Question about Konica Minolta Dynax 5D / Maxxum 5D Body only Digital Camera
After loading compactflash card, card slot door will not close
I just bought a used one & I am having the exact same problem. Cut of the top of the card ejector?
Posted on Feb 13, 2011
Is thare a sim slot in dell axim 51v
Musaji Ahmed Hariff,
Your device has two slots located on the top of the unit. The larger slot supports CompactFlash Type II cards. The smaller slot supports Secure Digital (SD) memory cards, Secure Digital I/O (SDIO) cards, and the MultiMediaCard (MMC). All three memory card types are available in sizes from 64 MB to 1 GB or 2 GB. CompactFlash Cards Your device supports CompactFlash Type II cards. Some common types of cards include: • Modem - Connect a telephone line for modem data communication. • Wireless communication - Data communication without the use of cable connections. You can use cards, such as internal cards with Bluetooth wireless technology and 802.11b wireless LAN. • Storage - Save data or install programs on a storage card
You can click the link below to download the online manual for the Axim51v
http://dell.to/1WKDE1W
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Oct 05, 2015 | Dell Axim X51v Pocket PC
When I plug in my compactflash memory card into the slot thing on my tower nothing happens. how do I get it to work?
You probably have multiple slots. and some memory cards will fit into other slots. usually the card type is listed under each slot. make sure you have it in the right one first. also there is usually a light that will change colors when it detects a card inserted. then windows should take care of the rest.
Nov 04, 2010 | Computers & Internet
Message "card slot not initialized
The HP Color LaserJet 4650 printer also has three flash memory card slots for printer firmware, fonts, and other solutions. The HP Color LaserJet 4610n does not include any available flash memory card slots.
■ The first CompactFlash slot is reserved for printer firmware.
NOTE Use the first flash memory card slot for firmware only. The slot is marked “Firmware Slot.”
■ The two additional CompactFlash memory slots in the HP Color LaserJet 4650 printer enable the user to add fonts and third-party solutions, such as signatures and personalities. The slots are marked "Slot 2" and "Slot 3."
--- These card slots are located inside the Formater unit. Most likely you either are missing the firmware card or it's defective.
Hope this helps!
good luck!
Aug 31, 2009 | HP LaserJet 4650 Color Printer
Computer keeps saying insert disk into CompactFlash (F:)
I suppose if memory card is inserted your computer restarts, this usually happens if there is short in the memory card slot.
Mar 31, 2009 | E-Machines (T2958) PC Desktop
Finepix z20fd memory card won't load in slot
Have you ever dropped your camera??
If you have , this is why.
No need to buy a new camera just yet.
Try celotaping it in.
My mom had to do this , after it worked fine!
Dec 26, 2008 | Fuji Finepix Z20fd Digital Camera
How do i down load pic on computer
Almost any computer store (even drugstores these days!) sell inexpensive memory card readers that have a connector that you plug into a USB port on your computer. Most have slots to read several different types and sizes of cards. Just be sure that the reader you buy takes CompactFlash (CF) cards that the Nikon 5700 uses. Your computer treats the card and reader as one more disk drive.
Aug 08, 2008 | Nikon Coolpix 5700 Digital Camera
Helppp
Remove batteries and card. Look in the card slot for any bent pins. If you see some, use a small/skinny jeweler's flat screwdriver (K-mart, Walmart, and even dollar stores sell these, look in the hardware section) to bend the pin back as close as possible. Take your time and use as much patience as you can muster (take a breather in between if needed).
It doesn't have to be perfect, just as close as you can get it. When it's there, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
Jun 23, 2008 | Canon PowerShot A70 Digital Camera
Palce where to insert sim card
It's not a phone. It's a pocket PC.
CAUTION: For synchronization to work properly, install Microsoft
ActiveSync on your personal computer before you connect your
iPAQ Pocket PC to your computer.
To install a CompactFlash (CF) or Secure Digital (SD) card into
an expansion slot on the iPAQ Pocket PC:
1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
To identify slot locations, refer to the Getting Started
document that came with the iPAQ Pocket PC.
2. Before inserting a CompactFlash (CF) card into the CF
expansion slot, pull the plastic slot cover from the CF slot.
3. Insert the expansion card into the appropriate expansion slot
and push the connection edge of the card firmly into the
expansion slot.
✎If your expansion card is not recognized, follow the card
manufacturer’s instructions to install it.
✎For more detailed help, refer to the Help files installed on your
iPAQ Pocket PC. From the Start menu, tap Help > Connections.
✎To prevent power loss, remove any expansion cards from either
the CF or SD expansion slots before turning off the iPAQ
Pocket PC.
44bf6e2.jpg Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device. Figure 1: Expansion slot c00059391.jpg To make your Pocket PC a WLAN device, you need:
  • To purchase a WLAN CF or SDIO expansion card
  • To have access to a wireless network
Dec 29, 2007 | HP iPAQ H2215 Pocket PC
When a CompactFlash is loaded, a message of "Card Error. OK" appears and remains on the LCD monitor.
Please follow the procedure below: 1. While the message is displayed, press the center of the controller. 2. The LCD monitor and data panel will turn off . 3. Turn the Main Switch to OFF and remove the CompactFlash card from the camera. 4. If "No Card " message appears at next time the camera is activated in the recording mode, the camera and CompactFlash card are OK. 5. In case that "Card Error. OK" appears again, the CompactFlash card may be faulty. Use other card.
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
What else can I do with CompactFlash
You can copy images to a CompactFlash card from the camera's internal memory or copy images from the CompactFlash card to the camera's memory. Also, if you have a PCMCIA adapter and a computer with a Type II PCMCIA slot, you can access images stored on a CompactFlash card directly from your computer.
Sep 13, 2005 | Epson PhotoPC 600 Digital Camera
Konica Minolta Dynax 5D / Maxxum 5D Body only Digital Camera Logo
108 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
