Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Refrigerator Water Leak from opening under Freezer
Hi, we have a Kenmore Coldspot Top Freezer refrigerator, model# 72852101. It has been leaking water from the two openings under the freezer for a while. The freezer is working fine, but now the refrigerator is no longer cold nor cooling. How expensive is to repair this? Sears wants to sell me a $250 warranty for a year to include fixing it. Or I can do the $65 dollar estimate then parts and labor fees. Is this problem an easy fix for a regular repair guy? Is it under $250? Close to $250? Is it time for a new fridge? Its only 6 years old. Is this something I can fix? I really just want to make the right choice once given some fair solutions. I appreciate any and all information.
Thanks In Advance
  • Anonymous May 15, 2008
    same problem, same fridge. lookin for fix info from you guys.
  • Anonymous Jul 08, 2008
    Same product and EXACT same problem (water is running out of the styrofoam covered holes located between the freezer compartment and the refrigerator.) The fridge and freezer still work okay....but I expect they may stop working at any moment due to the increasing problem w/ the leak!
    Scholar:
  • 150 Answers
Easy fix my man. couple of possibilities: 1) the fresh food gets cold air from the freezer via the vents where the water has been coming out. the water has frozen up in the vents and is blocking the airflow. the reason the water was coming out in the first place is a slow drain. open up the evaporator cover inside the freezer. get all the ice out of there and clear the drain. a little bleach will kill the gunk that made the drain flow slowly.
2) you have a defrost issue and the coil is loaded up with frost causing no airflow to the fresh food section. check the defrost heater limit and timer. none of these repairs should be over 150. but thats in lawton ok. if you live in L.A. or NYC get the wty.
Posted on May 07, 2008
    Genius:
  • 1,073 Answers
Also get the warranty for sears knows that some of these drain tubes on the ref were not formed correcty and are colapsing, inside the body of the machine, with the warranty if they can not fix it they have to replace it
I have a Kenmore Coldspot Model 106.70182000 that is leaking water from the freezer into the refrigerator. Any ideas? Thanks!
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain, then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps you to stop that leak,
Gene
Aug 08, 2011 | Refrigerators
Water is leaking into teferagerator, seemingly from the freezer compartment. It is a Kenmore Coldspot model 106.72132101 type 21 TFA.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
Good luck
I hope this helps
Gene
Aug 01, 2011 | Kenmore 61282 / 61284 / 61289 Top Freezer...
I have a Kenmore Coldspot ref, model # 78862898. The freezer literally has icicles hanging from the roof of the freezer, frost on food items. The ref isn't as cold as it should be with water...
Sound allot like there is a serious air leak....Is the door sealed good? You also have a defrost drain line plugged up behind the freezer panel you will need to clear that out with hot water after removing all the ice. watch this video to see how to replace the defrost thermosthttp://www.youtube.com/watch?v=z-h541_14ZE
May 26, 2011 | Kenmore Top Freezer Refrigerator
Kenmore coldspot model 106: top freezer leaks water slowly into botton refrigerator. how do I repair it?
Have you tried adjusting the freezer temperature to a higher level? This worked for my Kenmore. It will take a couple of days to quit leaking.
Dec 19, 2010 | Kenmore Refrigerators
My kenmore coldspot 72852101 refrigerator not working but freezer seems to be working
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 21, 2010 | Kenmore 64802 Top Freezer Refrigerator
We have a 10 year old Kenmore Coldspot Refrigerator (it looks like model # 590 9990). It is leaking water from the freezer door. We turned off the ice maker to see if that would stop the leak but so far-...
look for all/any drain holes and blow out/syringe with clorine bleach ,then check door seals for any air leaks.water in fridge is mainly condensation from warm food/replacement air when you open door.
Jul 02, 2010 | Refrigerators
Kenmore elite refrigerator door leak
your drain in the bottom of freezer is clogged or frozen,use a hanger or if it is frozen use a hair dryer,thanks-mike
Oct 19, 2007 | Kenmore 57029 Side by Side Refrigerator
Water Leak
do you have a water dispensor?? is there ice in the bottom of the freezer??
Oct 02, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
963 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
