Hotpoint aquarius wf320 1200 spin washer all the lights areflashing andthe door won,t open andthe water won,t drain thank u
  • 1 more comment
  • Anonymous Nov 02, 2008
    flashing lights door locked
  • Anonymous Apr 05, 2009
    same as above, water won't drain, machoine won't spin and door is locked.
  • Anonymous Mar 23, 2014
    Very annoying as urgently needed clothes (work clothes, school uniform) are stuck inside as it won't let us open the door until the water is drained.
    Problem Solver:
  • 5 Answers
Its blocked...try the waste pipe
Posted on Nov 14, 2009
Hotpoint aquarius 100 wm62
tha model number doesn't come up,you need to send the full number off of the washer,open the door and lok around the opening where you put the clothes in,you should see a tag with the model number on it,if the pump doesn't drain out the water then it can't spin until the water is drained,if it's a front load washer check the pump to see if something is in the pump stopping the impellar from spinning to drain out the water or you could have a bad pump,put the washer or drain and spin and see if it will drain.
Jun 06, 2013 | Washing Machines
Door will not open have wash cycle
Switch off, put in spin/drain cycle and switch back on; check water is fully drained and then check filter. If not all drained, lower hose to ground level and drain to a bowl.
Apr 28, 2012 | Hotpoint Washing Machines
What does f-5 mean when flashing at me and won,t let me have my washing out the machine also washing really hot after a fast spin programme
if water is in drum then door wont open,drop drain hose to floor level into bucket to drain manually, then check filter or pump is it running ok if not is it stuck some thing in it , hot wash is cold water inlet ok or is this due to again faulty pump ...
Jun 25, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius waher dryer
possible blockage ' filter or could aslo be water coming back from the sink if drain hose too low , you may need to raise this....
Nov 13, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint aquarius WDL520 all lights flashing not spinning water still in bowl cant find instructions only bought it at xmas
There should be a small door at the front bottom of the machine, open it and unscrew the plunger. try that first as there could be a blockage.
The machine will not spin until the water is drained out.
Jun 17, 2009 | Hotpoint Aquarius WD63 Front Load...
Door locked light stays on so cannot open door
Make sure that all the water has drained or the door will not open, lay the hose into a bowl or other shallow vessel and let any remaining water run out. Wait a for a while for lock to release,if it still does not open then the door is going to have to be opened by force.
Plz rate this solution.
Thanks
Dec 16, 2008 | Hotpoint Aquarius WD63 Front Load...
Door won't open
Usual reason for this is not emptied correctly. The filter on this model is in an awkward place so try lowering drain hose into a bowl to check if water still in.
Nov 11, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius wd440g washer/dryer
Hi claire your problem is the pump braking down check to make sure there is nothing in the pump if you still cant get the door open pull the mains plug out and turn off the water valves red and blue take off the top of the machine and get a basin take the drain hose out and put it in the basin and bring the two down to the floor empty all the water out you should now be able to get the door open remember to check the pump and the bearings
Jul 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Aquarius Hotpoint WD440. 1400 Spin
The next step should be the pump out. If it is not pumping check your pump filter for obstructions. Check the drain hose and also your drain in the wall. If all are clear you may have a bad pump. You should have an error code coming up when the machine stops also, please let me know what it is. Thanks and I hope I can FixYa.
Mike
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius washer door wont open
I've got the same problem, the locked symbol is showing
Feb 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
1,095 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
