Question about Dell Inspiron 6000 Notebook
My Dell Laptop syas that my battery is charged. But when I remove the ac power cord the computer immediately shuts down.
  • 734 Answers
I repair laptops professionally and work on many Dells. Here are the possibilities.
1. The plugin connection where the battery meets the charging contacts in its bay where it seats are malfucntioning and the software is reading it incorrectly. To see if this is so, push the small round black button on the battery next to the 5 little dots at one end. If none of those dots light up green, the battery has no charge and the connection I spoke of above is damaged or malfunctioning beyond where you can see. If all the dots light up green, the battery is likely fine but the laptop can;t connect to its charge at the plugin.
2. The basic software (BIOS) is reading the charger/adapter incorrectly and although saying it is charging or charged, the actual charger is ruined inside in the compartment for charging the battery. Dell chargers can actually be incapable of charging the battery but still run the computer on direct current while plugged in.
3. The battery is no longer able to be charged, but is giving a false reading.
4. The DC Power Jack (into which you plug the charger) is only partially damaged and while able to power the laptop directky, cannot charge the battery. (Check to see if it is loose and woobly when you plug in the charger.
The easiest and least expensive way to troubleshoot and fix this yourself is to start with the charger. They can be had on eBay for about $20. Keep in mind that if no green lights show up on the battery, it might be your first choice and it's about the same price.
I hope I've given you enough info the help you determine your true problem.
Regards,
The Selkie
Posted on Aug 29, 2010
Power schemes battery
Chances are that your battery doesn't / wouldn't hold a charge anymore. The laptop runs off battery power. When it is plugged in, the AC power "goes right through the battery", to support the laptop's operations. When the power cord is unplugged, and the battery doesn't hold a charge, the laptop will shut down, as your battery is (too) low to continue supporting the laptop's operations.
The easiest way around this problem is to get a new battery for the laptop.
If your battery is (quite) new (and a Lithium battery), you may wish to see if you can "revive" the battery's "life" ... first by depleting the battery (completely), then charging it (until it shows it is full, plus a couple more hours), and repeating this process a few times. If you're lucky, the battery will slowly/gradually start to hold some charge, but, don't expect it to be very long.
The (preferred) way to use re-chargeable batteries is to charge it fully, unplug it from the external power source, use it until it is depleted, then plug in the external power source to charge it up (fully) again .... and NOT to keep it on a power source all the time.
Oct 26, 2013 | Lenovo G500 59373039 Intel Core i5-3230M...
Laptop Power Up Problem
Try booting under AC power with the battery removed.
Jun 05, 2008 | Gateway 400SD4 Notebook
Tip
How to solve the "Battery Plugged in not charging"
Battery Plugged in not charging and not detected solution I have a Dell Vostro 1510 laptop, and when i have the battery charger plugged in, the battery icon says "10% available (plugged in, not charging)", and if i pull out the cord, the laptop shuts down straight away. Can this be fixed, and if so, how? I bought this laptop new around 6 months ago. The detail info below:
plugged-in-not-charging.jpg The Battery didn't charge or detect being plugged in also caused by four reasons:
  • 1. The laptop battery failed
  • 2. The Adapter failed (can not charge the battery)
  • 3. The motherboard charging electric circuit failed (many caused by short damage). You can view more info here: Dell Motherboard Problem
  • 4. The laptop bios is too old to recognize the battery
After I checked my battery and adapter and confirm they are good. Then I try to repair it by myself.. My Latitude E6400 battery was fixed by myself.
The first solution :I search in the google: Repairman from another site suggested that while the computer is on and plugged in, to unplug the adapter and then plug it back in again. To check the computer can started charging.
So I remove the laptop battery from the laptop and left the AC cord connected, booting it up on the power cord alone until I was able to boot into Windows 7, at which point I then put the laptop battery back into the computer while it was still on. This worked and while a tad unsafe for most people, I wouldn’t recommend you use this idea unless you absolutely had to, that is, if there was no other choice.
The Second Solution: You can download the newest BIOS from dell.com and then flash the bios. But I do not want to update Bios, So I use another way to make the Power manager system to recognize my battery :)
I open up my laptop Device Manager (usually a right click on your Computer/My Computer) and remove all Dell inspiron 6400 battery related devices from the Device Manager. Then after you’ve done that, right click again and select “Scan for Changes”, which should reinstall the proper services and allow for your laptop to charge again. See the more info in the image below.
remove-battery.png If this also can not solve the problem, I suggest you send the laptop to Dell to repair the Laptop motherboard.
The article Via laptop battery blog
on May 27, 2010 | Computers & Internet
My laptop is not charging. i plug the power in but still doenst charge. im not sure if its on the power cords or on the laptop please help asap i need my laptop for school :(
Does the laptop work on AC ? Is the battery or cord/charged a replacement? First, try another cord/charger of the EXACT same specs as original. Second, Is the battery good? How old? Over 4 years? Have it tested. Beware of inexpensive aftermarket batteries and cord/chargers. I assume the laptop works on AC? If you unplug the AC , with battery in, the laptop shuts down immediately?
Nov 26, 2012 | Lenovo IdeaPad Y450 Notebook
New battery HP g61 is fully charged but not working \
Maybe the AC Adapter Power Cord is not working. If you can't get on the laptop with the power cord then it is bad and the battery might be drained so you have no power source to power up the laptop.
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 30, 2012 | HEWLETT-PACKARD HP G61A50US 156 AMD Athlon...
Its that the battery is not charging, and on the power meter icon its blinking four times orange and one time green. If I remove the battery, the laptop works with ac adapter. but if I reinstall the...
Check for a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Feb 06, 2011 | Dell Latitude D610 Notebook
I have dell c840. Suddenly only the left most light of the three lights gets orange when power is switched on and then there is no activity and screen remains blank. Bty light when plugged in also remain...
hello
shut down computer - unplug power cord from laptop - remove the battery from laptop - plug Ac adapter into computer and Ac outlet (wall)
turn on computer
if computer does not turn on, replace the AC adapter and cord - then place battery back into computer
plug in new Ac adapter and cord - recharge battery - if orange light stays on after 4-6 hours of charging battery, you need new battery as well - replace battery, charge it up and it should be fine
if you have attempted these steps before and no change occurs, then you may have issue with power connection in computer - locate a service centre to replace power connection on computer
Nov 07, 2010 | Dell Computers & Internet
Dell Inspiron 6000 laptop periodically shuts OFF
You've checked the p/s and it has volts out. Try removing the battery and running the laptop just on the p/s. If it works like this the battery is dead. Otherwise the laptop has a problem.
If the battery is dead, buy a new battery or run it on p/s alone. Laptops should be run on battery alone as much as possible, or the battery dies.
Apr 04, 2010 | Dell Inspiron 6000 Notebook
Got a new battery for Dell Inspiron 6400 but it won't charge
well if it's a new battery and you're having issues send it back, you may need to calibrate your new battery with the laptop
Nov 06, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron Laptop powers off by itself.
This could be a couple of issues. One, the computer could be over heating and shutting down. Ask her if her laptop was warm and if the fan was constantly running. The second possiblity is the cord that plugs into the laptop has become loose and once wiggled will cause it to turn off because the battery doesn't hold a charge. Have her put the laptop on the table and with the computer running wiggle the cable. If it shuts down its a bad connector. In this case find someone with mad soldering skills and re-solder the connector on the motherboard.
Armymason
If this sounds like a good solution a high score is appreciated.
Apr 01, 2009 | Dell Inspiron 2200 Notebook
Dell Inspiron 6000 Notebook Logo
93 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
