Question about Keurig B50 Coffee Maker
How do we stop the auto time ON/OFF feature and have the B70 on all the time?
    New Friend:
Go to the "On/Off Time", set the minutes to 00, then start pressing the hour button. An "Off" will be an option available after you get past 12:00.
Posted on Mar 12, 2013
2 Suggested Answers
BarrettDenCo
  • 1772 Answers
SOURCE: HOW TO DISABLE AUTO ON/OFF
Sorry to read about your problem, I hope this helps you out.
when you goto your menu, you will see auto off/time use the hour button, then select off
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 29, 2010
Auto Down window feature stopped working. Any ideas?
Try calibrating first,window up & hold switch for 3-4 seconds window down hold 3-4 seconds then back up & hold 3-4 seconds,check for the auto down to work if not then most likely the master switch is needed.
Oct 10, 2015 | Chrysler PT Cruiser Cars & Trucks
Every morning my Keurig is turned off
The Keurig B70 has an auto off feature that needs to be programmed. You can find the instructions here:
http://www.ehow.com/how_7389997_reset-keurig.html
Oct 17, 2014 | Keurig Platinum B70 Coffee Maker
I cant change the Auto Off feature
You should be able to press the Auto Off button and it cancels the automatic option. Hold it down and while keeping pressure on the button, pull the power cord from the Wall. keep holding the button and reinsert the Power Cord once again. Lift up and see if it did a Reset.
Jan 24, 2014 | Keurig Platinum B70 Coffee Maker
The temp set is at 0 so the water is not getting hot
Have you gone into the menu and changed the temperature setting? You can also change the auto off feature in the menu that is probably causing it to turn off.
Jan 16, 2014 | Keurig Platinum B70 Coffee Maker
How do I reprogram my platinum Keurig so it does not shut off
With unit powered on, Select Menu button, scroll down, and turn "auto off" to off selection. Cup size is selected after you put K Cup in. The display should flash on a default (1 of 5) cup sizes. You can manually change to the size you want. Alternatively, you can select the Menu button and change the default cup size (same process as stated above).
Nov 25, 2013 | Keurig Platinum B70 Coffee Maker
How do you set up the time,auto off ,etc.
Hold the auto button 6 seconds and relaease.
Oct 16, 2012 | Keurig B70 Coffee Maker
Keurig B70 coffee maker Not Ready and auto off set
Needs priming. See instrauctions for new unit setup.
Sep 29, 2012 | Keurig Platinum B70 Coffee Maker
HOW TO DISABLE AUTO ON/OFF FEATURE ON KEURIG B70
3 Thumbs - Helpful
Dec 29, 2010 | Keurig Platinum B70 Coffee Maker
It is a model #B70 and says NOT READY no matter what I do. I have changed the clock, set the auto on/off (which I would like to disable permanently) and I can't get it to brew!
Clean out the upper needle. It may have become clogged w/coffee grounds. Do you use tap water? If so, limescale may have prematurely ended the life of the machine. The air pump may be out of the unit as well. You can call Keurig and they will make you an offer to purchase another unit. Sell it for scrap on ebay or Crystal Pure. If you want to disable the auto on/off feature that is easy. Menu: time clock scroll to "Off" click and see if that doesn't help to "jump start" your B70! Best wishes, Melba
Nov 09, 2009 | Coffee Makers & Espresso Machines
Keurig B50 Coffee Maker Logo
358 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
