Printing ONLY 1 page of the document when using letter size paper...then windows xp in the printer/fax window says error message. restored factory settings, printed test page. continues to display "size mismatch" on the printer. Changed paper size to legal...ALL WORKS GREAT. Why cant I print letter size documents? Turned the "Auto Continue" off and on..NO difference. Any suggestions?
I have a problem with the "size mismatch" error. Does anyone else has a similar error and has an answer?
AnonymousJan 16, 2009
how do you remove transfer rollers on the magicolor 2300Dl? how do you remove transfer rollers on the magicolor 2300Dl?
AnonymousMar 27, 2014
The printer keeps printing the same page as soon as it is switched on, and won't stop even when printer set to "pause". Is there some way to clear the buffer? (Using iMac OX 10.7. Printer usually works well.)The printer keeps printing the same page as soon as it is switched on, and won't stop even when printer set to "pause". Is there some way to clear the buffer? (Using iMac OX 10.7. Printer usually works well.)
You can't post conmments that contain an email address.
How to specify the paper size and page setup
This section describes the procedure for specifying the paper size
or page setup when printing from an application, taking Adobe Reader 6.0
as an example.
Note:
The screen shots used in this section are from Windows XP Home Edition.
1. Open the PDF file to print with Adobe Reader, and then select [Print Setup] from the [File] menu.
2. Specify the paper size of the document and the printing orientation, then click [OK].
3. Select [Print] from the [File] menu.
4. Select this printer for [Name] or [Printer Name], and then specify the printing preferences.
Note:
The printer name displayed in this dialog box can be
changed in the [Printers and Faxes] folder (the [Printers] folder for
Windows 98/Me/2000).
A web search suggested thihs would be the reason for the 21140 code>
Issue: "The selected paper size is not supported by your printer..." appears after selecting the Paper Size in the printer driver.
Solution: Use Fit-to-Page Printing (Windows)
The Fit-to-Page function automatically resizes the image to fit the size of the page being used. Letter size image data, for example, will automatically be printed on 4" x 6" size paper. Paper sizes larger than the printer can handle will be available on the Page Setup of the printer driver but will not print unless the Fit-to-Page function is enabled.
Note: The Fit-to-Page Printing function is not available when Borderless Printing is selected.
Access the printing preferences by opening the printer Properties / Preferences:
For Windows Vista
Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
Click your right mouse button on the listing for your printer, and then select 'Preferences' from the menu that appears.
For Windows XP Home Edition
Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
For Windows XP Professional Edition
Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
For Windows 2000/Me/98
Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
Click the Page Setup tab.
Specify the 'Fit-to-Page Printing' settings.
(1) Select Fit-to-Page Printing.
(2) Select the size of original document created in application program. Paper sizes larger than the printer can handle will be available.
Two Minolta 2300DL windows 7 64-bit solutions(choose oneoption):
1) Download the XP 64-bit driver and extract to a folder:
ftp://ftp.minolta-qms.com/pub/crc/out_going/windows/2300d_64b.exe
then Control Panel>Devices and Printers>Add aprinter> Add a local printer>choose USB printer port>select the "HaveDisk" button(do not select a printer) and browse navigate to where you savedthe XP 64-bit driver "MLUU_DRV.inf" driver file which installs and worksfine. Only issue is now have a 3 minutewait delay for each print job using the universal driver compared to no delaywhen printing with XP.
OR
2) Follow the Vista USB port(not network) install guide butstill use the XP 64-bit driver.
ftp://ftp.minolta-qms.com/pub/crc/out_going/manuals/misc/km_vista_instruct.pdf
3) 32-bit option use the Vista 32-bit driver first as thatshould work.
Mr Stephen You have to check paper settings at 3 places first that you are putting correct paper size in correct tray and the paper supporter is touching the paper. Secondly your documents page setup paper size. Finally go to printer properties and under paper selection you will find letter size change it to a4
Thankyou for using free solutions at yafix-ratings from your side would be appriciated.
Need to set A4 size default on the printer driver itself. Go to Printers and Faxes / Konica Minolta 2490MF right click/ Printing preferences / Create a "Easy Set" with a new name. Set all paper sizes to A4. Save the new settings to the new Easy Set. Click apply.
The
For Windows Vista
Click
Click
(2)
Issue: "The selected paper size is not supported by your printer..." appears after selecting the Paper Size in the printer driver. Solution: Use Fit-to-Page Printing (Windows)
For Windows Vista
I am using Vista 64 and a 2300DL in the same manner as abertola003. I downloaded the Latest driver from Konica Website and everything is working well. the driver is named Konica-Minolta 2300DL (unidrv)
Look in driver and see if the paper size is set to a different size. It could be that the driver says you want Letter size prints but you have A4 in the tray.
The problem is most likely a driver setting that is set differently to what you need.
Another option is to check that the paper feed guide is pushed up properly. If it is set too wide the machine may think it has a different sized paper in it.
Test the driver. Go in the properties for the printer and set the number of copies to 4. Try to print a Windows test and and see if you get the same error message. If you do, then the issue is the paper settings in Printing preferences and probably needs to be changed to LETTER paper. If you don't get an error message, the issue is the application you are printing from. Make sure the application is set to letter under printer setup.
