Question about Hampton Bay 24002 Ceiling Fan
I have two fans in separate rooms but the remote works both fans at the same time.
  • 377 Answers
There should be a set of very small switches that will change the code for each fan. Seems they must both be set to the same code. Re-set one controller and fan for one code and leave the other alone. Very small switches.
Posted on Aug 29, 2010
How can the remotes be set to separately control 2 fans in the same room?
Most have four dip switches in the transmitter & receiver. You need to match-up the dips in both for one fan. The dip switches in the transmitter are in the battery compartment.
Oct 05, 2015 | Dryers
Missing remotes for hampton bay ceiling fans
https://www.google.com/search?q=remotes+for+hampton+bay+ceiling+fans&rlz=1C1PQHB_enUS689US689&espv=2&biw=1536&bih=748&source=univ&tbm=shop&tbo=u&sa=X&ved=0ahUKEwik3qiMx4bTAhXh5oMKHV3vDJ4QsxgIGg
Apr 02, 2017 | Hampton Bay 52 In. White Redington...
We install 2 fans in differents rooms, after a few
There is a small opening on the top of the fan with four small (DIP style) switches. In order for the remote to work, both the fan and remote must have the same combination in the switches. Remove the battery cover from the remote to have access to the switches, then using a small tool (a ball point pen will work just fine) set the switches to the same combination both in the remote and the fan. For example: If you set the remote to: off, off, on, on; then the fan should also be: off, off, on, on. You can set the remote for the other room with a different combination as to avoid any interference between the two. Please rate this solution if it was helpful. Good luck and thanks for using Fixya!
Nov 02, 2009 | Hampton Bay 24002 Ceiling Fan
4 ceiling fans functioning intermittantly
Either that or there is some kind of RFI (Radio Frequency Interference) coming from somewhere in the house or maybe from outside.
Have you installed new cordless phones, two way radios, remote controlled devices, wireless internet access, wireless intercoms, garage openers or something that emits some kind of radio signal?
Have your next door neighbor? (If he lives close enough) Good luck!
Oct 25, 2009 | Dryers
Need manual to program remote to a different frequency
Each fan with have a receiver unit mounted in the housing, usually above the fan up against the ceiling. Each receiver unit will have 4 "dip pins" which allow the code to the remote to be set. In order for two fans originally installed with the same code to be run separately, one fan will have to be taken down, and the code changed on the receiver unit. Then you will have to purchase a new remote and set the same code on its dip pins (usually under the battery.) It's easiest to buy a replacement remote WITH a receiver AND a transmitter in it. You can either wire in the new receiver (setting the code differently than the existing one on BOTH the receiver AND the transmitter) OR just put the receiver aside and program the new code that you've set in the old one into the transmitter.
Apr 25, 2009 | Universal Remote Control Hampton Bay...
Reiker ''room conditioner'' heater stopped working
i have of course the same problem......5 times now in 3 years.
i have discovered that for some reason if i disconnect the fan and put it back up it works again for another 8 months or so.
Nov 16, 2008 | Reiker Room Conditioner Ceiling Fan with...
Fan is Erratic
Ceiling fans with wireless remote controls have an electronic receiver installed in the fan, which controls the light, dimming, and fan speed. Sometimes the receiver goes bad and needs to be replaced. If you have had any power outages or power surges, they may have fried the receiver. I've noticed that my ceiling fan light turns on when the power is restored after a power outage. Now, whenever my power goes out, I shut off the light switch that powers my ceiling fan so It doesn't experience a surge to to the controller when the power comes back on. I've purchased new receivers on eBay and Amazon to replace my blown remotes and receivers.
Sep 07, 2008 | Hunter 22451 The Brookline Brushed Nickel...
Remote calibration
I installed three fans in the same room and one remote ran all three. In order to get the dimmers all to bring the lights up and down together, I changed the dip-switches in the fan housing so that the remote would only work one fan at a time. I then brought the dimmer lights all the way to bright. After all the lights were equally bright, I again altered the dip-switches so that all three and the remote were identical. The remote then dimmed all three lights equally.
Jun 16, 2007 | Hampton Bay AC438-VPW 52'' Vintage Pewter...
Hampton Bay 24002 Ceiling Fan Logo
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
