CD stuck in a 5-disc changer
A CD is stuck in the player. The tray is out & won't go back in. When power is on, the tray just spins. With the cover off, I can see the CD is held in place but I can't get it out. Is there a release button or other way to correct?
Sony CDP-C435
  • 4,234 Answers
There is a flat ribbon cable on the inside that is defective. The cable needs to be replaced and the loading mechanism retimed. This is a simple repair for a repair shop. Expect the ribbon cable to run around $10. Add in the local labor rate for the total repair cost. I've done many of these. This is a common problem with age.
Dan
Posted on May 07, 2008
Sony CDP-C910 will no longer play cds or eject changer cartridge
Mine did the same thing. My player was primarily used in the garage and the cold weather may have caused my player to do the same thing. I just fixed my player. I removed the top cover and looked at the CD in the play position. In the upper right corner from the CD, you will see a spindle motor with a belt on it. Gently spin the motor back and forth carefully with your finger. I rotated it a half-spin in either direction, careful not to dislodge the belt. When I turned the player back on, the mechanism operated as it normally would and began playing the disc. I was able to eject and reinsert the magazine without any issues, solving the problem. Hopefully that will work for you.
Dec 17, 2012 | Sony CDP-C910 10-Disc CD Changer
Cd will not eject. Keeps giving message "Now OPC" but will not do anything and will not eject cd either.
To remove a stuck CD from Tascam CC222 MKII
This solved the "Now OPC" problem
1. Unplug unit
2. Remove the top cover, (3 screws on each side and 3 on the back, lift cover).
3. Plug in unit.
4. Power on the unit to observe the drive spindle spinning clockwise, (1" disc on top of drive).
5. Turn off unit, do not unplug at this time.
6. Use a small screwdriver to prevent the drive spindle from spinning.
7. Power on the unit preventing the spin.
8. In approximately 10 seconds the display will read "Disc Error" and the CD tray will open.
9. Remove the screwdriver and the disc.
10. Turn off the unit and unplug.
11. Replace the cover.
12. Use a better quality disc.
Sep 23, 2010 | Tascam CC-222mkIII CD Player / Recorder
Disc stuck in cd player
Easy, turn off the power, remove the lid by unsrewing all the screws on the side, back and top of the lid. When removed you should see the CD jammed somewhere at the rear of the disk carrier. be very carefull and slowly remove it. The disk may be already scratched but if you're carefull you can stop further damage. Also don't force any part of the tray they are only plastic. If you can't get the disk out things start to get awkward. Write backmor take the unit with the lid off to a repair shop it shouldn't take them long to get it out.
Apr 07, 2010 | Technics SL-PD887 5-Disc CD Changer
My dics dor to its changer wont close
open it up
the tray has somthing stuck init
Mar 02, 2010 | Sony CDP-C445 5-Disc CD Changer
I bought the cd changer with my unit & two cds are stuck in it. This happened the third time I used the unit.
this is a mechanism problem. Also, maybe something might have hooked the cd tray and made it stuck.
What you have to do now is to open the player by unscrewing the cover, so that you can gain access to the mechanism inside the player.
After you must have opened the cover, plug the cd changer to light, power it on and use you hand to pull out the tray while you press open button.
Also make observations on the disc tray while you press the open button and check the disc tray and look for what is making it stuck and refuse to open. This is why you need use your hand to support the disc tray by pushing it open from the inside.
I wish you good luck.
Feb 25, 2010 | Bose Wave Radio
I have a denon 3500 cd player my cd is stuck
Open the top cover of your CD using a screw driver, (usually a star screw driver),. Then, manually turn the driving gear of the CD tray to free the stucked tray and until to the point where you can take the disc from the tray. Be careful so the setting of the tray and the laser eye is not change. Then, close the close the cover and play. You can send your e-mail thru fix ya to let me know.
Sep 25, 2009 | Sony CDP-C910 10-Disc CD Changer
Disc stuck in cd changer
there is a large gear on the top of the cd mech, turn it counterclockwise to put the cd back in the magazine. the changer will probably work after that.
May 09, 2009 | Car Audio & Video
Sony 5 disk changer disk is stuck not able to open the tray
After some time it was showing some C 31 00 error. I searched on internet, opened the top cover, there is the CD changer and my cd was stuck in there, I pushed the CD from finger and there it goes... on press of eject it came out... thanks anyway...
Apr 02, 2009 | Sony CDP-CE375 5-Disc CD Changer
5-Disc CD player
your tray is out of track, have to place it back. not that easy but you can try. dont force it of you can damage the tray or gears
Nov 21, 2007 | Yamaha CDC-765 5-Disc CD Changer
Screen only shows "cd"
possible tray stuck, will cause this problem, if you can get the case off, 2 screws on the bottom and 4 or 5 on the back case , if it is jammed the unit will not initialize..I am talking from experience with model and simular models ..I have repaired alot
Aug 22, 2007 | RCA RP8078 5-Disc CD Changer
412 people viewed this question
 Grubhead
Grubhead
