Question about Car Audio & Video
GCE 572RDS GCD 573C 10 DISC seems no power to changer will not eject is there any way of testing for power. thanks peter
    Genius:
  • 1,224 Answers
Direct battery hookup with low end fuses about 5 to 10 on both power and ground protect your system
Posted on May 07, 2008
Sony CDP-C910 will no longer play cds or eject changer cartridge
Mine did the same thing. My player was primarily used in the garage and the cold weather may have caused my player to do the same thing. I just fixed my player. I removed the top cover and looked at the CD in the play position. In the upper right corner from the CD, you will see a spindle motor with a belt on it. Gently spin the motor back and forth carefully with your finger. I rotated it a half-spin in either direction, careful not to dislodge the belt. When I turned the player back on, the mechanism operated as it normally would and began playing the disc. I was able to eject and reinsert the magazine without any issues, solving the problem. Hopefully that will work for you.
Dec 17, 2012 | Sony CDP-C910 10-Disc CD Changer
No power to the disc changer, how do I manually eject the magazine
There is a manual eject slot on the side of the CD changer. You will need a small flat head screwdriver or a pry tool to insert into the slot.
Oct 11, 2012 | Kenwood KDC-C715 10 Disc CD Changer
GCD-700 does not turn on. Internal fuses OK
If the fuse is intact the fault must be checked from the power supply to the main motherboard section.
Check if the power supply works, if not check the SM drivers .Click the link below;
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Feb 17, 2011 | Adcom GCD-700 5-Disc CD Changer
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 14, 2009 | iLO CA3000V CD Player
Pinout of Round Connector on CDC A08 ?
See this diagram.
http://fileshare.eshop.bg/index.php?what=search2
(search for CDC A08 if link doesn't work)
Basically, 12v to pin '3' (with notch at top, it's the top row, third pin from the RIGHT) and ground to outter jacket of the connector. Push eject button, works a charm.
Cheers.
Mar 27, 2009 | Blaupunkt CDC-A08 10-Disc CD Changer
Can't get the disc out...
is the light flashing on the drive ? .... be that as it may you will note a small hole on the face of it.... put a small round object in there and push... that should open the door.
Mar 08, 2009 | LG GCE 8523BB (GCE-8523BB-10PK) CD-RW...
Wont play and keep ejecting
Make sure there is power to fm modulator. There are 2 reset buttons, one on controller and one inside the door of the changer, push both.
Nov 23, 2008 | Xtreme Sound WMS6100RW 10-Disc CD Changer
How to eject the disc tray when not connected to the car?
hI , to enject cd is look a piece of strong tooth pick insert to a small hole at right corner of cd changer , push and and push tooth pick until the tray comes out.
Feb 02, 2008 | Sony CDX-454RF 10-Disc CD Changer
Adcom gcd-600 won't play
If I understand your issue, you press play and the player does not recognize the disc, the optical pickup may be defective. I suggest you contact an Authorized Adcom Service Center. For further questions, contact Adcom directly.
Dec 02, 2007 | Adcom GCD-700 5-Disc CD Changer
Pioneer 10 disc changer magazine stuck
i would like to be of assistance but i need to know the which pioneer 10 disc changer it is. send me the information and i may be able to help. thanks
Nov 26, 2007 | Pioneer 6CD CHANGER
Car Audio & Video Logo
79 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
