Question about Fisher and Paykel GWL11 Top Load Washer
Fischer & Paykel washer will not drain. What do I do?
    Problem Solver:
  • 14 Answers
You probably have a blocked drain hose - the most common cause is a coin or a button but sweetie wrappers & paper are just as bothersome. Turn off the machine & unplug. Pull the machine forward so that you can access the rear. The drain hose is at the bottom of the rear of the machine and is held in place by a very strong spring-loaded clip or else a jubilee clip. This needs to be removed & will result in the water inside the machine & hose draining out so make sure you have plenty of containers & cloths/towels etc to catch & mop up. The blockage is usually located just inside the hose. Remove anything you find. Also check the hole on the machine where the hose attaches. Re-attach hose. Clean up, put machine back and switch on. Also check filter for clogging (see manual). Run machine on rinse & spin cycle. Hopefully that should do it. Good luck.
Posted on Feb 20, 2015
    Champion:
  • 274 Answers
Take clothes out,check the hose for is it blocked or kinked put a clothes hanger in hose and see if you can un-snake any thing out,then put draino-max jel in washer and let it set for about 2-3hrs,see there may be hair blocking the pump were it drains,this stuff work great for front-loader so let it sit.then try putting on drain it may take a few times,the when it drains,run washer on full cycle no clothes hot-water let it go through a full wash cycle etc.
Posted on Aug 29, 2010
Can anyone tell me the age of my Fisher & Paykel refrigerator? (model E442B, sn: MYQ784484)
Possibly upto 7 years old but call Fischer & Paykel with the serial number and they should be able to give you the day month and year of production, the only number i can find for customer services is : 08000 886 605
Sep 20, 2014 | Refrigerators
Fischer paykel washer machine not turning on
I reset mine by unplugging it for a few minutes and plugging it back in.
Feb 08, 2014 | Fisher and Paykel Washing Machines
Fisher & paykel gw612 washer constantly trying to drain
The pump triacc in the motor control board needs to be replaced
by a technician, it's cheaper than getting a new board.
Apr 22, 2013 | Fisher and Paykel Fisher & Paykel Washer
I only have a hose attached to the cold water tap and inlet valve of my Fischer & Paykel top loader washing machine as I only do cold washes, this hadn't been a problem until recently, when th
it could be that the water level got to high and came out of the valve you could try putting a cap on the valve and see if that works and if it does not then it might be a bigger issue.
Dec 23, 2012 | Fisher and Paykel GWL11 Top Load Washer
F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
Dec 31, 2009 | Fisher Paykel EcoSmart GWL15
Fischer Paykel fridge freezes then stops
sounds more like a defrost problem, check your defrost timer, defrost heaters.
Feb 21, 2009 | Amana ABB1927DE Bottom Freezer...
Problems with fischer paykel self cleaning oven
Sounds like Clothes Washing Machine To Me!!--Methinks You have "Posted Incorrectly"--Stay Upright --Des.
Dec 15, 2008 | 2006 Fischer MRX 650
Fisher and Paykel GWL11 Top Load Washer Logo
195 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
