Question about Maax Calla 6042 Bathtub - 101058-000
Our Max jetted tub won't turn on. Our house is new construction and the tub has never been used. I checked the breaker. I've been reading about this EO6 sensor...but I have no idea where it is or what it does. I filled the tub just above the jet holes thinking that would be enough water. Confused
    New Friend:
The on off switch is air operated via a tube that puts air pressure from the push button to the electric motor switch. It was pulled off on my Maax tub . Just push the hose back on both ends. Push button on upper end and motor switch on pump motor.
Posted on Feb 24, 2015
    Champion:
  • 274 Answers
See if ther is another panel arond tub,there may be another breaker,try resetting breakers turn off the back on,see if this works
Posted on Aug 29, 2010
Hot ub heats up then heater stops working i think when i turn on the jets
your heater works when it has to with or without jets on. you won't be able to feel the temp difference on your skin because it has a very small heater coil versus 210 gallons of water. As long as the spa maintains the set temp, it's working fine. maybe your set program for the spa isn't set to your needs. check your manuel for setup and make sure your not in vacation mode, thst will drop the water temp by 20 degrees.
Jul 20, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
Why wont hot tub heat with jets on losing temperature on 110 volt
My first question would be about the outside temperature. What is the outside temperature?
Hot tubs that are designed to operate on 115v only have 1.5kw heaters and if the outside temperature is below 50 deg F they tend to not keep up to 103 deg water while being used. They are also designed to not heat while the high speed pump is operating.
Does it stay up to temperature on a normal basis?
ROD
US Parts Center
Jun 08, 2014 | Qca Spas Dream Series Dream Master Hot Tub...
Jets not working
Check your breaker in the breaker box. Is this an air tub or a water tub?
Nov 10, 2013 | Neptune Home
MY JETS WONT TURN ON
The threaded knob should not be related to the problem, it just controls how much air gets mixed into the water jets. One possibility is that the electricity is off. These tubs should receive power through a Ground Fault Circuit Interrupter (GFCI) type of circuit breaker for your protection from electrical shock. Check your circuit breaker panel(s) for a breaker with a little square white or yellow "test" button. Refer to the label (if it is there) to see if it refers to "tub" or "spa" or "bath" or something like that. You may have to turn the breaker handle off (push extra hard to make it reset) and then back on again. If the breaker handle is in the "on" position and the "test" button does not "trip it off," call an electrician. If no luck there, check the bathroom for an electrical outlet with GFCI protection, again looking for white or yellow (or red) buttons - one should be engraved "test" and the other "reset" as the electrician (I hope it was an electrician) may have supplied the tub from this outlet (not actually up to code). Plug an appliance or light into the outlet. If it doesn't work, push the reset button on the outlet and test again. If working, now test the spa. If that doesn't work, test every other GFCI outlet you can find - in the kitchen, other baths, garage, outdoors, basement, etc. using the same testing procedure. If you find a GFCI breaker or outlet "tripped" that restores the tub, that indicates there is something wrong with your electrical system that could cause you to get electrocuted, and requires that you hire a qualified electrician to investigate the problem. The same is true for any GFCI outlet that does not "trip" and/or "reset." If this doesn't fix the tub, the problem may not be electrical but some other problem with the system, indicating a plumber or spa tech may need to be consulted. Note: these GFCI breakers and outlets are supposed to be tested and reset once every month. How many of us do that? Well, at least as often as we test our smoke detectors, I suppose.
May 20, 2013 | Home
Jandy lx250 won't keep water hot
what size pump motor slow the water down put a bypass in
Feb 27, 2012 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
We bought a house with an Aqua Glass jetted tub. When we tried to turn it on nothing happens. At our inspection in July it was working fine. There is no way to get in to the front of the tub and no box. ...
Get the manual and study how it works. Then with this new knowledge you will have a good idea of just what to look for.
Is power reaching the unit? ON/off switch good? Circuit breaker? Is water reaching the unit/valve shut off?
It has to be something simple.
Sep 09, 2017 | Pool & Spa
I have a whirlpool jacuzzi tub. I wired to diagram but when tub is full and I turn on jets it trips a breaker. Not GFCI outlet but breaker panel breaker.
Sounds like you may not have a ground on the motor of the pump or a grounded outlet?
check the wiring on the motor on the cord to make sure there are no wires improperly attached inside the motor housing.
Jan 07, 2011 | Jacuzzi Amiga, Soaking Bathtub with...
Jets don't work in the jetted tub.
First the obvious, most are electrically connected to a ground fault device, ether an outlet or a breaker. BEFORE ADDING WATER, check these out to make sure they are not tripped. Most all tubs have a minimum water level which must be reached before the jets will operate. This is usually a piece of trim located above the depth of the jets. Make sure the tub is filled to cover this part. If you cant identify the water level device fill the tub so that all the jets are covered by an inch or 2. Some tubs have push button switches or touch pads to control the motor, some have touch sensitive trim. There may be some sort of medallion from the maker on the tub, simply touching it will start the tub. Once you get it going most tubs have a built in timer that turns off the pump in 15 - 20 minutes. For more tub time just hit the switch again but keep in mind that extended exposure in a hot tub can mess with your blood pressure and cause you to loose balance or pass out, hence the 20 minute timer.
Mar 22, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
My Kohler whirlpool started on its own with no water in it. We turned it off with the switch and it hasn't happened again. Is there a danger of it starting a fire if we are away from home and it does it...
Most Kohler tubs have a water sensor or water level sensor. Is this an air bath tub (holes in the floor)? or a jetted tub? If it is an air bath, the tub will purge after using it 15 to 30 minutes ater it is drained. If it is programable it will come on every 24 hours if it has been programmed. If it is a jetted tub, there may have been water on the sensor and caused it to start up. If it is a single on/off button the switch could have gotten water and caused it to start up, or there is a problem with the control box. It usually will not start a fire if it comes on, most of the newer pumps have run dry seals. If you leave the house for vacation or weekends, I would advise unplugging the tub or turning off the breaker.
Aug 28, 2009 | Kohler 1014-H2-96 Portrait 5' Whirlpool...
Maax Calla 6042 Bathtub - 101058-000 Logo
1,596 people viewed this question
Top Maax Home Experts
Mike
Tim Whalen
Tim Hunt
Tim Hunt
Are you a Maax Home Expert? Answer questions, earn points and help others
