Question about Dell Inspiron 710m Notebook
710m Fails Power On
My laptop froze in Windows and won't boot after a cold boot. Basically the power button lights up and the fan spins, but no POST. The internal speakers don't work so I can't get any audibles.
I tried booting after removing the battery with power unplugged with the same result. Any ideas or suggestions? Thanks!
  • 1 more comment
  • ironcrosser May 07, 2008
    Thanks for the quick replies, guys.
    IB4G2008:
    On power-up the laptop never make it past POST. It appears to just sit there with no activity. Only the fan spins and stops.
    Guest
    1) Doesn't seem to be a drive issue since I removed the DVD drive completely with the same result.
    2) The hard drive appears to be alright; I removed the hard drive and was able to get the Windows XP boot screen on another laptop (of course it wouldn't boot to the new hardware).
    3) I will test the backlight later today along with toggling the F12
    If anyone has any other suggestions for me to test I will greatly appreciate it! Thanks, everyone!
  • ironcrosser May 08, 2008
    Here's an update on the issue:
    IB4G2008:
    I cannot get into the BIOS setup or boot from recovery disk. The laptop powers on, fan spins, and cd-rom lights up then goes dark.
    Guest:
    3) I tested the backlight and it does not appear to be the issue. The F12 is unresponsive.
    Any other ideas? Thanks!
    Update:
    I was able to access all my hard drive data using a USB 2.0 enclosure, but still unable to get my laptop past POST.
    Anyone have any idea what hardware could be causing this issue? Thanks!
    Problem Solver:
  • 7 Answers
This can be caused by a few different reasons.
1. Does your CD/DVD drive open when you push the eject button? No? Maybe the drive is bad and your computer is setup to boot from this drive first so it just sits there waiting for the drive to respond. If you are able to, you can remove the drive to test. It may not allow you to even boot into BIOS otherwise. When booting, do you see anything on the screen?
2. Your hard drive may be bad. Your drive should have a restore partition on the drive. When booting, hit F12 to enter the Dell utilities/restore utility or whatever Dell calls it. If you can enter this area, maybe only your main partition is damaged. At this point, you may need to have a technician look at it because it may be your last chance to recover any files on the drive. If you don't care about losing your data, you can continue the recovery procedure to restore your computer to factory conditions. Again, you WILL LOSE ALL YOUR DATA AND PROGRAMS. I've seen drives that lose their data but continue to function fine after a reinstall. If this is the problem, it would explain why your computer froze then stopped working on reboot. If you are familiar with Linux, you can download a live CD and backup your data and/or see if your drive is readable at all.
3. Your display has a backlight. This backlight can go bad. If this is the problem, you won't see anything on the screen. To test this, get a flash light (the brighter the better) and shine it at the screen while the computer is on. You may need to try it from different angles to see something. If your backlight is bad, you should be able to see something (windows, your icons, etc.) on the screen when you shine the flashlight. On your model, I don't know how easy this would be to fix. Another way to test this is to plug in an external monitor. You may have to cycle through the settings using the F8 (or whatever key on your notebook controls the external display). If it's the backlight or display that's bad, you may get an image on the external monitor.
Hope that helps.
Posted on May 07, 2008
    Genius:
  • 3,587 Answers
Try booting from a recovery disk
  • Patrick Michaels
    Patrick Michaels May 07, 2008
    haha...that's funny..you may find that this suggestion is precisely what you'll wind up doing.
Won't go into windows XP
What happens when you press the power button?
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Remove the battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 05, 2012 | Computers & Internet
Acer aspire 2920 power light on fan spins then stops and wont boot
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 23, 2012 | Computers & Internet
No letting me reboot computer what to do
Whenyou plug in the power cord is there any lights whatsoever on the laptop, wherethe plug goes in or on the AC Adapter of the power cord?
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Pressand Hold the power button for 30 seconds. After 30 seconds plug the powercord back in and hit the power button to see if it boots. Maybeyour memory is bad or the memory slot is bad.Removethe Power Cord, Open the Case and remove one of the memory chips. Set thechip aside then try rebooting the computer. If it boots, then you knowthe memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and tryrebooting. If it fails take the chip out and set it aside, then put theother chip in and try booting it in both slots. If it boots, just toverify that the chip set aside is bad, mark an x on it and put it into the openmemory chip slot and try booting.Maybeyour power supply is bad. Sometimes there is enough power to make thepower light come on but not enough power to make the fan turn on or harddrive spin.
May 11, 2012 | Computers & Internet
Lx6810 blinking power light
Maybe your power supply is bad. Sometimes there is enough power to make the power light come on but not enough power to make the fan turn on or hard drive spin.
May 10, 2012 | Gateway LX6810-01 PC Desktop
Desktop runs but won't boot
Normally if the hard drive is bad you will get some type of message on the screen.
If it sounds like it is running but the screen is blank, then try another monitor. Maybe the monitor is bad. Try another monitor. Borrow a monitor from a neighbor, friend, relative or co-worker and put it on the computer. If the borrowed monitor works, then your old monitor is bad. If the borrowed monitor does the same thing, then your video card is bad.
If it does not seem like it booted up all the way then try the steps below.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
May 09, 2012 | HP Computers & Internet
PCV R44G, won't boot, no fans, won' turn on.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 22, 2012 | Sony Computers & Internet
Toshiba satellitep205d-s7438 won't boot up
You need to be more specific and tell what happens when you plug in the power cord and press the power button. There are a number of reason why a computer will not boot, but if you tell what's going on someone can help you.
Computers don't boot for basically the following reasons, 1) the power supply is bad. That means when you plug it in you don't see any lights, and when you press the power button nothing happens, you hear no fans, no beeps, no blinking lights, no hard drive spinning, no cd drive clicking and nothing appears on the lcd screen.
2) A motherboard issue, usually when this happens you will either see blinking lights or hear beeps. Those blinking lights and beeps are codes that tell the technician what is really going on.
3) Static Buildup - try removing the battery and the power cord then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back in (leave the battery out) and Press the Power Button. If it boots up you had static buildup and can replace the battery, count your blessings and Thank The Lord cuz a dishonest repairman would have told you he had to replace the motherboard for $300
Mar 20, 2012 | Toshiba Satellite P205D-S7438 Notebook
Dell won't turn on, screen blank, battery light on when pluggedin
Take battery out and see it will turn on with just the power supply. If this does not work try with just the battery and no other power. If these do not work try to find a know good battery and power supply and these steps again. If all this fails it will most likely be the computer power supply which in some cases is quite a costly repair. It is possible that the motherboard or processor is defective causing this issue.
Mar 20, 2010 | Dell Inspiron 710m Notebook
Laptop fails to boot. no post beeps no video Power light comes on Hard Drive light comes on briefly and the Drive can be heard spinning up then stopping. Laptop was originally purchased in North Korea
Clean first its ram module edge connector with soft eraser. But disengaged first its battery, power source and completely shutdown.
Then put it back and try to boot. If this doesn't help let me know . Leave a comment.
Apr 23, 2009 | Computers & Internet
Dell Inspiron 710m Notebook Logo
81 people viewed this question
Alun Cox
