Question about Cycling
I have a 1998 polaris trailblazer 250 4 wheeler and iam trying to get running.i put a new carb kit in it.i took the starter out and repaird it.would this have anything to do with not running.when i put my hand on the back part of the carb it back fires and it acts lick it wants to start.does any body have any suggestions on what i can do or what could be wrong.thanks
    Problem Solver:
  • 12 Answers
Maybe your gasket or your running to rich my best bet is your running to rich oil or carb ajustment
Posted on Apr 09, 2012
  • walz04736
    walz04736 Apr 09, 2012
    maybe your gasket or your running to rich my best bet is your running to rich oil or carb ajustment
I have an 02 doing the same thing---did you ever get this figured out?
Posted on Sep 18, 2010
How to change 2000 Polaris Trailblazer 250
Hey Bob check out YouTube...That's where I went when I needed to fix the pull rope on my kids four wheeler. Here is a link to a video...He shows you how to get to the housing about 8 mins in to the video.
https://youtu.be/DFC6fQoLlQM
Hope it helps!ycejjb
Jun 06, 2016 | ATVs
I can't get my Polaris Sportsman 90 to run
Hey Chris,
I need more technical info.
Did you line up ALL the timing/valve/cam/piston location marks when you assembled the engine?? A new head..?? - new valves, cam. ..?? Piston installed in the correct direction, Does the carb float bowl have gas in it..? (the drain screw is in the very bottom- loosen it and gas should flow out freely. What do you mean by "kick over".. does it have a kick starter? ..or will the motor not turn over with the kick starter? Please tell me more. Thanks
Mar 10, 2016 | ATVs
Trailblazer 250 wont start
check/change, Battery, spark plug, remove air filter, use starter fluid, drain all old gas. use premium new gas. usecarb cleaner...should run,.
Mar 28, 2014 | Polaris ATV
Polaris trailblazer 250
Check the timing.
Oct 10, 2013 | Garden
2004 polaris trailblazer 250 is really hard to start! it will not start with the electric starter, compression is at 100 gas and carb are claean and flowing it has a new plug and will only start with the...
hi try cleaning the air filter box might be filled with oil so all you have to do is clean the air filter out with water let it dry and soak all the oil up with a rag or sponge. and try to replace the battery and spark plugs, thats what i did for my 2005 polaris sportsman 500 ho. Best of luck!
Aug 29, 2013 | Polaris ATV
250 Polaris Trailblazer wont start- new spark new filiter help
Did u choke it ? -stroke are very cold blooded Mine(2003) needs a choke after sitting 1/2 hr at 70 degrees.
Mar 31, 2010 | Polaris ATV
My 2002 polaris trailblazer wont start it has fire
If you have oil and gas and it will fire then try a new plug. A bad plug when removed will appear to be fine but under compression can fail.
Also try a splash of good gas in the throat of the carb or intake (if fuel injected) with a new spark plug. My bet is it fires just fine.
If this is a fuel injector type engine you could have a bad injector control unit or a clogged injector.
If it fires with gas in the intake manifold then suspect carb or injector system. (which ever applies)
Thanks for using FixYa!
Kelly
Feb 19, 2010 | Polaris ATV
Electric Start Wont Work (Four Wheeler)
Solenoid Faulty or loose connections, short out the solenoid on its contacts and see if this throws on the starter motor, other than that it could be brushes inside the starter motor itself. Good Luck , the eti
May 20, 2009 | 1979 Yamaha RD 250
Compression on 2000 polaris 250 trailblazer
the fuel could be good but still it wont spit check the carbs when you throttle or kick start if thats possible if that is good try some starting fluid it should start up and the fuel pump should get out the obstruction if theres more problems it is one of many things either bad fuel pump, your fuel line is disconnected, blown headgasket idk the psi specs for the 250 but that sounds good i know for the 550s its around 120 and so on
Apr 24, 2009 | Polaris ATV
Cycling Logo
138 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
