Question about Hitachi 60UX58K 61 in. Rear Projection Television
Hello, I have a Hitachi Rear Projection Model 60UX58K. The TV turned on and was working fine, for no apparent reason the TV shut off and will not turn back on. I unplugged the TV from the outlet in the wall, and waited several minutes and then plugged the TV back into the outlet; once plugged in there is a brief click noise and a red light on the front panel appears for roughly 2 seconds, but the TV will still not turn on from either the front panel or remote. Does this sound like a power supply issue? What would be the best solution...before requiring a repairman? Thank you Matthew
  • 308 Answers
SOURCE: Hitachi 50ux58b
It's possible that the Convergence IC's are causing a shutdown of the power supply. Also on this model, there have been problems with: C707 - 1000pf @ 2kv Cermaic Disc Cap (normally a small blue one) Hitachi Part # 0244211. I901 - A STRM6811a Reg Ic and E994 - 2.0 Amp Circuit Protector (Pico Fuse) having a high failure rate. If the 2 amp pico fuse was good, and the capacitor looked OK, then I would check the convergence circuit board. There are many other parts that can also cause shutdown problems, however.
Posted on Jan 03, 2007
  • 1153 Answers
SOURCE: No power to Hitachi 61UWX10BA Projection TV. Have tried steps found in other blogs.
These set are good for having convergence amps go out, and also audio problems. So if your set had experienced color alignment problems, or sound problems this may tell you what is going on. There are codes for Hitachi, and it's in the LED lights that lights up when you plug in and then hit power button. Some LED lights up and goes off some stay on this tells a tech what is wrong, I use to have code but gotten away from Hitachi, but if you could safely tell me which ones maybe I can help further. Like I said, this set has had many problems with convergence amps going out. There are small fuses on the big board that do not look like the ones in powersupply. They usually say F001 or somthing to that sort. They sometimes can be yellow in color, but the problem is replacing without fixing problem will have it going out again. So hope this helps. and Read the threads here on sets like yours becaus the answer might be here already.
Posted on Sep 21, 2007
  • 65 Answers
SOURCE: Hitachi projection TV does not power up
You probably have a blown 2kV capacitor and 2 amp fuse. Look for signs of black burning inside.
Posted on Aug 09, 2009
ladywinn
  • 5138 Answers
SOURCE: REPOST: Hitachi 60SX12B Rear Projection TV typical(?) problem
If you can solder you can Fix It STK ICs they are big black ICs will have part number on them example STK392-110 replace Both and these resistors RK42 3.3ohms RK46 1.8 RK5 2.7 RK54 1.5 RK58 3.9 RK60 2.2ohms upgrade to STK392-150s better ICs
Posted on Dec 03, 2009
Testimonial: "Quick and thorough response! Thanks!"
SOURCE: Have a Hitachi 53sdx89BA Rear Projection TV. Turn
Discharged Flyback Transformer. Removed main pc board from bottom of TV and flipped over, no apparent damaged components or blown board traces were found. Noticed a lot of flux in various areas on the board that seemed unusual (maybe TV was worked on before as I bought a showroom demo at Circuit City). Used a plastic screwdriver to remove all flux between connections on ICs, Transformers, Flyback Transformer, and various other components. Cleaned all debris, dust and crud accumulation (TV is over 10 years old and there was alot around the Flyback Transformer) from both sides of board using a lightweight paint brush.
Used a magnifying glass to check all solder joints for possible cold solders and found none. Did the same for Power Supply Board. Checked various ICs and Power Transistors for opens or shorts (in machine) and they seemed fine. Reinstalled boards, said a few Hail Mary's and fired it up.
The protector Led no longer flashed under power and lo and behold I got picture and sound!
I cleaned the lens on the projectors (again 10 years of dust accumulation) did a magic focus adjustment and it works fine!
After reading other fixes, I fully expected it to die after 10 minutes so I left it on all day and against all odds it still works.
What was the fix......Dirt buildup on and around Flyback and other components,,,,,,Flux conducting electricity between contacts on Flyback and other components.....or oxidation on connectors between Power Supply and Main Board.....I don't know.... all I know is that for the moment I saved around $ 300 - 400 in repair bills by doing it myself.
Posted on Feb 02, 2010
Where is the reset button on a 50u by 58b projection tv
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Jan 12, 2012 | Hitachi 50UX58B 50" Rear Projection...
Hitachi tv model 50ux58b starts to come then goes off
Hope this helps,
Nov 07, 2008 | Hitachi 50UX58B 50" Rear Projection...
Tv won't turn on.
Hope this helps,
Oct 07, 2008 | Hitachi 60SBX78B 60" Rear Projection...
TV quit no lights on front panel at all !
Hope this helps,
Sep 13, 2008 | Hitachi 60UX58B 60" Rear Projection...
TV popped and turned off and won't come back on
Hope this helps,
Jun 27, 2008 | Hitachi 60UX58B 60" Rear Projection...
Tv dead
hello. the loud pop you heard was .maybe a fuse.? u need to uplug .!!! the set !!!. and take off the back and see if fuse is bown.? ok let me know.!! ok
Jun 02, 2008 | Hitachi 50UX58B 50" Rear Projection...
Tv will not power on
Hope this helps,
May 01, 2008 | Hitachi 50SBX78B 50" Rear Projection...
60ux58b hitachi
Hope this helps,
Apr 29, 2008 | Hitachi 60UX58B 60" Rear Projection...
Won't power up
Hope this helps,
Sep 17, 2007 | Hitachi 60UX58K 61 in. Rear Projection...
Green lights
HELLO I WOULD REPLACE THE HOLE BOARD.!!! AND GO FROM THERE. HOPE THIS HELP'S YOU.!!! "GOOD LUCK"
Oct 29, 2006 | Hitachi 50UX58B 50" Rear Projection...
Televison & Video Logo
69 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
