Question about GE Televison & Video
Will this remote work if the power button is broken on the t.v.?
    Problem Solver:
  • 13 Answers
Yes if you have the code for the remote to work the tv
Posted on Aug 29, 2010
Remote with TV stopped working for vol, AV, and mute. Only power button works. Used new Batt; no change. Used buttons on TV; none work there too. Is there something broken on TV?
If the buttons on the TV -and- the buttons on the remote don't work, then there's definitely something wonky with the TV.
The good news is that the power works and the picture looks good. That rules out a bunch of things. If you don't mind tinkering, replacing circuit boards on TVs is pretty straight-forward -- just take off the back, unscrew the offending board and replace it. You'll have to do a little research to narrow down to the right board to replace -- it might be this key controller board:
http://www.shopjimmy.com/panasonic-tnpa4280s-gs-board.htm
May 04, 2016 | Panasonic TH-50PX75U Plasma HDTV
I have hisense er-31607A it will not work on tv unless i am pressing the white button next to power button simultaneously.
I suggest you to disassemble your remote to check led connection. If connection is broken; by pressing white button it might connect broken wires temporary.
Nov 22, 2014 | Televison & Video
I have a Zenith Model B25AO2Z tv and programmed it through my cable remote. I just got a new cable remote and the first step to program a tv is to turn on the tv. I can't do that because the t
Have you ever tried to fix tv remote? Most of the remotes don't work due to broken led connection (Red circuled area). Try to resolder it, may be you might work it.
Nov 19, 2014 | Zenith B25A02Z TV
My Palsonic LCD TFTV81PBHDT remote is broken and buttons on side panel do not seem to work. How can I switch tv on to tune to universal remote? Do the side buttons have some sort of child lock function...
you can program most universal remotes to work the tv and menu the child lock is activated on the tv and the buttons will not work only power button will work as long as it has not been set to not work when made. some are set this way. but a remote with the right code set will turn on the tv.
Sep 20, 2013 | Televison & Video
Remote doesn't work even with new batteries
make sure the remote batteries are in the correct + and - way. It could also be that the remote is broken. If nothing comes on when you press the power button and the tv doesn't respond, then the remote is broken and you should buy another one.
May 28, 2011 | GPX Televison & Video
The on / off button on the remote does not work. Will a new remote take care of the problem?
A new remote should. It could either be that the remote is broken or the receiver on the tv. Make sure that the tv works with other buttons such as volume and channel. If everything except the power button on the remote works, just get a new remote.
May 26, 2011 | Televison & Video
The player will start with the power button on the unit the dawer will open and close and the unit will load and start running but the remote does not seem to work to start the unit. new batties wer...
Check that the batteries are inserted properly and that they are in the right way, if either of the batteries is not in the position its ment to be, it won't work.
you would need a Special IR camera to see any light from the remote so that seems like a silly solution to me.
The remote is not working if you can't turn the device off or change channel. You might want to try another remote to confirm that your device actually receives the signal and works, if it does work with another remote, the remote you have is broken.
Aug 27, 2009 | Televison & Video
The power button on the tv is broken and i lost the remote
You can just try programming the remote with the Sharp codes they list in the instructions until you find the one that works. Follow the procedure for entering a code and try it. When you find the right one it will turn the set on when you hit the power button. The remote's instructions tell you to turn the set on to make finding the code easier (when the set shuts off you know you found the right one), but you can work without it.
Mar 27, 2009 | Sharp 27N-S100 27" TV
Dvd code
Try preforming an automatic code search:
1) Make sure the device is on.
2) Hold down the DVD button and the power button simultaneously until the red light stays on solid.
3) Then press the power button - it will flash one time - keep pressing slowly, letting it flash until the device turns off.
4) As soon as the device turns off, press the stop button
If your the remote does not power the device off after cycling through all the codes - You will know this when the power button blinks and deluminates - then your "universal" remote will not work with the DVD player.
The best of luck to you!
Sep 18, 2008 | Televison & Video
Broken power button
unfortantly the power button on the front panel in most cases are part of the entire front part of the cabinet! In some cases you can take off the back and gently pull and slide out the chassis then you can see if it just slipped down below the switch or is it broken?? The front cabinet for this set is expensive and you probably would not want to replace it but you should be able still to use the remote control. If you dont have the remote a universal should work or you can most likely get an original replacement remote from 1-800-remotes or at http://www.remotes.com Good Luck
May 23, 2006 | Daewoo DTQ-25S3FC 25" TV
Televison & Video Logo
20 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
