Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
My craftsman tractor model # 917.259556 ,hydro gear transaxle model #310-0650 has a worsening problem loosing drive power, I had removed the transaxle and left it upsidedown for several days to drain and refilled it with the correct amount of required oil and reinstalled it on the tractor , I purged it as described in owners manual more than 5 times , it worked somewhat better for a while but now we have to push it up hills and reverse barely works, I double checked brake adj. & fluid level-ok. the internal parts are expensive, if i pull it apart will i find it to be excessivly worn and lots of metal filings, or could it be carefully cleaned and filter cleaned or replaced. Has any one had any luck reparing these with out replacing 100s of dollars on parts. ADAM thanks for the help
  • 2 more comments
  • Adam Harrer Aug 29, 2010
    The engine does not lack power.
    would disassembly and manual cleaning be worth a try.
    what about the filter inside
    thanks for your help , I think I will pull it apart and check the filter and look for the sludge problem you mentioned, do you know if its a washable mesh type screen or paper. Note: This unit has only an internal filter, not a screw on type like conventional auto filters.
  • 2,272 Answers
Yes disassembling the unit and getting filter cleaned should help in this types of problem. And in this type of craftsman tractor there are mostly washable mesh type screen. Keep updated.Thanks.
Posted on Aug 29, 2010
    President:
  • 986 Answers
One thing you can try is to drain your fluid and refill with stp oil treatment,it not a perment fix but it will help you for now,and maybe you can trade,I have had this happen to me and it worked
  • 3,740 Answers
Adam it most likely has some gunk / debris inside of it that is allowing fluids to bypass across rubber surfaces that should be sealed. I have to be honest I have had very little sucess as a tech tearing into one of these. Mainly because the time it takes ends up running up a labor cost more than the replacement unit cost. I always tell the owner that there is a 50 - 50 chance of saving the unit. I have used engine flush in them before and had about a 50% success rate of returning them to service. You fill it about half full install the plug and shake it vigorously. Then drain it and do it again. You keep doing that until you notice that the exiting fluid are free of debris. You can Cheese Cloth the engine flush over a bucket so you can keep using it for cleaning. Just note the cheese cloth will be flammable after your finished and will need to be stored in a covered metal container. I do not recommend using B-12 chemtool as it will cause the seals to harden quickly. Once your sure that the debris is gone.. you have to let it sit upside down for about an hour before refilling and installing the plug for the last time. If after all of this it does not work properly it is your call as to attempt repair or replace the drive. Like I said I have very little success professionally with attempting repair and have been doing lawn equipment service since the very first hydro-static drives became common place.
Thanks for choosing FixYa.
Kelly
  • 2 more comments
  • Kelly
    Kelly Aug 29, 2010
    The debris we are talking about is relatively small in nature but that is all it takes on a hydraulic action type seat to cause it to leak by. I would try the flushing routine that I mentioned before I tore into it as a last resort. You have nothing to lose by taking it apart but if you go the remaufactured replacment route they may ask for your (core) transmission. And a remaufactured unit is just as good as a new one. I am sure you know these rascals (310-0650) run a small fortune to the tune of over $500.00 new.
    I like this parts breakdown because it is in pdf format and you and enlarge it. Nice when it comes to parts searching or oops where does this part go and I do not have the service manual.....
    http://www.mymowerparts.com/pdf/Husqvarn...
    I am not in this for the money. I would rather see your hydrostatic drive working again by sharing my experience and knowledge. I do wish you the best.
    Kelly
  • Kelly
    Kelly Aug 29, 2010
    Here is the service manual that should assist you in finding out what has failed. http://www.mymowerparts.com/pdf/Husqvarn... See section 3
    Kelly
  • Kelly
    Kelly Aug 29, 2010
    Adam the filter maintenance interval is that it should be changed every 200 hours or more often in extreme conditions.
    Since your having problems of course I recommend changing the filter. Note the 5 - 10 psi pressure check in section 3 of the manual page 21 if you have noted leaks. Also note the bypass valve linkage on page 20 which is part of the freewheel control. A sloppy linkage can cause the symptoms your having. You should test that it freewheels when in transport position and locks when transport is deselected.
    I see your question keeps going back to the main questions board. How the site works: Everytime you reject an answer it goes back to the main board. You can just reply vs reject answers. You are not charged unless you accept an answer. (You can respond without accepting) When you reject an answer you will get a different expert answering your question. I don't mind at all. My preference is to get you enough information to so you can get your Hydro Gear functioning properly at the lowest possible cost. I am just explaining how the site works.
    Kelly
  • Kelly
    Kelly Aug 31, 2010
    Adam,
    I have never seen a paper filter as an internal filter so at this point not being the person taking it part I would assume it is a washable mesh filter. We soaked them in solvent. (and engine flush is a good soaking medium) Maybe the book is wrong but it is showing the -0650 drive with an external filter. You said that there was no external filter so evidently the service manual is incorrect as published. As a professional I sure would like to hear about the end result when your finished be it good or bad. I would bet the farm on your finding even more gunk and goo inside the unit. That is why I recommended you use engine flush in an attempt to clean by solvent flushing before tearing into it. I do wish you the best and honestly hope that in the end it works fine.
    Kelly
    Brigadier General:
  • 3,513 Answers
Husqvarna gear oil
I assume you are referring the the transaxle? The replacement oil in the transaxle is as follows: This model ran either a Hydro-Gear or Tuff-Torque transaxle. If Hydro-Gear use: 20W50 synthetic. If Tuff-Torque use: 10W30 synthetic.
Apr 02, 2014 | Husqvarna Lawn Tractor Gth26k54t Owners...
Tansmission oil type for model# 917.254740
Your Craftsman is equipped with a Agri-Fab transaxle, the predecessor to the Hydro-Gear brand. The recommended oil is 10w-30. Unfortunately, the transaxle on your craftsman tractor is not serviceable. It is sealed for life. The only way to change the oil is to remove the unit from the tractor, tip it upside down and drain the oil out the reservoir plug.
Jun 16, 2012 | Craftsman 24 Hp 48" Deck Yard Tractor
Gear shift lever is loose and mower will not move. this is on a craftsman lt1000.
Trace back the linkage from the shift lever to the transaxle to see if the linkage has come apart. If it is a manual, then I know the linkage connects to the transaxle on the top, forward, left of center. There is a retaining bolt (i think bolt, been a long time) that attaches the linkage to the transaxle. If this has backed out very much the linkage is not going to shift gears on the transaxle.
I hope this helps.
Jul 28, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Brand new riding lawnmower, stop on hill, set park break, ready to go foward and when I push foward pedal and release break mower free whells backward. has 1 hr. on it. purged the trans. per instructions...
Sorry to hear about your problem...you aren't the only one having it. Sounds like a hydrostatic problem or a pulley freewheeling on a shaft somewhere. If you bought your tractor at Sears they might could help you---the husky and are the craftsman are the same. Husky uses a little better engine is all. Hope this helps.
Jul 11, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
2008 Husqvarna YTH 2348 is loosing power...
it has a leak from the head gasket,ive done many with the same problem.pop the head off and change the gasket,also check the rings ect while apart
Dec 30, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Gear selector
SOUNDS LIKE THE BELT HAS CAME OFF OR THE PULLEY HAS BROKE
Sep 30, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman hydro gear transaxle problem
check the brake for sticking and dragging. check the bypass lever, make sure it's disengaged fully. did you just fix a flat rear tire? if so, the square key that links the axle and wheel fell out. do you pull a heavy garden cart around? that can stretch a belt and overheat the trans. last thought, check the belt and see if it came off a pulley, i know that should have been first but it's late and i'm tired. good night
Aug 11, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
I have a 20 hp craftsman lawn( hydro gear transaxle ) tractor in terrific shape that losses drive on a grade. I replaced the worn drive belt and it was good for the first few mows, Now Im right back to...
It sounds like the oil in transaxle is degraded.The transaxle is supposed to be a sealed unit requiring no service but over time the oil will get dirty enough to cause problems like you are describing.Remove the back hitch plate and look at the transaxle it will have a rubber vent hose or a 1/4 alllen wrench fitting on top. You will need to purchase a battery suction bulb from sears automotive and use it to remove as much oil from transaxle as possible. Warm the transaxle up first by running it around,then suction the oil out.Refill with a good synthetic motor oil 15w-50 or 20w-50 like Amsoil or Mobil 1.Do not use transmission fluid or hydraulic fluid. When adding the new oil back fill it to within 1.5 in from the top,be sure to allow this amount of air space in top of transaxle for expansion.
Jul 15, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 20.5 hp. auto trans.lawn tractor loss of drive power
Hello:
>>You can View a Breakdown/IPL of
this Engine at this Site Addy,
http://www.outdoordistributors.com/
and Select the H. Then Select Hydro-
Gear. Then Select Don't have Part
Numbers. Then Enter the Model
Numbers 319-0650. Then Select your
Model and Download the File for
Online Viewing.
From your Description it Sounds like the Internal Pump is Worn and is Loosing Pressure as the Unit Heats Up and the Components Expand from the Heat.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 10, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman Transmission problem
Some of these tractors have a friction wheel that is driven off of a flat wheel on the bottom of the engine drive shaft. The rubber ring on this friction wheel could be worn out, or it could be out of adjustment.
Apr 22, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
996 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
