Question about HP w1907 LCD Monitor
My screen size is about 20% too big for my HP L1925 monitor. When I try to access the monitor's main menu, my cursor travels underneath it, so that I can't move the indicator on the menu. So how can I re-set the size of the page?
    Brigadier General:
  • 3,513 Answers
Hi
Try downloading the driver for the lcd then restart the pc and check resolutions
Also check the bellow links….
http://www.ehow.com/how_2064083_adjust-computer-screen-resolution.html
http://www.ehow.com/how_5580975_adjust-window-screens.html
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Aug 29, 2010
What do I do to get a screen that is frozen on a hp2010i monitor it is asking for language but the cursor on my mouse wont go to the selection
HP Monitor Problem - YouTube
? 1:35
https://www.youtube.com/watch?v=RYLaefQQdDY
Jul 22, 2009 - Uploaded by 7TimeToShine7
So I can use the monitor like I am using now but when themonitor goes to sleep I ... I tried it with a different computer and the monitor was able to re-find the ... How to fix or troubleshoot a blank or black screen not powering up ...
Monitor message" Power Button Lockout" - HP Support Forum
h30434.www3.hp.com > ... > Video/Touch
Feb 2, 2011 - 10 posts
Solved: New HP 23" monitor - HP 2310m Accidentally held down the power button too long; now I can't get the monitor to turn completely off. ... How can I turn the monitoroff completely and clear the message "Power Button ..... 8) · HP PCs - Error Messages Display on a Black Screen during Startup or Boot ...
OSD Lockout on my desktop monitor - HP Support Forum ...
h30434.www3.hp.com > ... > Boot
Dec 25, 2010 - 9 posts
If that doesn't work then go into the monitor's menu and do a factory reset. ... it looks like those button get stuck and doesnt work anymore so this is the ... OSD lockout prevents the OSD menu from opening on the screen when ...
Jan 03, 2016 | HP 2010i Black 20" Widescreen LCD Monitor...
My hp w2007 turned blue after I moved it how do I access screen display from the monitor menu
Some monitors change colour if there is damage, internally, within the signal cable. Try another cable if you have one.
Alternatively, it might be that the monitor is near an extremely strong magnetic source, such as big loudspeakers?
Mar 11, 2015 | HP W2007 LCD Monitor
HOW DOES ONE CHANGE THE SIZE OF THE ARROW CURSOR ?
Go to start menu, accessories, accessebility, accessebility wizard, scroll down to magnifier and click
Apr 17, 2012 | HP 2009M Monitor
How to rotate display vertically on HP L1925
Press control alt arrow key (up or down to rotate vertically and right or left to rotate horizontally) simultaneously to rotate the screen.
Good Luck and have a nice day
Jun 02, 2010 | HP L1925 19" LCD Monitor
What is the model of chopper transformer of HP l1925 monitor
It depends on who made the board, you can have more than one version of the board for the same model number, HP does not make the monitors, they get from the one who can make the cheapest one, you need to get inside and get the number, then google it or try here: http://www.lcdparts.net
Apr 12, 2010 | HP L1925 19" LCD Monitor
Have a Hp L1925 lcd monitor that the green power led light comes on but the screen is black. Used a flashlight and can see the logo and windows start.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
How to remove "in retail store mode with settings" message
Question What should I do if my TV is stuck in Retail mode? Answer Your TV may have been set to Retail Store mode, which is mainly used on the shop floor.
For home use, we recommend that you set the TV to HOME mode, which will allow you to change the settings.
To change to HOME mode follow the steps below.
  1. Press the 'MENU' button on the remote control to access the main menu.
  2. Move the cursor down to select INSTALLATION and move the cursor right.
  3. Move the cursor down to select PREFERENCES and move the cursor right.
  4. Select LOCATION and move the cursor right.
  5. Move the cursor up/down to select HOME and press the 'OK' button for confirmation.
  6. Press the 'MENU' button to exit the menu.
Sep 29, 2009 | Philips 42PFP5332D 42 in. Plasma...
I have an HP pavilionf1703 monitor. Two blue squares on
If the cursor is hidden use the keyboard: Press the TAB key and cycle the options. When you reach the one you want press ENTER
Hope it helps.
Aug 30, 2009 | HP Pavilion F1703 17" LCD Monitor
I have a Silicon Image 164 ADD DVI card added to my HP desktop DVI-D access card in an effort to get a dual monitor configuration. I get an exact clone in the second monitor. I have an HP compaq desktop...
If the Intel graphic card is part of the motherboard, you need to disable this in the BIOS. You need to install the Silicon grpahic driver, then you will be able to configure the screen resolution etc for each monitor.
Jun 10, 2009 | HP Compaq d530 CMT PC Desktop
OSD main menu pop-up will not go away
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu and remove that message from your screen. best regards
May 19, 2009 | HP Pavilion F1703 17" LCD Monitor
HP w1907 LCD Monitor Logo
27 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
