Question about Sharp AL-1641CS Color Copier
Ar5316 how do you reset the drum counter? i see the service codes and sub codes...but where/how do you enter that?
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
Main code Start key Sub code Start key
Posted on May 28, 2008
How to reset Toshiba Studio 256se Total Counter?
Clearing counter
The counter indicating "current number of prints and driving time" used for the PM display function is
reset by entering "0" in it or clearing it in the PM support mode.
Notes:
Even if "0" is entered in the PM management setting value of the setting mode (08), the
corresponding counter for the PM display is not reset. Be sure to clear the counter in the PM
support mode when the maintenance is finished.
The reset condition of each counter is as follows:
• 08-6194: Current value of PM counter [process unit (K)]
• 08-6195: Current value of PM time counter [process unit (K)]
When the current value of "CLEANER/DRUM" on the main screen or "DRUM" on the sub-screen in
the PM support mode is cleared, the counter is reset.
• 08-5568: Current value of PM time counter [developer material (K)]
• 08-5569: Current value of PM time counter [developer material (K)]
When the current value of "DEVELOPER" on the main screen or "DEVELOPER" on the sub-screen
in the PM support mode is cleared, the counter is reset.
• 08-5576: Current value of PM counter [parts other than the PM parts of the process unit]
• 08-5577: Current value of PM time counter [parts other than the PM parts of the process unit]
• 08-6225: Number of output pages (Thick paper 1)
• 08-6226: Number of output pages (Thick paper 2)
• 08-6227: Number of output pages (Thick paper 3)
• 08-6228: Number of output pages (OHP film)
• 08-6244: Counter for tab paper
• 08-6247: Counter for envelope
When the current value of "FUSER" on the main screen or "FUSER ROLLER" on the sub screen in
Notes:
The following counters are cleared by executing the EPU replacement mode.
08-5568: Current value of PM counter [developer material (K)]
Jun 14, 2016 | Toshiba Office Equipment & Supplies
Sharp MX-3100; what does DK mean
h r u . DK MEANS black drum life is over need to replace black drum unit or Reset black drum unit counter.
To clear this you need to clear this easy you want
# , * , c , *
To enter service mode
Type in code 24 press start
Then you want sub code07
Then you can select what you want to clear so the bk drum unit
Feb 26, 2015 | SHARP MX-3100N
I REPAIR THE MACHINES IN AFRICA SO I NI THE ERROR RESET CODES
Usual "reset" codes:
14 - Trouble cancel (except for U2)
16 - U2 trouble cancel
20 - 01 Maintenance counter clear
24 -01 Jam total counter clear
02 Trouble memory clear
04 SPF counter clear
06 Paper feed counter clear
07 Drum counter clear
08 Copy counter clear
09 Printer counter clear
13 Scanner counter clear
14 SPF jam total counter clear
42 01 Developing counter clear
There are codes and subcodes.
example if yiu want to clear the maintenance counter , you have to enter simulation mode and then enter 20 / Copy key /01 /copy key.
I hope it helps you.
regards,
Adi
Nov 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
I just replaced all the moving parts in my Sharp AR-M620 copier including the finisher and drum etc...I have the service codes and sub codes to reset the print counters, drums, developers etc but don't...
* Entering the simulation mode
1) Copy mode key ON ? Program key ON ? Asterisk (*) key ON ?
CLEAR key ON ? Asterisk (*) key ON ? Ready for input of a main
code of simulation
2) Entering a main code with the 10-key ? START key ON
3) Entering a sub code with the 10-key ? START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected item.
Press START key or EXECUTE key to start the simulation opera-
tion.
To cancel the current simulation mode or to change the main code
and the sub code, press the user setup key.
* Canceling the simulation mode to return to the normal mode
1) Press CA key.
Sep 06, 2010 | Sharp AR-M620N Copier
Sharp AR-M160 Maintenance light and developer replacement light have come on together. Where do I get developer from?
It's not developer light.
It is drum unit light and maintenance.
You have to replace the Drum, Blade and Developer.
After changing them you have to reset the maintenance, drum,developer counter.
This procedure must be made by a copier tech.
But if you still want only the developer the code is AR-202D
Dec 12, 2009 | Sharp AR-M160 Laser Printer
SHARP AR 5012 developer reset
i have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
Jun 25, 2009 | Sharp AR-5320 Black and White Copier
Error F 2 (Blinking mode) appears in Display of Sharp AR5316,
Hello sir; F2 have a sub code, press print key to read the sub code, if the sub code is 04,then it means wrong cartridge,wrong country, you can try to reset it;
1, press "#", "interrupt", "c", "interrupt" keys.
2, enter 14 press start.
3, if it work, don't forget give me a good rating.
Feb 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Copier drum reset code
Hello sir; The simulation code for reset drum counter at this model is # 20 sub code07 if need more help let me know.
Jan 03, 2009 | Office Equipment & Supplies
Service mode
Hello:
All I have access to is the Toshiba Version of your machine but I think maintenance mode is the same.
This is the excerpt from the relative info in the service manual.
Example:
Basically you press # * c * ( to get into maint. mode
Press 20 Start 01 start (then the maintenance counter will clear)
I hope you can figure it out
The drum and dev counts are below
To enter the serviceman test command mode, press the keys as follows:
[#] key [*] key [C] key [*] key
To cancel the test command mode, press the [CA] key.
[10KEY]:(number pad) Entry of MAIN CODE/SUB CODE
Selection of an item
Setup of an adjustment value in case of test commands for adjustment
[/]: Selection of MAIN CODE/SUB CODE
[OK (ENTER)/START]: Settlement
<In case of test commands for print>
[OK (ENTER)]: Settlement (Without print)
[START]: Settlement/Print
[C]: (Interrupting operation check) Returns to the upper hierarchy.
In case of test command of operation check, terminates the operations.
[CA]: Exits from the test command mode.
For a test command of adjustment, the display returns to the initial display (00-00).
20 01 Maintenance counter clear (M-CNT CLR.)
24 06 Developer counter clear (DVLP CLR.)
24 07 Drum counter clear (DRUM CLR.)
Mar 12, 2008 | Sharp AR-168D Copier
Error code
Hi Sorry cant send manual U have to buy like every one else.But here are the codes you require It is service code 24 sub code 04 to reset PM counter and sub code 07 to rest drum sub code 09 to reset print count and sub code 11 to reset developer. Hope this helps
Aug 18, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AL-1641CS Color Copier Logo
207 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
