECTIY. REASSEMBLE AND TRY AGAIN.
Jul 19, 2007 | Whirlpool AWM029 Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
