Question about Amana 24 in. ADB1500AW Built-in Dishwasher
My dishes are not getting clean, especially the glasses in the top rack. They have a gritty substance on them after a wash session. The bottom rack seems to be okay, but the top rack is not clean at all. I've never had any problems with this appliance at all.
  • jmhagan2 Aug 29, 2010
    I haven't tried it, but I am going to get a Finish Dishwashing cleaning kit tomorrow. Thank you! I appreciate your help.
  • Amana Master
  • 3,247 Answers
The problem in the top drawer could be due to a few reasons.
Have you cleaned the wash arm and does it sit in alignment with the hole from which the water comes in.
Try to increase the quantity of detergent and rinse aid to see if there is any difference to the cleaning of the glasses.
You can check if water is getting to the top rack by leaving a container in it to measure the quantity of water at end of wash cycle. The gritty substance is usually the sand in the detergent. It is left behind because there may not be adequate water reaching the top rack.
Once in a few months you should use a Finish Dishwasher cleaning kit and run the empty dishwasher with it according to the instructions on the kit.
Hope this will help solve the problem.
Posted on Aug 29, 2010
  • Sam Aug 29, 2010
    Also check the top washer arm and if the water is getting to it.
Dishes on top shelf not getting clean
Check your upper wash arm.... check the holes, especially the ones at the end of the arm. Are they possibly clogged with debris or hard water? This is the usual cause of dishes on the top rack not getting clean. The holes at the end of the wash arm are angled to eject the water at an angle to use the reaction to push the wash arm around. If those holes are clogged, then the arm won't rotate, and only those few dishes or glasses right under the arm will get clean, and the remaining 80% of the dishes on the upper rack won't get clean!
Sep 13, 2014 | GE Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Top rack dishes have a white gritty residue on them. i use washer cleaner and jet dry and it does not help. i don't know if there is filter to clean or not . what do i do?
Check whether the top rackspray arm is moving freely. Check the jet holes and remove clogs if any.
Hope the bottom rack is good in wash quality!
Apr 12, 2010 | KitchenAid 24 in. KUDG25SH Built-in...
Dishes, glasses on the top rack dont get cleaned. The bottom rack is fine. What may be the problem?
Probably a blocked spray arm. Remove the top spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Jan 25, 2010 | KitchenAid 24 in. KUDS25 Built-in...
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
Dishwasher not cleaning dishes
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 24, 2009 | Kenmore 24 in. 17462 / 17464 / 17469...
Dishwasher
Make sure not to prewash your dishes before you put them in the machine. The water needs to be dirty to activate the enzymes in the detergent. Are the dishes coming out cloudy? Also a sign of prewashing your dishes. Use only powder detergent and clean your machine by running 2 cups of vinegar on hottest cycle once a month. No gel and no tabs. They cause a build up in the unit and causes poor performance. Use rinse aid. Hope this helps.
Mar 29, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag Quiet Series 300/Dishwasher leaving gritty stuff on dishes
My model is simillar Cheri's. Every couple years I have to remove the plastic spray bars. They are held on by a simple torque screw. Once removed you will see debris plugging many of the holes. I have found this on all 4 of my spray bars. This debris prevents the right amount of water in the wash and rinse cycles. The upper spray bars seem to be the worse. This explains the trouble most folks have with glasses in the upper rack. Also check the docking station. You will fiind it along the back wall of your unit. The plastic tubes on the backside of each rack will slide into a hole in the docking station. After a few years the rubber seal in the docking station will be worn away. Once this happens, it prevents the correct water pressure to the upper rack. The replacement part snaps into place and cost about $25.
Jan 19, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Dishes aren't getting clean, especially glasses on the top rack
check chopper remove bottom spray arm remove 4 screws take of cover then 2 more screws and the chopper is there.probably broken
Nov 21, 2008 | Kenmore Dishwashers
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Amana 24 in. ADB1500AW Built-in Dishwasher Logo
672 people viewed this question
Top Amana Dishwashers Experts
Oloyede Monsuru
Kolbrun...
Mike
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
