Question about Samsung Rant Cell Phone
Samsung rant have to hold charger just so to charge the phone. Port doesn't seem to be loose.
The charger probly got a shortage in it
Posted on Sep 01, 2010
My Samsung tablet won't charge when plugged in
Does it have a micro USB charger/charging port? This was the universal charging adapter most manufacturers other than Apple moved to around 5 years ago. In my experience, the charging port to charger connection can become loose and prevent charging....especially if you use the tablet or phone during charging. The best method I have found to troubleshoot the issue is to try a charger that successfully charges another device and plug it into the tablet or phone. If your device still does not charge, and especially if the connection is loose, it is most likely that your charging port is damaged. Another possible issue would be the battery itself but the charger or charging port is the most likely culprit for your issue.
Sep 08, 2017 | Samsung Tablets & eReaders
My galaxy 3 phone will not charge properly how do i fix it
Charging issues is a process of elimination. First the charger....many chargers will fit but not all that fit will work. A bluetooth charger will fit but would never charge your battery completely. Make sure you are using a proper charger. 2nd is the charging port on the phone. If the charger is loose it could be a bad port or the prongs on the charger are not holding....is it loose? Or if there is corrosion on the port. If corrosion, clean with alcohol and tooth brush. 3rd is the battery. If its swollen, then it's toast. A li-on battery will start to decrease after 400 to 500 charges.
Jun 18, 2014 | Samsung Galaxy S 4G Cell Phone
My samsung rant keeps saying abnormal stae, charging disabled. What do I do?
It is a quick with the charger. Turn the phone off then try charging it. If that doesn't work, change the battery, and with the phone off, charge it.
Sep 11, 2010 | Samsung Rant Cell Phone
My samsung rant wont charge. it charged yesterday but today after plugging it into the charger the Samsung name lights up and then it says "low battery please charge" but it wont charge, i did drop it in...
Phone not charging.
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Aug 10, 2010 | Cell Phones
Hi, Samsung Rant is acting up. The battery is completely dead and my charger is broken, so I use my USB cable, but when I plug it in, it doesn't charge, it turns on and then shut off over and over again,...
I had a similar problem when I was using my computer cable for convenience. I asked my stepdad, since he's an very computer smart and he told me the computer cord is not for charging and when I switched back to the wall charger it was fine. You'll just have to go buy a wall charger.
Aug 10, 2010 | Samsung Rant Cell Phone
When I put in the charger for my Samsung phone, it says "Charging stop" when I put the phone down. Why?
Your charger is probably loose or not fitting into the port correctly. After you put it down, wiggle it and see if the "charging stop" disappears.
Jun 24, 2010 | Samsung SGH-a777 Cell Phone
I have a samsung rant and the charger port that is connected to the charger wont charger. How do i fix it?
there are 2 possible reasons for the problem u mentioned..
  • either ur phone charger port or its internal connection is defected
  • or ur charger circuit or wire orits pin is the problem
you can find it by connecting ur phone with system using usb data cable..if it charges then ur charger kit is to replaced..else u must service ur phone
May 24, 2010 | Samsung Rant Cell Phone
My samsung rant does not charge when the charger is attached, when you remove the charger it beeps like it is supposed to if you turn the phone off and try to charge it just recycles from off to the...
This worked for me........Plug in the charger, and then wrap the cord around the phone tightly! But no too tight or the whole damn thing will fly out (this happened to me)
Jan 31, 2010 | Samsung Rant Cell Phone
Charging is Disabled
i have tried different chargers, but my phone keeps saying abnormal state charging disabled.
Apr 07, 2009 | Samsung Cell Phones
Samsung Rant  Cell Phone Logo
175 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
