Question about Dell Dimension 4600 PC Desktop
I removed the hard drive and put it back now it just beeps it's a dell deminson 4200 desktop
  • joecoolvette
    joecoolvette Aug 29, 2010
    Would also suggest you have; 1) Computer unplugged from power. 2) Follow Anti-Static Precautions BEFORE you reach inside your computer. [ Anti-Static Precautions: Your body carries Static electricity. Static WILL fry out the delicate computer hardware components, in a personal computer. Again computer unplugged from power. Working on a table, open the computer case. TOUCH the metal frame of the open computer case, to relieve your body of Static. Should you get up in the middle of working on your computer, upon your return be Sure to touch the metal frame again. 3) The small black rectangular objects, on the side/s of a ram memory module, are DRAM chips. This area of the ram memory module is the Body. Below the Body you will see gold plated contacts. Handle the ram memory module by the Body. Suggest you use a pencil eraser, and clean each contact. PLUS use air from a can of compressed air for computers, and spray air into the ram memory slots on the motherboard, (Yes, even if there wasn't a ram module in it), AND use air to remove the eraser dust from cleaning. (The beeps you hear are BIOS Beep Codes. It's a modified Phoenix BIOS that is used in a Dimension 4600. Could follow within Phoenix BIOS beep codes, and/or AMI BIOS beep codes. { Look up BIOS Beep Codes on the 'net}
    Guru:
  • 266 Answers
Just Refix RAM sticks and start your pc.Its better you refix the hard disk connectors also. Normally its because RAM issue. Just open the CPU cover and clean the RAM slots and refix RAMs. You can put one by one if you have multiple RAMs. check with different RAM slots.If you still get this sound you need to get new RAMs
RAM will look like as in below picture
Posted on Aug 29, 2010
Dell optiplex GX280, beep one long, follow by 3 more beeps, then two more.
This is a motherboard problem, if the video Graphics Card is a plug in remove it and test as you go, unplug hard drive, and any other hardware, if at the end of it no change, motherboard will more than likely need to be replaced.
Mar 18, 2012 | Dell OptiPlex GX280 PC Desktop
Dell 3100 will not power up
Hardware issues: (most likely the motherboard)
Start by removing:
Ram Chip one by one. See if it will change anything (if it doesn't put that back in)
Cd Drive
Hard drive
Anything else (video card, PCI components)
Dec 12, 2011 | Dell Dimension 3100 PC Desktop
Computor beeps
its a POST test beeps. POST = power on start test, it is finding a power issue in your computer, it could be anything but i would start by removing one part at a time see if the computer starts if nothing changes put it back do this one by one see if it anything inside (start with cd drive, then hard drive then video card) after those its either one of 2 things either your power supply is bad or your motherboard is dead/dying (most likely your motherboard in my experiences)
Nov 15, 2011 | Dell Dimension 1100 PC Desktop
I have a question regarding my cpu dell inspiron..Heres my problem: 1. when i start my pc sometime the fan is spinning then suddenly its stop adn run again and then I dont hear any beeps form the board. I...
There is a circuit on the motherboard that detects the ambient temperature of your computer. Your CPU fan has 2 speeds - if it detects the temperature inside your desktop getting hot, it will switch the CPU fan to hi-speed. If you removed the memory and powered on the computer and don't hear any Beep codes then you probably have a problem with the the motherboard and it needs to be replaced. disconnect cables to CD/DVDdrives. Look at the USB ports to see if any are damaged.
Aug 14, 2011 | Dell Inspiron 530s Desktop Computer
I put a harddrive from my dell computer in my gateway dx200s. It booted up but I could not verify profit key. So I replaced the dell harddrive with the original gateway drive but now it wont boot. beeps...
all you need to do is put back the hard drive to the gateway, theres like a finger print that block the hard drive to come on but if you put back to its own i will come on...if you want to make it work in the dell you need to install a fress os...period...
May 01, 2011 | Computers & Internet
How do I get the second hard drive out of a dell precision 670
Hello there. before going into the Case make sure to touch the metal
Power down the PC and remove all cables
Open the side of the Case find the hard drive you want to remove unplug the two cables connecting to the hard drive and slowly remove the hard drive from the bay you may need to UN-screw the hard drive.
put in the new drive into its bay connect both cables put the case back together connect all the cables back to the PC boot the System up and reformat the new drive .
If you need anymore help with this problem let me know, i have done it many times myself thank you and don't forget to Rate
Jan 26, 2011 | Dell Precision Workstation 670 PC Desktop
At startup I get 6 beeps. No video. hard drive had a virus on it. was working just find before the virus. ( clean the virus off). was also getting message " hit atny key to wake from sleep mode." not...
Do the beeps have a sequence? like 2 long, 2 short, 2 long. It is very helpful to know the beep code. Remove your video board ( if you have one ) and see if the same beeps occur. If not, put video back in very firmly and remove all memory chips. Same beep code? Put in one memory chip in the slot A1 conn.
Does this help you? If there is no change, jumper your rtc to wipe out battery. wait 30 sec. then put jumper bck to normal position. If you can, removing the nickel Battery would be a good idea for 30 sec. Make sure to put it back in. If you're still getting the same beep code, or if it has changed to a new tempo, we are on the right track and you will be able to fix it.
Mar 21, 2010 | Dell Dimension 4700 PC Desktop
I have a dell 4600c When i turn it on it powersup but no video
unplug your computer
Open the computer case up, reseat the memory by removing it and putting in one ,and starting the system,and check all power cables are connected. Do this to each memeory module that you have to test your memory.
IF that doesn't work remove , memory,hard drive cd/dvd drive,and printer etc.turn system on and if it does not beep then the motherboard is bad. The motherboad should beep to indicate that their is no memory.No beep equal no response from the motherboard. hope that helps.
Jan 10, 2010 | Dell Dimension™ 4600C PC Desktop
Computer Beeping, something loose?
looks like u've done most of the steps.
put everything how it was, change the ram to the next availble slot. remove power, remove bios battery "like a watch battery" wait 10min and put back on and power on see what happens
Mar 11, 2009 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Dell deminson 4600 fails to power up, power supply tested ok.
No beebs, no bueno. Unplug the power cord. Unplug the wide multi colored adapter from the motherboard and reseat it. make sure the other conntections are firm while you're down there and have the case open.
If you don't know what I'm talking about or don't want to crack open your PC then buy a new Dell and hae someone slave up your drive and transfer the information.
Jul 16, 2008 | Computers & Internet
Dell Dimension 4600 PC Desktop Logo
164 people viewed this question
Alun Cox
