Question about Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum
Beater bar not working on newer ball pet unit
  • 40 Answers
HighnTools posted this solution some time ago. I think it can help you solve your issue.
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
Posted on Sep 28, 2010
Y Shark "Professional" model 540 26 is making a terribly loud noise and not picking up dirt. t also gets HOT
Check( 'beater bar',suction tube to canister) for accumulation of hair,carpet fiber,pet hair,etc....cut hair,etc,with scissors,clean...might also be hair stuck in belt that drives beater bar
May 08, 2017 | Shark Vacuums
Beater bar only spins when vacuum is locked & upright.
Your belt is probably stretched and can't turn the brush when it's on the floor. Replace the belt at least twice per year.
Feb 23, 2016 | Bissell Pet Hair Eraser Bagless Vacuum
My XV 11 Vacuum keeps on bringing up the message " My vacuum is stuck"
This message generally means that the beater/brush bar is not turning. Try rotating the beater/brush bar manually to see if it can turn freely. If not, you will need to remove the beater/brush bar and ensure that it is clean; that the orange end caps on the brush are free of hair and dirt, and that the bar housing area is free of obstructions.
Note, when I said "beater/brush", it could be either/or, depending on whether you're using the "standard" beater bar, or the upgraded pet brush.
May 31, 2014 | Neato XV11 Vacuum
Vacuum doesnt pick up very well any more
Larry Kessler:
Unplug the vacuum and lay it down on the floor upside down on some newspaper. Remove the vacuum head foot plate with a Phillips head screwdriver. Remove the beater bar and belt by pulling straight up on the beater bar. Pull the end caps and bearings from the ends of the beater bar... it may take a two-grunt pull to remove them, or CAREFULLY use a screwdriver to pry them off. Remove the hair, carpet fibers and other gunk from the ends of the beater bar, bearings and end caps. Pour (or spray) alcohol on the bearings and spin them until they spin freely. Dry the bearings so there is no alcohol in them.
Put a few drops of light machine oil in the bearings, (3 in 1 oil will do), and spin the bearings to distribute the oil and ensure the bearings spin freely. Now would be a good time to check the vacuum head opening and the hose for clogs. Reassemble the end caps and bearings to the ends of the beater bar and reinstall the beater bar assembly (with a new belt) in the vacuum head. Reinstall the foot plate, and your machine should pick up fuzz balls the size of Michigan!
Feb 15, 2013 | Vacuums
When I use the vacuum it smells like something burning but it does work. How do I fix this? Thank you Sharon Post
Hi ssharonxxx...
Sounds like you have hair,strings,debris caught on the beater bar and it is causing the belt to burn on the beater bar or motor.
Remove the bottom of your vacuum and clean,oil and replace the beater bar, that should solve your burning smell problem.
Please take time to rate me thumbs up
Sep 14, 2011 | LG Electronics Kompressor Pet Care Upright...
Beater not turning but belt good. beater motor not turning but turns manually
Hi Dan:
check both ends of the beater bar. Pet/Human hair, thread, strings and even dirt can really get wound up in between the plastic ends and the bar. It might look ok but it won't turn effortlessly. If you find that is the case, you might be able to fish the junk out but from experience it's just better to buy a new beater bar or roller part.
Mar 12, 2011 | Electrolux EL8502 Versatility Bagless...
The Beater Bar keeps Shorting out, we had to replace it a while back and it was working really good, then it started shorting out, do you know what the problem is?
HighnTools posted this solution a while ago. There are so many people having similar issues. This might be related to your problem: I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
The above by highntools.
May 11, 2010 | Dyson DC15 All Floors - The Ball Bagless...
How do I install a hoover windtunnel vacuum cleaner belt. The bagless one,.
First, take it outside or to the basement. This can get messy. Turn the vacuum cleaner upside down. Remove four 1-1/2" self-tapping screws that hold the bottom cover in place (where the beater bar is.) Remove this and you will see where the belts go; one from the beater bar to a grooved wheel and one from a bowed wheel to a metal spindle way in the back. The beater bar will lift right out. Be sure to clean the threads and pet hair while you're at it.
Mar 28, 2010 | Hoover U6630-900 WindTunnel Bagless...
Beater bar on Dyson upright won't turn when handle is lowered
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
Dec 20, 2008 | Dyson DC15 All Floors - The Ball Bagless...
Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum Logo
174 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
