Question about Moen Home
Bathtub faucet only runs hot water. think it is hardwater problem because this faucet is closest to the waterheater. Other bathtub faucets in the house do not have this problem. Part of my water source is well water.
    Problem Solver:
  • 10 Answers
There should be alternate little faucet knobs somewhere close one hot one cold, maybe you just have the hot knob turned to the maximum
Posted on Aug 29, 2010
Why hot water is still running when house water is turned off?
Is the hot water under sustained pressure or after you leave it on for 15 seconds or so, the flow lessens? If that's the case, the residual pressure in the pipes is forcing the water out as well as gravity if the faucets on the lower floors are still flowing.
Oct 03, 2014 | Kohler Brushed Nickel Roman Bathtub Tub...
Tub faucet (hot side) won't turn off when tight and the shutoff valve won't stop the water either
sound like you need a new valve in the hot water Faucet the rubber washer or cartridge depending on what type of faucet you have
May 09, 2014 | Sunrise Specialty Cast Iron Claw Foot Tub...
Water meter keeps running. When I turn off the water supply to the hot water tank the needle on the water meter stops, does that mean that I have a leak in the hot water pipe coming out of tge tank.
Yes you have a leak on hot pipe or TP overflow tube.
Put ear against pipe to listen for sound of running water.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#listen
If TP valve goes into drain line, check if water is running down TP overflow tube.
Check each faucet for leaks.
If pipes are under slab, put ear against each faucet to determine which faucet is closest to broken pipe.
Mar 23, 2013 | Water Heaters
Yesterday I was washinh some dishes in the sink when the hot water just turned off while running. I pushed the handle to off and then back on and the cold water works fine but no hot water! I cchecked the...
Depending on what brand of faucet you have you may need to replace the cartridge,moen and clones, or stem/cartridge on delta and similar. I would not replace the faucet until I was sure that you had hot water to the kitchen faucet and the faucet was going to cost more to repair then replace.
If you have supply valves for kitchen faucet I would shut them off and try to take faucet apart to determine where the hot water is stopping. Do not try to force things to much or you may make the faucet totally useless.
If you know what name brand your faucet is you can find several sites on u-tube that show good repair procedures.
I hope this helps you. Thank you.
Jan 12, 2011 | Home
I have a single control, new glacier bay bathtub faucet control. i don't have the hot water heater hooked up. i'm only getting a slight trickle out of my faucet whenb i turn the knob to cold. is it...
it is likely required. many new faucets have what's called a pressure balance valve that helps prevent scalding by lowering the pressure of hot when the cold pressure drops (due to a toilet flush or other water being run). Because you have pressure to only one side, that can cause the valve not to provide the necessary volume.
Dec 12, 2010 | Plumbing
Bathtub single handle faucet had not been used for a few months. Now when you rotate to hot water posiiton, there is no flow. Cold is normal. Hot water works fine at nearby sink & otherwise. Did an...
yes, and hopefully piece's of the cartridge's rubber have not come off and lodged in the water port's.have had this problem quite a few time's.remove your cart' and while it's out, run water to flush out the valve body.shine some light in body before re-assembly.
Dec 23, 2009 | Moen & One Handle Tub & Shower Faucet
Home Logo
100 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
