Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Cannot fide the water filter on my refrigerator
    Champion:
  • 245 Answers
I believe the filter is either in the top right corner inside your refrigerator or at the very bottom. It looks like a big flathead plastic screw. Ussually located on the bottom lefthand side of the exterior.
Posted on Aug 29, 2010
I have a Kenmore side-by-side ultrafresh refrigerator model # 5255210, serial# SM0649567. I cannot find the water filter. Where is the water filter located on this refrigerator ?
Owning 1 of these refrigerators will require you to replace the water filter from time to time, in order to keep the water fresh and the refrigerator running efficiently. Kenmore refrigerators are made by Amana, Frigidaire, GE, LG, and Whirlpool, so it is important to find out which manufacturer made your Kenmore refrigerator, in order to make sure you order the right part. Kenmore refrigerators use filters that are located in the bottom, front panel of the refrigerator. Details can be found on WiKi how to change a water filter on a Kenmore Refrigerator.
May 24, 2016 | Kenmore Refrigerators
Why my refrigerator is leaking water from the top where the water filter is located?
Shut off water supply valve. Relieve water pressure by dispensing water. Unscrew water filter. Examine to see if the gasket is damaged or if filter was loose and just needed tightening. Or simply replace water filter with the correct water filter that your GE refrigerator calls for.
Jul 19, 2014 | GE Refrigerators
Filter light will not turn off
Resetting your Refrigerator filter indicator light after changing your water filter
Some people are not aware that after you change your refrigerator water filter, there are two more steps that should be taken to complete the water filter change process.
Step 1:
Reset your water filter indicator light - Most new refrigerators come equiped with an indicator light that notifies you when it is time to change your water filter. This light does not automatically reset when you change your water filter. Here is a list of refrigerator manufacturers and how to reset the indicator light.
GE General Electric Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
Step 2:
Flush a couple of gallons of water through your new filter. Since most refrigerator water filters are made of carbon, some carbon residue is present in the first gallon or two of water. This will leave a bitter taste and residue in your water. If you continue to have these problems after flushing a couple of gallons through the filter, it is possible that you have a defective water filter.
Nov 11, 2012 | GE PFSS9PKy Refrirator
My water has a lot of sediment in it and poor taste. I started installing a GXRTDR filter and have cut the line and inserted the line into the inflow end of the filter. I turned the water back on but no...
Not on the refrigerator, only where the water comes out of the wall to your refrigerator. First make sure the line is not clogged by removing the filter and making sure you have water flow through the hose. Then reattach the filter to the hose only and then make sure you have water through the hose and filter (may get a little messy). Then attach the filter to the refrigerator to see if you have flow. If you do not then your refrigerator water lines are clogged. Here is a video that shows how to fix problems like this:
Nov 21, 2017 | Kenmore 21.7 cu. ft. Top Mount...
Fiding the fuel filter
the filter should be under the vehicle in the area of the rear axle.
Mar 03, 2011 | 2003 Oldsmobile Alero
A refrigerator without a water filter the water dispenser will not will not work am i right with that question?
Hi, W/D here.
The dispenser will actually work without a filter. I can remove my filter, and put on the temporary seal cap, and I get water!
Older versions of refrigerators were connected to water supplies without filters. What happened was that the water might taste "funny", or be discolored, but mostly, unfiltered water tended to kill ice makers. Nowadays, most refrigerators come with expensive filters. Lots of crafty folks put an in-line filter before the refrigerator to make their expensive filter last longer. The water tastes better too!
Best regards, --W/D--
Please feel free to rate this solution so that we may continue to help others. Thanks.
Feb 20, 2011 | Refrigerators
Water won't flow, water line clear and has water running thru it....
Then you have to replace the water filter of the refrigerator. It is having some blockage that is why water is not flowing in it.
Filters situated in the interior liner of the refrigerator compartment of samsung-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Remove the old filter by grasping it and slowly making a one quarter turn to the left.
  2. Pull down gently on the filter to remove it from the mounting bracket assembly. Be careful to not tip the filter, as water may spill out of it.
  3. Discard used filter.
  4. Remove the new filter from its packaging. Apply the appropriate month sticker to the filter to remind yourself to change it again in six months' time.
  5. Fill the filter with water from the tap, and then line the arrow on the filter up with the arrow on the cartridge holder inside your refrigerator.
  6. The filter automatically pulls itself into position as you turn the filter to the right and lock it in place. Be careful to not over tighten the filter into position.
  7. Run water through your dispenser for about three minutes to clear the system. Keep in mind that a newly installed water filter could initially cause water to spurt from the dispenser.
Water by Culligan filter cartridges need to have a water filter adapter installed. This is a one time installment, and once you have this adapter installed, it stays in the refrigerator for all future filter replacements. If your refrigerator already has this adapter in place, do not remove it to replace the filter.
Smart Water filter cartridges do not require the use of the water filter adapter. If for some reason your refrigerator has an adapter in place already, you will have to remove it before installing a Smart Water filter cartridge. The adapter is removed in the same manner as the filter itself: with a gentle quarter turn to the left.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Hope this was helpful to you. Thank you for using fixya.
Jan 27, 2011 | Samsung 26.1 Cu. Ft. Side-by-Side...
My maytag wide by side keeps frosting up .
You might have a bad thermostat or defrost timer has gone bad.
Jun 28, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
The warning light to reset filter came on. I've
Resetting your Refrigerator filter indicator light after changing your water filter Some people are not aware that after you change your refrigerator water filter, there are two more steps that should be taken to complete the water filter change process.
Step 1:
Amana Refrigerators - Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire Refrigerators - Press and Hold the Reset Button Until the Indicator Light Flashes.
HotPoint Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Kitchen Aid Refrigerators - Press and Release the Light Button 5 times Quickly.
Maytag Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung Refrigerators - Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool Refrigerators - Press and Release the Light Button 5 times Quickly.
Step 2:
Once these two steps are completed, you are all set to enjoy great tasting ice and water through your refrigerator. If you don't see your manufacturer listed or the insructions don't work for your model please post a comment with your make and model number so that we can provide exact instructions for your model.
May 06, 2009 | GE PDS22LBN Bottom Freezer French Door...
Would like to install a water filter
Add a in-line filter to the incoming water line behind the refrigerator.
Most have 1/4 inch compression fittings to adapt.
Mar 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
