Question about Car Audio & Video
Need Help Ground came loose on my Lightning Audio Amp LA1.150.2 and will not produce any more bass everything else works on this amp lights etc. just possibly need some help on the schematics end because I have no resources here in this small town I live in. Thanks, Fred
    Genius:
  • 1,224 Answers
If you know the difference between ground and the power wire just find an area where the ground can be hooked up in vehicle that goes direct to the bolt to the chassis
ground should be thick wire
try a reset on your amp if it has one pull the fuse and put back in this should help but make sure to get that ground fixed first before giving it power again
Posted on May 07, 2008
I have a JL 1000/1 and the low ohm light switch on and off.. The terminal connector is slightly loose.. with a jiggle of the ground wire the amp switch back to GREEN and plays normal..
Check the ground wire to the car make sure that you have bare metal and that the contact between the car and the wire is good. Ensure that the ground wire is in all the way. What size ground wire are you using. I would say don't use smaller than 4ga for a 1000 watt amps.
Also has the amp been screwed or velcroed to the box? Sometimes amp connections become loose from the vibrations of the bass. So it's possible it might be an internal issue or that the wire isn't in all the way.
I would suggest also taking the amp completely out of the car and inspecting the terminals to make sure they aren't loose or corroded.
Mar 06, 2011 | Jl Audio 1000/1 Car Audio Amplifier
I have a lightning audio amp a B4.320.4 and Protect Lght stays on
the amp probably got to hot and had a thermal shut down witch will have to be fixed by a professional.
Mar 06, 2010 | Lightning Audio Car Audio & Video
Legacy audio LA590 car audio amp protecet mode
Is that on all the time or are you saying the light is on? If that light is always on that just means it's protecting your amp. If it's off and not playing bass then your in trouble
Mar 01, 2010 | Legacy Audio American Legacy II LA590 Car...
Help!
Double check the ground wire to make sure it is grounded to an unpainted surface of the car. Otherwise turn cd player bass down and amp gain at no more than 3/4
Aug 24, 2009 | Lightning Audio Bolt B2.150.2 Car Audio...
My fuse blew out on my Pioneer amp
Could have been caused by a few things.
1) Low voltage. Most car charging systems aren't equipped to handle the extra strain of amplifiers without some sort of help, if this is the case you may need to add, a capacitor or battery.
2) Blown sub. Sometimes when you blow a subwoofer, it can take your amp down with it, most amp's will go in to protect before this happens, but not always.
3) Over driving the amp. If you max the gain, and bass boost on your amplifier, you can cause all sorts of problems, including blown fuses.
4) Loose or bad connections. Check your connections to the battery, and ground, sometimes a loose connection will play, but cause your amp to over heat by working to hard to produce it's power.
5) Bad amp. Could be a factory defect, like a poor soldier joint, or bad component.
Aug 09, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Amp Issues
1800W peak output at 2 ohms
975W peak output at 4 ohms
600W RMS (continuous) at 2 ohms
325W RMS (continuous) at 4 ohms
Variable LP crossover adjustable 35-250Hz
4 AWG power/ground inputs and RCA pass through
Low-pass filter
Bass boost 0-18dB adjustable remote punch bass EQ
Signal-to-noise ratio: >80dB
Line-level input
It is going into protect mode for a reason.
Disconnect the subs and turn everything on again. If the light comes on, the problem is internal and will need servicing by a technician.
Dec 22, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
Behringer Bass V-Amp
In my xvamp, a strucked microbutton caused E2. I've replaced the button, and everything went right :D
Nov 29, 2008 | Behringer F-CONTROL AUDIO FCA202 External...
Sony amp 1000w
Check the wiring of the speakers (both inside the box and between the box and the amp). It sounds like one speaker is wired incorrectly at one connection point.
Sep 09, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
LIGHTS ON BUT NO BASS
Is the master/slave switch set to master? Have you tried feeding the signal into a different amp to make sure that there is signal reaching the amp?
Sep 18, 2007 | Car Audio & Video
Amp cuts off
So you have an EQ and a Pioneer amp you're trying to hook up to each other? And only some Stinger RCA cable works? And when the lightning audio RCA cable is hooked up, it doesn't turn on? The amp isn't grounding itself through the RCA cables, is it? Check your ground wire and make sure it has a clean contact that's free of rust or any paint that might be in the way. Otherwise, the RCA cables should have nothing to do with an amp turning on or not.
May 07, 2006 | Pioneer GM-X324 Car Audio Amplifier
Car Audio & Video Logo
79 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
