Question about LG L204WT LCD Monitor
How do I get into the LG 204WT monitor to change the capacitors in the power supply?
  • 11,361 Answers
Here are the service manuals: http://elektrotanya.com/?q=showresult&megnev=LG%20&megnev2=L204WT%20&kategoria=&kat2=all
Start separating the case at the bottom edge of the monitor then work your way around using thin flat blade screw driver, be careful with any cable attached to the front bezel.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Aug 29, 2010
    New Friend:
  • 12 Answers
The monitor has 4 screws at the rear which you need to remove. Then the front bezel clips off.
If your LG L204WT will not start up - only shows the blue LED but no display, or takes long to power up, or dies after a while and it has not been exposed to lightning damage then in all likelihood the Electrolytic capacitors in its power supply has started to fail.
Unplug the unit from mains. To open it up, remove the 4 philips screws at the back. Then starting at the bottom corner use a small flat screw driver to wedge the front bezel loose. After removing the bezel the rear casing will also come off the panel. The circuitry case is taped to the panel with silver tape. Loosen the tape, lift the power supply. Carefully unplug the two sets of backlight cables, and the front panel controls to completely remove the circuitry case. Now remove the 4 screws holding the power board and then replace the following capacitors:
You can order caps from most electronic component stores. All the capacitors should cost under US$10.
You will need to replace:
C105: Electrolytic Cap, 47uF 50V 105 degrees C
C106: Electrolytic Cap, 1uF 50V 105 degrees C - very important, this one usually does not swell up.
C202,C206: Electrolytic Cap, 680uF 25V 105 degrees C
C203,C204, C205: Electrolytic Cap, 1000uF 25V 105 degrees C
C339 - 33uF 50V - I replace with 47uF 50V 105 degrees C.
You can always use a HIGHER voltage and a slightly HIGHER uF, and HIGHER temp rating but never lower.
Make 100% sure to observe the polarity when replacing the caps. Electrolytic caps have a clear negative marking stripe on the side coinciding with a black mark on the board.
If, after a few months of fixing it it fails again chances are your C106 and C339 has failed again - use a better quality capacitor with a higher voltage and temperature rating.
Posted on Jun 02, 2014
Lg flatron w2240
You might need to change the monitor's power supply. I have seen similar problems with other LG models. Usually it is easier to replace the power supply than trying to troubleshoot it.
Replacing the power supply usually involves a few screws and a few cable connections. Troubleshooting the power supply board itself usually involves soldering replacements for blown capacitors.
Oct 26, 2013 | Computers & Internet
LG L206WU monitor will not turn on
The normal cause of power loss if a failure of the filter capacitors on the power supply board. Here is a link to information on the power supply board and the capacitors that need to be changed.
http://www.ccl-la.com/catalog/product_info.php?products_id=242
Apr 26, 2013 | LG FLATRON L206WTQ-BF Monitor
Al2032w
This usually indicates that the filter capacitors in the power supply are not working right. When the unit is turned on they should build up a charge that lets the board power up the monitor but when they start to go out it takes longer and longer to get the charge built up. Here is a link to information on rebuilding the power supply board by replacing the capacitors, this should get you back up and running.
www.ccl-la.com/catalog/product_info.php?products_id=288
Dec 08, 2012 | Acer AL2216WBD LCD Monitor
Lg 1752s goes into power saving mode when pc is turned on
Hello Alan,
That is actually not power saving mode, the flashing power light indicates the power supply is not starting up correctly and keeps shutting down and trying again. This is a very common symptom of a failure of the capacitors on the power supply board. The L1752s uses the AIP0157 power supply board which is the same board the is used in several LG monitors such as the L196WTQ and L194WT. Here is a link to a repair guide for the L196WTQ that shows what capacitors to look for and replace on the power supply board to bring the unit back to life.
http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/
I hope this helps, if so please rate my solution.
BuddyMc
May 15, 2012 | LG L1915S 19" LCD Monitor
Display Shutdown After Few Seconds To Few Minutes
Hook a spare monitor to the computer to rule out the video graphics card in the computer, and sub another video cord from the computer to the monitor if possible to check your LG monitor, If the display shuts down and power light changes colour or goes out it is a power supply board, one or more capacitors open causing the power to fail, sometimes the top developes a bulge making it easy to spot.
Apr 14, 2012 | LG L192WS LCD Monitor
Lg 17"lcd monitor is power
You will have to take your monitor apart to fix this problem. Once inside, you need to find the capacitor or capacitors that are blown. The will be round on top, instead of flat. A picture is far better than words for this one, and video is even better. There are some excellent videos on Youtube that show you how to find the bad capacitors and how to fix them. It is not difficult, if you know how to solder.
Feb 21, 2011 | LG Flatron L1715S 17" LCD Monitor
Monitor keeps coming up with 'power saving mode' and the green on light turns to orange.
  1. remove the rear cover and the front cover
  2. look at the power supply you will find some puffed capacitors change them by the value
  3. if all capacitors looks good, check the inverter for shorted transistor
Dec 10, 2010 | LG L1717S-BN 17" LCD Monitor
LG L196WTQ monitor just quit working. won't turn
Look in the power supply section first for bad caps, post back what you find inside, pictures will help a lot to guide you through, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 24, 2010 | LG L196WTQ Monitor
Display problem in my LG 15'' monitors
1. cheak the filament path diode,capacitor.
2. there is dry points in power section.
3. replaced 3842 IC supply capacitor 47/100v.
4. LOT sarounds. if in case near to lot one resistor burnt (12k ohm ) change the lot & capacitors,resistor
Nov 22, 2008 | LG Studioworks 563N 15" CRT Monitor
LG L204WT LCD Monitor Logo
959 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
