Question about Dell Inspiron 8200 Notebook
Not Starting Still
Thanks,
Do you mean no battery and just AC adapter? So Yes I have tried it but no luck. Or did you mean something else?
  • 1 more comment
  • DocJB May 07, 2008
    Thanks,
    Any easy and inexpensive solutions to this motherboard problem?
    Thanks,
    I will have to find some one to help me with it as my skills in the computer world are as good as being none.
    Thanks for all your help.
    Genius:
  • 3,587 Answers
That's what I meant...ok..then methinks you are working with a truly unhappy motherboard where the dc charger circuit resides..
Posted on May 07, 2008
  • Patrick Michaels
    Patrick Michaels May 07, 2008
    nope..it's more like 150 to 200 for the board..and 2 hours or so for install, if you want someone to do it.
Toshiba Satellite won't start up when AC plugged in
Try another Cord/Charger to verify the Cord, AC jack. If you plug in the AC cord after starting on battery, does the battery charge? Open Control Panel, Power Options, set to High Performance, Advanced power settings, set Sleep and Hibernate to Never, Adjust Advanced power setting to your preference.
Feb 06, 2013 | Toshiba Satellite L300D-ST3501 Notebook
Will only charge for about 5 seconds
Try another battery if possible in the laptop. If it charges up the battery the whole way then that means your original battery is bad. If you still can't charge another battery for more then 5 seconds then that means the adapter is bad. If you get another adapter and still can't charge, then the motherboard is starting to go bad at that point.
May 14, 2011 | Lifetime Toshiba Satellite A205S5000...
It wont charge my netbook
Is your ac adapter or charger detected?
If YES, and it doesn't charge the battery, but it turns ON the laptop it means that the battery is the one not holding a charge.
If NO. Try to change the power cord that goes to the wall (that part is detachable) with good known power cord. If it does the same then definitely there's a problem with the ac adapter.
If the computer powers ON, both ac adapter and battery are detected but no display, then the problem is the system board.
Hope it works.
Mar 15, 2011 | Computers & Internet
Dell c640 laptop when not power on when using ac
The battery has a dry cell causing this so replace the battery
Jun 20, 2010 | Dell Latitude C640 Notebook
My DELL Inspiron 640m battery does not charge
Try the following method:
1. Remove the battery from your laptop and plug-in the AC Adapter. Check if it is working.
If not - The AC Adapter is not working properly
If Yes - The battery is the problem. Change the battery
You can visit DELL website:
http://accessories.us.dell.com/sna/batteryconfig.aspx?c=us&l=en&s=bsd&cs=04
Thanks. Please rate. God bless!
Let me know if you need further assistance.
Apr 22, 2010 | Dell Inspiron 6400 Notebook
Battery indicator light on, but the actuall computer will not come on; What do I do?
Try the following steps:
1. First remove the battery from your LAPTOP and plug in the AC Adapter. Turn ON the Laptop without the battery. Check if it is Working:
If Yes - You need to change your BATTERY
If No - Try checking your AC Adapter
2. The AC Adapter has LED indicator which will light up if it is plug-in to a power source (outlet) Check if it is lighted:
If Yes - AC adapter functions properly
If No - Try replacing your AC Adapter
3. If the problem still persist you might have an a following hardware failure on the following component:
a. RAM - Memory errors - replace with same Memory SPEED or type
b. Motherboard defective - you need to replace your motherboard with a new one.
Please Rate. Thanks. Cheers!
Mar 02, 2010 | Microsoft Compaq Presario C501nr Notebook
Dell Latitude D620 isn't getting power to the mainboard.
diagnostic procedures as follows:
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer operates normally when using AC power, go to step 7. If the computer does not boot when using the AC adapter, see the previous subsection, "Total Power Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Your computer may be in a hot environment. Charging the battery in this condition may affect the life span of the battery.
Yes. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. get a new battery replacement.
No. Call Dell for technical assistance.
if you need Dell latitude d620 Battery you can go to online shop
http://www.global-battery.co.uk
http://www.sales-batteries.com
here you can perchase high quality battery easily
good luck!
Feb 04, 2010 | Dell Latitude D620 Notebook
No power. Adapter light flashes when connected to laptop
thanks for using fixya!!
Please do and observe the following:
1. Uninstall the battery pack.
2. Then, connect the AC adapter, we will try to use the power coming from the AC, then turn on your laptop.
3. Observe what will happen.
4. If still doesn't work, install again the battery, then connect the AC adapter, check if its going to work.
5. If not, perhaps you have a problem neither with the battery or the AC adapter.
I suggest that you bring your laptop to a service center. Good luck!
pls rate me positively! thanks!
Mar 30, 2009 | Acer Aspire 3680 Laptop
Toshiba laptop battery or AC/DC adapter
step 1.First remove the battery out
step 2.Try to plug in the AC/DC adapter and see any Power light or something on your machine. If you have power light on your machine that mean your adaptor is supplying electric.But still there're some adapter that don't really supply a good DC voltage
we need to further check.
step 3: incase no light nothing on your machine you need to use analog meter or digital meter to check that your adapter is giving out DC Volatage around 16-19V
Best of luck, takecare.
Apr 19, 2008 | Toshiba Satellite L25-S119 Notebook
Dell Inspiron 8200 Notebook Logo
21 people viewed this question
Alun Cox
