Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan pro 42cc,18",PPB4218 is very hard to start and runs for a short time and then will not start when hot. It worked well first year, badly this season.Changed spark plug and cleaned fuel filter and exhaust mesh and adjusted idle up.
  • 252 Answers
Check basics 1st fuel , air, compression, spark , timming
then secondary compression ie crankcase air tightness
2 strokes need air tight c/case in order to draw in & pump mixture
check your tank breather is working,
has this saw been sitting a while ? if so might pay to rekit carb
check your carby diaphrams are pliable and inlet screen is not blocked and metering needle is set flush with chamber floor,
are hi / lo needles set base settings are 1-1/4 turns out from lightly seated , final hi setting is done while @ full rev and needs to 4 stroke slightly
check ignition spark under load ie while under compression load- could be a weak spark
check timming key
check for a air leak at cylinder / manifold block gasket or carb joint
check barrell bolts are tight everything been = engine should run
cheers
Posted on Aug 29, 2010
  • Roy Cagle
    Roy Cagle Jul 03, 2011
    Just finished fixing a 42cc Poulan. It had been sitting...a long while...dried out metering diaphragm.....stiff fuel pump diaphragm (crackly blue mylar)...little debris in carb filter screen.....air gap between coil legs and flywheel too close, scraping at times. Fuel lines weak from age and ethanol destruction. Fuel filter bad with dried up oil outside and inside. Fixed ALL these issues (gasket and diaphragm carb kit the kicker) and she runs better than new (so the owner says).
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 28 Answers
Rebuild the carb and tune it right
Posted on Apr 13, 2014
Won't start very well only runs when using won't idle always dies then hard to start again
no offence thats a made in china saw poulans are but it might just need carburator cleaned and new filters and plug wouldnt hurt to check the clutch springs either there bad to break
Aug 04, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a poulan pro 4218 it was running great when i put it away last year . went to start it this year put in fresh fuel i have a spark used starting fluid doesnt even try to start what gives?
If there is good fuel in the tank and there is a good spark, there is only two reasons why it will not fire up, the ignition timing is out ( sheared flywheel key ) or there is too little compression ( engine has seized at some time trapping the rings )
Oct 14, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Saw want start when its hot
Hi tjjohnson042
your problem is a faulty coil...replace the coil.
It is shorting out when hot, when cool it will crank and run great
Please rate me
Bud
Oct 03, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My poulan pro 42cc is hard to start ,,, its1 year old an i'm not sure if its worn out from alot of use or if its with the ignition
throw it out and buy a new one this is a throw away scoiety we live in due to cheap *** chinese **** oh yeah go green
May 27, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Pro 42CC 2 Cycle Chainsaw, 18": New gas, clean plugs..Ran fine last year, won't st...
Check for a plugged fuel filter and defective fuel lines. Make sure the carburetor fasteners are tight. Check for spark at the plug--it should be blue and snappy with a new plug. If ok, squirt in some fuel mix in the plug hole, replace the plug, and see if it will pop a couple of times. If ok, make sure the primer bulb draws fuel into it after several pumps. If still won't run, remove the lower chamber of the carburetor and check the diaphragm for flexibility and no holes. Hope this helps!
May 12, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a Poulan Pro PP4218AVX 18" 42cc. The saw seems to be running at about 1/2 speed, how do I fix or adjust this?
there should be 2 adj. screws going in to the carb marked L and H. Try turning the H jet in a little at a time and see if this helps. Or you can slowly turn it in all the way until you feel it stop. don't turn it any further in or you will damage the needle valve tip. Turn it out 1 1/2 turns and start the saw. It should run good at that setting. If not then adjust the screw in or out until it runs faster.
Aug 26, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
1,142 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
