Question about GE WCVH6260FWW
With 1 minute to go, the washer stopped and door locked light came on. Wet clothes are in machine and we cannot get door open.
  • GE Master
  • 8,220 Answers
To me that sounds like a suds problem. I have a service manual for you HERE
Posted on Aug 29, 2010
    Champion:
  • 274 Answers
Your going to love this, your pump is blocked due to hair or dog hair.so first cancel load now turn knob and change to a quick wash now unplug wait ten-seconds and the door lock well shut off,get a bucket (told you would love this) wring out and put clothes in bucket,now scoop out water and put draino-max gel about a third of the bottle and let it sit over nite,now run washer on Heavy-Duty load Hot water,it may take a few times,(are washer does the same and this works. and then do a quick wash(no clothes) then you can do wash again
Washer will not turn on.
If the Add A Garment light is on, try this: the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point.
May 21, 2013 | Washing Machines
I have a maytag centennial washer MVWC400XWO it is 3 years old. The washer has stopped after the initial wash cycle leaving the cloths wet in a tub full of water. The washer will not go to the spin/drain...
For saftey the lid lock and lid down switch must be activated before the machine can advance to the next cycle. This has been the sequence for all top loaders..
Check the switch for the lid it is likely defective.
Make sure that the power is removed.
Simple repair by a qualified technician.
Hope this helps?
Jun 14, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Making humming noise power not on door locked
turn off the unit.use a wet dry shop vac and attach it to the end of the drain hose this will remove all the water then you can turn it back on and should be able to open the door to get your clothes out.
after all thatis done you need to check the drain pump and make sure there is nothing blocking the pump.other likely problems are the door lock mechanism is bad or the main control board
Jul 05, 2010 | GE Energy Star WCVH6260F Front Load Washer
Maytag neptune washer clothes staying wet after cycle
Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
Wont start (door lock light not on) & stops 10 min into cycle
Sounds like the door micro switch is out. You can check this by opening the door & pressing in switch lever with your finger should feel a clicking almost like popping a knuckle on your finger no clicking switch is bad. If switch is bad you will need to have it replaced. You could bypass switch but with all electrical parts it could be dangerous if you do not know what your doing. Switch $2.00 to $13.00 Labor is where they get you.
Mar 08, 2009 | Washing Machines
Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Maytag Neptune Front Loader Washer
Sounds like the door lock unit isn't locking and may be bad. It is also a possiblity but not likely that there could be a problem with the computer board but start with the door lock unit first
Dec 29, 2008 | Maytag Neptune Washer
Bosch Nexxt Essence Washer
start a cycle, once the door lock light comes on pull on the door to see if its really locked if not, you need a new door lock assembly
Nov 12, 2007 | Bosch WFMC2100UC Nexxt Essence Washer
GE WCVH6260FWW Logo
536 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
