Question about Dell UltraSharp 1907FP 19" LCD Monitor
Shadow going right on my dell 1907fp monitor. don't know how to degauss it or where the bottom is to try to degauss it
  • 11,361 Answers
First try it with another PC first to make sure it is not PC problem.
There is no degaussing coil in the LCD monitor, not like the CRT type monitor that use electron beams and magnetic fileds for scanning the screen. First make sure the PC video resolution is set to the native resolution for this monitor, see your owner manual.
It can have problem in the power supply also due to bad caps and not producing clean DC to run the monitor.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Aug 29, 2010
How do i degauss my dell SE198WFP, i don't see a degauss button nor does it do it automatically
You cannot "Degausse" a flat panel screen. Degaussing is actually the de-magnetisation of the chassis of the Cathode Ray Tube. Flat panels don't have CRT's.
Mar 20, 2012 | Computers & Internet
Dell LCD 1907FP 19" have
Unfortunately this is an early indicator that the LCD display panel is starting to break down and the cost to replace the part will exceed the amount of a new monitor. I recommend using present item until it completely fails. Sometimes the video cable is the issue and should be subbed provided you can detach from both ends.
Sep 06, 2011 | Dell UltraSharp 1907FP 19" LCD Monitor
DELL 1907FP MONITOR
There were no screws on the back of my monitor so that was not an option for me. I figured I didn't have much to lose, so I took a very thin and small screw driver and pried the on-off button right out of its socket, which does break it. To the left, inside the hole,you can see where a tab on the button pressed against a small circular inner button. I pressed that with the screwdriver and the monitor turned right on. I replaced the button for the sake of cosmetics and will never touch it again. If I leave the monitor for any extendd period of time I will simply unplug it.
Sep 06, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Power Button Broken?
Yes, I think your right, if it is under warranty send it back to Dell for repair, I had the same issue about a year ago.
May 20, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Monitor display is blurry, with shadows and waves next to text
Jnanda,
Could be one of two related situations both have to do with built up magnetic flux:
!. If you have used the monitor for a significant amount of time and have never degaussed it that might be it.
To fix: Go to where your monitor's controls are (eg screen size/position, Brightness, Contrast, etc.). Providing that we are referring to an older style monitor (like a TV) and not a flat screen, you should find a degaussing button located there. This button is marked with a depiction of a horseshoe magnet. Press it.
If you have on screen settings control, hit the menu button and select the icon that looks like a horseshoe magnet.
You'll hear a buzz and the screen will go kooky for a moment.
You're then degaussed. Your problem should go away.
2. You may have moved the monitor close to a source of electromagnetic interference (or vice-versa) this will also cause that sort of thing you describe (remember that there are electrical lines in the walls (another source of EMI)
In that case move the monitor away from the EMI source or move the EMI source away from the monitor.
Remember that it could be both 1 and 2. So if the problem lessens but does not go away fully try both steps.
Feb 06, 2009 | Dell E173FP 17" LCD Monitor
Dell 1907fp USB port not working
The big question is do you have the USB uplink cabled from the monitor, connected to a USB port on the system?
http://support.dell.com/support/edocs/systems/1907FP/en/about.htm#Bottom%20View
Item #5 needs to be connected to your system's USB port via a USB cable. The ports on the monitor are just a USB hub.
Jun 09, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell 1907fp picture "shifts up"
It is most likely the cable, it is where most faults of this ilk lie in LCD monitors. :-)
Mar 27, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell UltraSharp 1907FP 19" LCD Monitor Logo
332 people viewed this question
Alun Cox
