Question about Office Depot Ativa LH-1H18AX DVD±RW Burner
GET ERROR MESSAGE THAT EVERY TIME I TRY TO BURN A DISC THE WRITE FAILES !!! IS THERE A FIRMWARE UPGRADE OR SOMETHING I CAN DO
  • Office Depot Master
  • 27,725 Answers
Try using a different brand of writeable disks you may have a bad batch
hope this helps good luck
Posted on Aug 29, 2010
How can u fix error 80010516?
To solve this error :
Never eject disc while game is in use.
Delete all your messages.
If playing a game on disc, clean the disc off and ensure disc is inserted properly.
Upgrade your firmware to the latest version.
Under Game settings, set PS/PS2 Upscaler to Off.
Restart your Playstation 3 and try again.
If all else fails, the disc might be defective.
Mar 01, 2011 | Sony Playstation 3 (PS3) Console
I have a DVD duplicator 2057 and when I burn a cd, it won't play in the car, but the original works fine. Both discs are the same and I have tried 10 time and all failed. I even used DAO and TAO, still...
If you are troubleshooting a system or OS problem, you should not consider firmware updates until after exploring more typical troubleshooting steps like file system error checking and anti-virus scanning.
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this should schedule the task on restart then defragment your hard drive
hope this helps
Jan 30, 2011 | Computers & Internet
I have tried downloading from the samsung website lastest firmware update, which is an iso file when extracted it saves it to disc as a xuf file and the blu ray wont read this what am i doing wrong??
Read the Upgrade Guide (PDF) for instructions on how to do this. It says to burn a CD. The ZIP file extracts to ISO type. The guide tells you what format it needs.
http://www.samsung.com/us/support/search/supportSearchModelResult.do?menu=SP00&searchWord=bdp1400&searchInputBox=bd-p1400&find_button=
READ the PDF file under Upgrade Guide. Make sure you designate the proper file type when burning CD. Check your burning software.
How to make a firmware update CD
Please follow the below procedures.
1 Download the new firmware file from www.samsung.com
2 If the firmware file is compressed (*.zip), the file should be uncompressed to CD image file
(*.iso).
3 Please burn the CD image file on a blank CD-R/RW disc
1) Recommended CD Burning Program is Nero Burning ROM.
2) Burning Options (in case of using Nero Burning ROM)
A. ‘Recorder’ menu ?? ‘Burn Image…’ ?? Select an uncompressed image file(*.iso)
B. Please check ‘Finalize CD (No further writhing possible!)’
C. Please refer to your own CD burning Program Manual if you want to use any other
CD burning program for burning ISO image file.
D. Make sure if the downloaded software is eligible for your BD-P1400.
E. The System Upgrade will not be executed if using the update CD made with NOT
following the upper procedures.
Warning
The following events may interrupt the upgrade process and MAY RESULT IN PERMANENT
DAMAGE TO THE UNIT WHILE UPGRADING.
1. Unplugging the power plug
2. Power outage
3. Dirt or scratches on the burned CD-R/RW disc
4. Closing or opening a disc tray during update processing
How to upgrade the BD-P1400
1. Press OPEN/CLOSE button to open the disc tray.
2. Insert the upgrade CD.
3. Press OPEN/CLOSE button to close the disc tray.
4. Please wait about 6 minutes while verifying.
Verifying Firmware Version.
5. When below message box comes up, please check the date of the Firmware version.
Do you want to update Firmware?
>Current Version : 070730.02_XAA
>New Version : 070903.01_XAA
Yes No
6. Press ‘Enter’ button to choose ‘Yes’ for upgrade and please remove the disc on the tray.
If you select ‘No’, BD-P1400 will be automatically powered off.
If you don’t see above message box, try another disc. Generally, this is caused by disc
quality or a disc creation problem.
7. Please wait for about 7 minutes.
Firmware Update.
Now, Processing…
Please, do not turn off the power.
8. When finished, the screen and the power will turn off automatically.
9. Turn on the unit again. The tray will close automatically. Below screen will show up. Please
select the language you want with a corresponding number button.
MENU LANGUAGE SELECTION
Press 1 for English
Pulsar 2 para Español
Touche 3 pour Français
Macrovision : BSS01
10. If you want to do System Upgrade through the network, please refer to ‘System Upgrade’
Article on the User’s Manual.
Aug 18, 2010 | Samsung BD-P1400 Blu-Ray Player
Masterlink "Disc Read Error"
try to reinstall the O.S. /firmware.
the firmware is avail on the alesis site
dave
Sep 11, 2008 | Alesis MasterLink ML-9600
DVD will not finalize
Bad Disk batch is the most common problem if it is occuring with the same batch of dvds. Other problems could include that you need to get a firmware upgrade for higher speed discs. If you are using a disc that burns faster than the current speed of the machine you need to download the upgrade (follow the directions that are given in most dvd blank packs) and insert the CD that you downlaoded the program onto into the DVD player/recorder.
Feb 09, 2008 | Zenith XBR716
Error message NG: 01 F->
have you tried burning at a slower rate or are you using cheap DVD media?
Feb 07, 2008 | Computers & Internet
SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
DVD+RW & +R DL
In order to upgrade the firmware the LG drive MUST be on it's own IDE channel and 60 conductor cable and be set as master.
___________________________________________
Quoted from the LG support firmware file download:
Critical Instructions: (to be followed carefully)
1. Connect the drive as master by it self, on the secondary IDE controller with no other device on the same IDE cable, making note to set the jumper on the back of the drive to the master position.
To check this open the computer case.
If you need more assistance, post here again.
Oct 03, 2007 | LG GSA-4160B DVD±RW Burner
Office Depot Ativa LH-1H18AX DVD±RW Burner Logo
71 people viewed this question
Top Office Depot Computers & Internet Experts
jmcoll
Shawn DuRee
Are you an Office Depot Computer and Internet Expert? Answer questions, earn points and help others
