Question about Intel D101GGC Motherboard
I'm looking for a diagram of this Motherboard so I can see where the ATA jumper is.
  • 2,335 Answers
I can help you with your Intel D101GGC Motherboard problem.
The product guide pdf for your Intel D101GGC is available from intel here.
The Technical Product Specification for your Intel D101GGC is available from intel here.
Either document will specify the board layout information you are after.
I hope that helps.
Posted on Aug 29, 2010
5kpl-vm asus mother board not detected new sata segate HDD how to resolve
The BIOS does not detect or recognize the ATA / SATA hard drive Tips and tricks for troubleshooting a Serial ATA or ATA/IDE internal drive that is not detected in the BIOS.
There are six main reasons why a system BIOS will not detect the presence of an internal hard drive. Here is a list of them. They are not in any particular order, but you can follow these steps one by one to troubleshoot this problem:
  1. Drive not enabled in the BIOS
  2. Serial ATA drivers are not properly installed
  3. Faulty or unplugged data cable
  4. Drive is not spinning up
  5. Incorrect jumper settings on the drive
  6. Faulty hard drive
Note: Sections 3, 4, 5, and 6 pertain to PC or Mac systems. Sections 1 and 2 pertain only to PC systems.
For more detailed step-by-step troubleshooting on this topic, please see the Seagate Serial ATA troubleshooter "Drive Not Detected" section.
After verifying that your ATA or SATA port is set to Auto-Detect or is enabled, if you find that your disk drive is not being detected (auto-detected) by the system BIOS, try the following steps to try and isolate/troubleshoot the problem.
  1. this link can be useful.
    System setup is where the date and time are stored and where startup preferences like NumLock or Passwords are defined. In addition, many hardware settings are defined in System Setup.
    In particular, hard disk drives are often controlled here. At the simplest level, hard drives are numbered in Setup as Drive 0, Drive 1, etc or sometimes as Primary Master, Primary Slave. Which ever way these are named, they have a basic ON / OFF setting (sometimes AUTOMATIC or something similar). If your drive is not detected it may be because it is turned OFF in System Setup.
    In most cases, the boot drive is Drive 0 or Primary Master. When you add a second drive to the system, it may be need to be enabled by turning it ON in System Setup.
    Sample screen shot showing a Dell System Setup section for disk drives:
  3. To be able to hit the F6 button, you must restart the Setup process, and watch the bottom of the screen after pressing Enter on the "Welcome to Setup" screen. There will be some moments of files being loaded, and then you should see a message appear that says "Press F6 if you need to install a 3rd party SCSI or RAID driver". This message will only stay on the screen for a couple of seconds, so press F6 as soon as you see it appear.
    (Click to expand)
  4. After this is done, you will see other messages appear, and it will act as though nothing is happening, but eventually a screen will appear that will allow you to install the drivers for the add-in SATA controller. The screen will look like the sample below:
    (Click to expand)
  5. After you press S, the driver install process will continue and the floppy diskettes will be needed. Further instructions will be furnished after the driver install process has ended.
    (Click to expand)
  6. Insert the floppy diskette containing the drivers for the add-in Serial ATA controller.
  7. Once the drivers are loaded, proceed with the normal Windows XP/2000 installation.
A few further notes on the driver diskette:
For the hard drive to be detected in a new installation, the drivers for the add-in SATA controller/motherboard must be loaded at the beginning of installation.
The drivers for the controller/motherboard can probably be found either on the CD that came with it or on the manufacturer's website. These drivers do not come from Seagate; they come from the motherboard manufacturer. Simply load the required drivers on the diskette and have it ready.
  • Document ID: 182453.
    Here are some images of Serial ATA cables. Click to expand.
  • The BIOS will not detect a hard disk if the data cable is damaged or the connection is incorrect.
    Serial ATA cables, in particular, can sometimes fall out of their connection. Be sure to check your SATA cables are tightly connected to the SATA port connection.
  • The easiest way to test a cable is to replace it with another cable. If the problem persists, then the cable was not the cause of the problem.
  • For ATA drives, Seagate recommends using UDMA cabling with a maximum length of 18 inches. UDMA cables have color coded connections which require proper orientation when connecting.
    • Blue connector - always connects to the motherboard.
    • Grey (middle) connector - is used for slave devices on the cable.
    • Black connector - is used for master device connection.
    See this image:
    (Click to expand)
  • to determine whether it is providing sufficient electrical power to operate the drives and devices you have in your computer.
  • If the drive is still not spinning, connect it in another computer if possible.
  • Connect the drive in a SATA-USB enclosure or something similar if possible.
  • If the drive does not spin up after all of these steps, please visit the Warranty page to begin a warranty replacement order.
  • 48-8s.jpg -- (Click to expand) Jumper settings for Seagate SATA drives
    -48-9s.jpg -- (Click to expand) Jumper settings for Maxtor-brand SATA drives
    ATA: It is recommended that all Seagate ATA hard disks supporting the Cable Select jumper option be configured as Cable Select. If your computer system was built prior to October 1998 and does not support UDMA 66 or greater you will be required to use the Master/Slave jumper settings.
    -48-10s.jpg -- (Click to expand) Jumper settings for Seagate ATA drives
    -48-11s.jpg -- (Click to expand) Jumper settings for Maxtor-brand ATA drives
    When using Cable Select jumper settings on your ATA drive, all devices connected to the UDMA cable must also use the Cable Select setting. The cable decides master/slave device detection when the cable select jumper settings are used.
  • SeaTools for DOS (see the tutorial here) to test the drive. If SeaTools does not detect the drive after the steps followed above, or an error code that signifies drive failure displays, please proceed to the our Warranty Services page to begin a warranty replacement order.
  • The BIOS does not detect or recognize the ATA SATA hard drive
    May 08, 2014 | ASUS K8V-MX Motherboard
    What are the correct connections for harddrive to motherboard??? on a Acer am5100-U5301A AMD Athlon 64x2 dual core. can't find connection diagram
    It depends. Some (older) disk-drives use "IDE" (also called "parallel-ATA") 40-pin connectors.
    Some (newer) disk-drives use "SATA" (also called "serial-ATA") connectors.
    So, look on the motherboard for "IDE1" and "IDE2" ports, and/or for "SATA1/SATA2/SATA3/SATA4" ports.
    Mar 18, 2011 | Acer Computers & Internet
    Need location of HDD ATA connectors and jumpers on motherboard
    You need to look at the motherboard to find the pins that fit the hard drive ribbon cable. Then plug your cable into the motherboard and the hard drive. Nowadays, motherboards do not have jumpers for hard drive function.
    If you have a really new motherboard, you may not nave any ATA connectors at all. New motherboards are going to SATA.
    Sep 12, 2010 | Computers & Internet
    How do i configure this hard drive for a 'slave' ?
    Hello
    Ok, you ill be able to see the jumper configuration on the hard drive itself. Here is an example on what the jumper diagram will look like on a hard drive.
    Now, all you need to do is to have a look on your hard dive and see where you need to place the jumper for the slave configuration. Here is what a jumper looks like.
    After you have done this, you only need to plug the hard drive into your pc.
    Hope this can be of help.
    Kind regards
    Aug 13, 2010 | Quantum Fireball 15 GB ATA-66 Hard Drive
    Msi pm8m3-vh motherboard need to reset bios as comp will not start up
    On almost every motherboard, there is a small jumper setting (3 prongs) with a *small yellow* jumper connecting two of the prongs. It is generally near the "chipset" heatsink, nearby the ATA/SATA cable connectors for the Hard Drive(s). Yours may be near the "bottom" of the RAM slots.
    If you turn off the computer, turn off the power, unplug the computer, and move the small yellow (sometimes white, but almost always yellow) switch from the two jumpers it's on to connect the middle to the opposite one.
    If the jumper is on the left two, move it to the right two. This will include the middle jumper prong.
    Leave it that way for 15-30 seconds, and you should reset your BIOS settings.
    If that doesnt work, unplug everything and pull the small, quarter sized battery out of the motherboard (directly next to the ATA connectors. (It looks like a large watch battery. You will need a tweezer or small plastic wedge of some sort to move the battery holder out of the way to get it out. It's easier than it sounds, trust me.
    If neither of those work...I'd suggest a new motherboard, because both of those methods are supposed to reset the BIOS. Hope it helps!
    Sep 15, 2009 | MSI PM8M-V Motherboard
    I don't have the manual for 277498-011
    As for the Power Supply 99% sure it is an ATX which as long as you get the same Watt as the existing you will be okay. Make sure you look at your existing connectors to see if you have a 24 pin or 20pin motherboard and 4 pin or 8 pin additional power plug (black and yellow wires) and the new power supply has matching connectors....older ATX supplies have only 20 pins, but there are converters from 20 to 24 pin available.
    Watch for the new power supplies and your drive connectors as some of the new power supplies have limited ATA plugs...if you have a lot of ATA devices you might need SATA power convertor plugs or ATA splitters to get all you ATA devices up.
    Sep 11, 2009 | Compaq ( 277498-001) Motherboard
    Need wiring diagram for eMachine 20030812 motherboard!!!
    You should be able to see the words/letters that go with the jumpers on the motherboard itself. look around the jumper settings area for power, pwr etc. and match them up with your jumpers which should have what the go to on them.
    Apr 10, 2009 | E-Machines eMachines Refurbished EMA...
    Jumper placement on motherboard
    Here this website has documented the jumper settings for your model motherboard with detailed pictures to go to
    http://support.gateway.com/s/MOTHERBD/INTEL/m00061/M0006126.shtml
    Goodluck
    Please Dont Forget To Rate, Thanks :D
    Aug 26, 2008 | Gateway (4000444) Motherboard
    Intel D101GGC Motherboard Logo
    238 people viewed this question
    Top Intel Computers & Internet Experts
    Tony
    David
    David
    vsri9
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
