Dear Experts. Hope you are well. I need a
Dear Experts. Hope you are well. I need a schematic for an industrial paper shredder made in China. I tried looking in the China Yellow Pages online - couldn't find the manufacturer "Wu Jin Feng Chen Motor Co., Ltd." I already know which parts are broken, just need the part numbers so I can order them. Any assistance would be greatly appreciated. God Bless! Elizabeth
SOURCE: XF50D motor won't turn shredder blades
Call ATIVIA # 877 777 4357 fax 866 765 0063 and they can help you. I GONNA GET BACK MY $$$$$$$$ .
Posted on Jan 12, 2009
  • 35 Answers
SOURCE: Broken teeth on drive gear wheels Taros paper shredder Taros 31.8
New gears are $88.50 plus freight. You won't find any used gears because these usually break first. I can help.
Posted on Feb 23, 2009
SOURCE: Need part for royal shredder model sc800
Here's what I found, but good luck...... I've been on hold for 20 minutes now....
http://www.royalsupplies.com/contact-us.html
Spare Parts: 800-222-2310
Posted on Mar 21, 2009
t_vinson57
  • 58 Answers
SOURCE: Achiever, Model CCS 5000, shredder, need a part (a large nylon gear)
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
t_vinson57
  • 58 Answers
SOURCE: order main drive gear for geha paper shredder
Good luck, Tom
Were can I find or buy the schematic for the SB-99Ci?
Contact the manufacturer of the device, whatever it is, you never say.
Oct 25, 2016 | Industrial Paper Shredders Office...
Tip
How to save repairs for paper shredders
When purchasing a new paper shredder, analyze your needs and purchase the largest shredder to fit your need and budget. If you buy one that "says" it can handle 10 sheets at a time, only put 6-7 sheets at a time to prevent overloading your shredder. Always use shredder oil to lubricate your blades and that will also prevent binding and eliminate most jams.
on Jan 12, 2015 | Industrial Paper Shredders Office...
Is it true that even though you have a crisscross paper shredder there are devices that can put all those piece back together?
no there isn't anything that can put the paper back together, if you are worryed about that then tear the paper in piece and then shred
Jan 07, 2016 | Industrial Paper Shredders Office...
Infoguard sx100m
I don't own this shredder, but most are built with similarities. Usually there is a micro-switch that's used to detect a piece of paper being inserted. Should this switch get jambed, it will continue to "sense" paper being inserted and continue to run.
As I said, I don't know this shredder, but it would be reasonable to assume that someone will need to open the shredder and clean (or replace) the switch.
As a possibility, I think I would try using one of those 3M Dust Remover can's of compressed air and see it you can dislodge any paper or paper dust around the switch by blowing through the paper entry opening. (Will need to look into the opening to see where the switch is located. Usually near the center.)
Otherwise need to have a technician come out.
Aug 28, 2014 | Industrial Paper Shredders Office...
Shredder goes 1/3 and stops has to be reversed the forward also paper comes out punched but unshredded
its the combination of plastic parts in the shredding device . the plastic tongs part craks off then the metal binds . paper builds up in that area .
its unlikely you can fix it .
youll put ur eye out trying.
Aug 03, 2014 | Industrial Paper Shredders Office...
Shredder struggles to shred paper. Do I need to oil it? It is an SD5X shredder mad in China. Itasca of Illinois is also on it.
MOST STRIP CUT SHREDDERS DO NOT REQUIRE OILING...IF ITS A CROSS-CUT SHREDDER MOST CERTAINLY YOU SHOULD BE PUTTING OIL IN WHERE THE PAPER IS INSERTED.
May 17, 2010 | Office Equipment & Supplies
Destroyit 4104 manual
I know that shredderparts.com has parts for it, but I don't know about the manual for this machine.
Aug 21, 2009 | Industrial Paper Shredders IPS16D
Tech Solutions shredder Only powers in reverse w/ green light
These are made by Winsource Industries http://www.winsource-hk.com/ The contact information is Hong Kong. I haven't had any luck getting a replacement for one with a Limited Lifetime Warrany.
Good Luck -
Jan 25, 2009 | Tech Solution TS-8000 Cross-Cut Shredder
Paper shredder
intimus 14.90 has te drive gear bearing busted how do i change the bearing
Sep 27, 2008 | Intimus 14.90 1/4 Inch StripCut and...
62 people viewed this question
jasbo
jasbo
