Question about Dryers
My dryer drum seems offset and clothes are getting stuck in between the drum and the exterior rim. The gap between the drum and the exterior rim is wider on the bottom than on the top.
    Champion:
  • 274 Answers
Call a repair man it needs to be opened up and the wheels that the dryer set on to turn it sounds like it some how came off,and the belt is miss alined.
Posted on Aug 29, 2010
Hotpoint aquarius vtd00 dryer clothes getting stuck all the time how do I fix
hiis the rim of the drum seating ok or worn out because it will give u sharp edges its all i can think of take top off rotate by hand check rim allso try lifting drum if you have fair bit of play you need front bearing pads
Dec 28, 2013 | Hotpoint Dryers
Drum gap
what is the model number?
Dec 09, 2012 | Kenmore 83142 Electric Dryer
Clothes stuck in drum
You might have a drum glide, felt piece, that has come off or unaligned itself from the drum. Contact Frigidaire for one and replace it. You have too much of a gap in the front and that is why your clothing material gets caught.
Jul 29, 2012 | Frigidaire FEQ1442ES Electric Dryer
I have a whirlpool wed5520sq0 dryer the drum seems to be pinching cloths and making marks on them. The drum has a gap on left side looking into the dryer. I can move it and close the gap. Any ideas would...
Sounds to me like either the seals on the front and back of the drum are worn or the glides for the drum are worn and is causing the clothes to get caught between the drum and the usually the
front edge of the dryer. The worn glides will cause the gap that you mention.
Feb 11, 2011 | Whirlpool WED9200SQ Electric Dryer
Hello I have an 2004 HE4 Nat Gas smartheat quick pack 9 model 9587 / 110.9586. It seems to be leaving brown markings or streaks on the clothes more and more frequently any ideas on how to best deal with...
the felt seal part number 697694 could be worn,if the drum sags down from the felt wearing down it forms a gap and the clothing can even get stuck in gap,some dryers have glides that wear down and some ride on a back bearing,but the problem usually is from a part wearing down and a gap forms from it and it damages the clothing,hope this helps
Nov 06, 2009 | Kenmore Elite HE4 Electric Dryer
Drum seems to be loose. Metal to metal sound each time it rotates
the rear bearing is bad and maybe also the glides on the felt need to be replace they sell it as a kit
Aug 22, 2009 | Kenmore 98702 Stacked Washer/Dryer
Clothes get stuck between dryer and barrel
If your clothes get stuck, marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
May 31, 2009 | Electrolux Kenmore 5.8 cu. ft. Super...
Fridgidare dryer problem
there is a front glide assembly, depending on model will have 3 teflon/plastic glides attached t o the felt, this may be your grinding and gap issue
Nov 16, 2008 | Dryers
Stuck clothes
There are durm glides that support the front part # 5303937139
you can look up and order at www.apdepot.com
Hope this helps
Jul 18, 2008 | Kenmore 62722 Electric Dryer
Dryers Logo
179 people viewed this question
Top Dryers Experts
