Question about Sony PlayStation 2 Slimline Console
PS2 Slim Line Prblem !!!
Hi. Thanks .But how can a spindle put scratches on a disc.I didn't understand what you did said.Can ypu explain in a easier way.Does the lens touches the cd and put scratches on it. or are you trying to say that the cd is inserted too much in the spindle.My PS2 is not in warranty.But it does not put scrathes on double layer disc(Blue disc).Can you reply me ?? Please Reply.
    Problem Solver:
  • 5 Answers
Lenses adjust their distance on ur disc, the harder they can read it, the nearer it goes on the disc...can it still read other discs? if it wont, then ur lens is damaged because of too much scratches, and if it does happen, u have no other choice but to repalce lenses...and by the way, there's an adjustment under these lenses that determines its distance on the disc, but before adjusting it, you should know what ur doing, coz it miht damage the lenses, again....
Posted on May 13, 2008
I put a game in my PS2 and it scratches it. Whats wrong?
Your disc trey or disc spindle is off balance maybe see if your trey is out of line and bend it slight back inline. Or if its the piece that spins your disc it might need replacing or a good push back down.
Nov 20, 2010 | Sony PlayStation 2 (PS2) Console
On my ps2 after reading its disc, message will appear "disc read error"
Hello, you are most probably using a PS2 Slim, they have a very sensitive Lens Radiance. If the CD is a little scratched, a CD lens cleaner could help. Or if it is not a PS2 Slim, it must just require a CD lens Cleaner :)
Jan 29, 2010 | Sony PlayStation 2 (PS2) Console
Ps2 slim spindle dont spin
If your spindle has stopped spinning, it will most likely be 1 of 2 problems. Either your spindle motor has burnt up, or even though it is very unlike, a lead wire that supplies the power to the spindle has became disconnected. Now, if the case it the burnt up spindle motor, there are hundreds of motors for every kind of PS on, of course, E-Bay. If the problem is for some reason, a soldered wire has broken from the motor. It is very simple to re-attach the lead with a quick touch from a soldering iron. I hope this has helped.
Jan 02, 2009 | Sony PlayStation 2 Slimline Console
My Ps2 Fell from my desk now it scratches every game i put in please help me i think something came off
You need to replace the DVD drive assembly / Motor spindle as that keeps the alignment of the disc (ebay) however you need to get the right one for your model SCHP ****
Oct 04, 2008 | Sony PlayStation 2 (PS2) Console
My ps2 slim is leaving rings on my games???????
I think the motor spindle is damaged , as the motor spindle holds the disc up or it could the lens assembly being misaligned which causes the lens to be angled and scratch the disc
i recommend you to look at the site http://www.forums.gamewinners.com/forums/showthread.php?t=513070#Basic%20servicing for servicing if possible (slimline is somewhere at the bottom)
Jul 20, 2008 | Sony PlayStation 2 Slimline Console
PS2 Slim Line Problem
The problem is with the disc drive itself. Most common problem is the give in the spindle starts to go and gets to be to much and you get floating of the disc while in play. If the system is still in waranty I would sudgest contacting the MFG and getting it fixed or replaced. If not in waranty then your only other choice is to find another system for cheap and rape it for parts and replace the drive.
Apr 29, 2008 | Sony PlayStation 2 Slimline Console
PS2 Slim
SURE !!! www.richspsxparts.com
Dec 04, 2007 | Sony PlayStation 2 Slimline Console
Disc wont work
Hi AdalVI,
Your PS2 probably has a dirty laser lens. Below is a procedure for cleaning the lens on the big PS2. It does not work on the Slim PS2. Do not ever use alcohol on a slim PS2 laser lens.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. Remove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the Reset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the CD tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the CD area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. Remove the little white disc from the CD tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and you’re in business.
If you have trouble you can send your PS2 to a Repair shop. Click on "Repair Directory" at the bottom of this screen. then choose "Video Game Consoles". Then you pick a Good Repair shop. My shop is listed, but I cannot divulge the name in this forum. Cost will be $25 plus shipping. Shipping is usually $8.95 to the USA
Dec 04, 2007 | Sony PlayStation 2 (PS2) Console
Clean the lens of ps2 slim line
since it is slim type ps2 get a cotton buds and wipe the lens gently and smoothly.
Oct 19, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 Slimline Console Logo
90 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
