Question about Nokia 6600
Don't working on side keypad - Nokia 6600
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 122 Answers
Maybe you need clean inside,or setup screws ,or change keypad
Posted on Aug 29, 2010
My keyboard buttons don't work ..phone on 1 mint keyboard botton working but leat no working only keyboard no working
My Dear your phone keypad ic default so please change keypad ic
and keypad problem will solved
Aug 15, 2012 | Nokia N96 Cell Phone
My buttons don't work
Your Phone Keypad Ic Deafult So Please Change keypad Ic
and keypad Problem Will Solved
Jul 24, 2012 | Nokia N96 Cell Phone
I have a proform 650 v threadmil, and the left side of the buttons panel (start button and incline levels) don't work. could someone help me?
1) tight all connector wires and clean
2) tight the ribbon cables from keypads.
3) Run the software calibration for diagnose, and troubleshooting, and fix it.
4) lube the shaft and gear in the elevation motor,
5) adjust the potentiometer for better running see the diagram.
God bless you
Jun 19, 2012 | Proform Exercise & Fitness
Some keys don't work
Yes! the whole keypad control board will need to be replaced.
May 17, 2012 | KitchenAid KHMS155L Microwave Oven
Liftmaster chamberlain professional 771E-03 infrared sensor - have these on my gate system and operate it with a button system - was told sensors needed replaced - have done this but the one button keypad...
Why don't you try contacting Chamberlain? The information is below but you need to get the model number of your system. The number you give must be a part number of some kind.
support@chamberlain.com, or call toll free Technical Support Hotline at (800) 528-5880
Aug 26, 2011 | Sears Craftsman LiftMaster Chamberlain...
The key pad on my Motorola V3s RAZAR doesn't work the only button that works is the power button. All the other buttons don't work, how can i fix it myself.
If you're going to do it alone,follow this steps.
1. try to check if the volume up or down is working,if not, remove the battery cover and dismantle the lower panel at the back using a T6 precision screw,unscrew 2 screws and by using your thumbnail look for edge cover,insert and lift it up gentle (remember that a flex connector is attach on the right side If done,check the volume switch and remove the circular metal (keypad membrane) that is volume high and low apparently.clean it and align it when returning back before assembling it(might some shortage or hang buttons that's why keys are not working).,also try to check if the flex connector or socket is clean as well as the board socket connector cause keypad function has the line with it.assemble it and try if its working.
2. If the method above fails,need to replace the keypad flex cable.it maybe to risky for you to do cause the keypad connector is connected at the upper flip panel.i maybe reliable if you continue and there's a chance to break the lcd cause upper portion is to hard to dismantle.better bring it a mobile service center for keypad flex replacement.
hope this simple solution helps.
Jun 19, 2011 | Motorola Mobility RAZR V3
When trying to text a message, some keys are not working - example, to text the word "what" I can text wha but no t. Is there a way to reset the keyboard?
Hi, they don not reset keypads. They can only clean or replace with another.
What causes a phones keypad not to function especially when some of the keypads works and some don't work is due to IC inside the phone panel that controls the keypads to function is bad. And it will only stay like that until the IC is replaced.
You will to take it to a skill personnel for assistance.
Have a nice day.
Aug 06, 2010 | Pantech Slate Cell Phone
How to take apart the samsung gravity sgh-t459
Remove battery cover and battery. Using a #00 philips head screwdriver, remove the 6 screws around the perimeter. Slide phone open and carefully pry up on the edge of the green (or blue) trim near the space bar. The colored back should unsnap. There will be two philips head screws visible on the now exposed circuit board. Remove these and carefully pull up on the rectangular ribbon cable to disconnect the main circuit board from the keypad circuit. Carefully peel the two button contacts from either side of the phone. On the spacebar edge, there will be a clip holding the circuit board in place. Gently pry it away from the board and the board should come free (there will be clips on the other side but you should be able to lift the free side of the board up and slide it out from under the clips). Remove the QWERTY keypad. Unglue the remaining ribbon cable from the keypad frame. Undo the 8 silver screws securing the keypad frame to the hinge and lift frame off. There will be 4 screws visible on the back of the LCD case. Remove these and insert a thin plastic spudger at the top of the frame and carefully work your way around. The two halves will separate (should hear two snaps on each side). You will now be into the keypad/LCD section of the phone. Removing everything else is pretty straight forward. Follow these directions backwards to reassemble.
Oct 10, 2009 | Samsung Gravity SGH-T459 Cell Phone
Keypad doesn't work onlt the on/off button
hmmmm... maybe a one of the side buttons is stuck up..try pressing them if all side buttons click, if not then there's your problem
Jan 24, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Nokia 6600 Logo
15 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
