Question about Sub-Zero PRO 48 Side by Side Refrigerator
I have a subzero pro 48 and it keeps beeping because the fan would not start, how can i check the fan
2 Suggested Answers
imufo2
  • 3773 Answers
SOURCE: I have frost on the
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 10, 2011
The refrigerator on my SubZero 650 is too warm. I set 38 F and the indicator goes directly to 48/50 degrees within a second of me releasing the temp select button. Freezer works fine. I have cleaned the...
I believe it's showing the actual temperature that it's currently inside the refrigerator, not the temperature it's set at. At least that's how my sub zero works. You may need to clean the coils to get it to cool better.
Apr 28, 2010 | Sub-Zero 650 / O Bottom Freezer...
Does the fan is on all the time?
old subzeros the CONDENSER FAN MOTOR RUNS OLD THE TIME. SAME WHIT THE EVAPORATOR FAN MOTOR. RUNS ALL THE TIME. now fos systems whit 2 compressor the condenser fan motor run for both compressor. only stop when both compressor stop......
Nov 25, 2009 | Sub-Zero 611 / O Bottom Freezer...
Subzero freezer has frost/ice build up on the
Check the fan and readjust temperature control to higher. Thanks.
Oct 22, 2009 | Sub-Zero Bottom Freezer Refrigerator
Hi,toshiba satelite pro L20 beeps when start up
Run check disk for hard drive errors. I recommend immediately backing up all your data that you can, wiping it, and reinstalling your programs. The rebooting problem smells like a bad hard drive. I just went through it with a Compaq at work.
Sep 16, 2009 | Toshiba Satellite Pro 6000 Notebook
SubZero 550 Water keeps collecting at the bottom of the refrigerator, behind the vegetable bins. I see it leaking from the drain pipe and the handyman has tried to clamp the pipe, but not sure why so much...
your drain may be plugged... it will need to be clean and clear... it may freeze too it you have ice in it you will need to add a drain heater to keep it clear
Sep 11, 2009 | Sub-Zero 650 / O Bottom Freezer...
Subzero model #561, freezer is warm, water leak
Check to see if the freezer fan is running. Push in the two switches at the top. The light should go out and if the freezer is powered on the fan should come on. The icemaker runs on temperature so no cold means no ice. Check for ice build up around the evaporator. Could be a defrost issue or a sealed system problem. As for the water, is it the floor of the unit or the floor of the house? Is the drippan in place or sitting on the floor? Also check the condenser fan motor. If this is all greek to you, you should probably call a factory authorized servicer.
Feb 03, 2009 | Sub-Zero 561 / F
CF-48 looses it's operating system!!systems seems to over heat and starts beeping!
Most laptops get warm at or near the processor as the fan is pumping air across it. This is why it is not recommended to sit it on your lap - blocks air flow and can cause burns. It would be worth checking that the fan is spinning freely and air is circulating as they **** in a lot of dust.
As for the beeps. Since you are getting OS not found it is most likely a flaky hard drive.It may not be spinning up initially, but a few tries could be kicking it over.
I would suggest backing up all your data and then replacing the drive. Laptop hard drives are notorious for failing due in part to physical movement of unit, particularly when turned on.
Aug 14, 2008 | Panasonic Computers & Internet
Subzero 690 flashing EC and service
If you replace the fan and clean the coils, and the refrigerator STILL does not cool, then contact SubZero or a service provider for an evaporator coil replacement.  Units manufacturer before mid-2003 had copper+aluminum coils that would corrode and allow all of the coolant to escape.  The (should be warranty) replacement is all aluminum.
Note the freezer does not have this issue due to the lack of liquid water.
Feb 20, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero PRO 48 Side by Side Refrigerator Logo
154 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
