Hi sir greetings can you tell me stk output ic number as someone has removed it hoping you can help me thanking you andrew lebon
  • 4,234 Answers
There is a good possibility that we can assist with this, but we need the make and model of the unit in question. Please update this with that info and we'll provide the part number.
Thanks,
Dan
Posted on Aug 29, 2010
I need Original Sansui CR-M7 Cassette Receiver stk aideo ic
Just order the stk????? part number printed on the IC from a supplier. Try typing it into Google, there will be loads of suppliers offering the sale.
Hope that helps.
Feb 19, 2011 | Computers & Internet
The picture is bowed and you can see double and the color is wrong
convergence ic stk----- you can repair this yourself if you can solder you can obtain ic.s from matt electronics or any electronic suppliers locate the convergence ic.s on chasis there will be 2 the number will start with stk- most likely stk-392-110 hope this helps
Oct 10, 2010 | Hitachi 43F300 43" Rear Projection...
Model 50UX26B/27K MAGIC FOCUS NOT WORKING - BLUE SHAWDOWS
Hi:
This is due to a convergence IC failure, the blue convergence Ic is faulty, but when replacing convergence Ic's replace both of them as the other is not far behind to fail you in the future, the part number to use for replacing them is STK-392-110 , I suggest if you have someone replace them, that you have them use STK-392-120 instead as they work better and longer. If you take off the back of the television they are the largest IC's in the unit, they are mounted on large metal heat sinks..
Aug 23, 2010 | Hitachi Televison & Video
My samsung rear projection tv has a problem with its convergence ic. i think theres two ics , but how do i tell which ic need replacing??
Always replace both once your going to the trouble each IC is usually less than $30.
This link will help show you what's involved.
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 13, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
I am getting red ghosting, and can't adjust it. Can you tell me what might be wrong?
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400
Oct 03, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Hi!! my sony projection tv kp-51ws500 shows double picture. there is reddish outline & its out of focus. i need help to reapir this. please advise. thanks
This sounds like a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400
Sep 30, 2009 | Sony KP-51WS500 51" Rear Projection...
Panasonic pt-53wx53g vertical output ic
IC451 (Vertical Output) LA78045 part number is C1AA00000521
Available in Part Store.
Above info are taken from related service manual and an image of s.manual is given below...
Jun 19, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Samsung HLM507W 50 in. STK IC's
STK-392-180s these are the best.Replace BOTH
Feb 01, 2009 | Samsung HLM507W 50" Rear Projection HDTV
How to test 5v ic regulator(3 pins)
francis, 3 pin voltage regulators have the following;
1 pin is INPUT, let`s say 12 volts
1 pin is OUTPUT, let`s say 5 volts
1 pin is GROUND, all electronics equip. has to have a ground
the problem is they are not all wired internally the same so how do you tell which is input pin and which is output pin ? the best way to find this info is find the data sheet on-line. Google the letters NTE and click on their cross reference link and then enter the number on the front of your regulator and it will cross your device to NTE`s device and show you the info, hope this helps you, Happy Holidays BMW Rider
Dec 01, 2007 | Televison & Video
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
46 people viewed this question
 Grubhead
Grubhead
