Question about Kenmore 57029 Side by Side Refrigerator
It,s not keeping cold dos it need gas or a compressor
    Champion:
  • 274 Answers
Is the compressor running it may be defrosting.Is the freezer cold? is food blocking the vents in the freezer?
Posted on Aug 29, 2010
AC compressor not kicking on
Locate the AC compressor Relay. A relay is used because the coil in the compressor clutch that must be activated to allow the compressor to turn pulls a large amount of current. The controls themselves inside the passenger compartment (switches) are not capable of transferring lots of current, only a little. The controls turn of the tiny AC Relay\'s coil that pulls very little current, and the contacts (switch) inside the relay CAN transfer the larger current to the compressor clutch coil. Nearly all cars and trucks work this way. The relays are not expensive and most are available at any any auto parts store. They go bad and either stop clicking on or the contacts wear out and although they still click they aren\'t making any connections anymore. I would replace it. If that doesn\'t take care of it look for a fuse in the fuse compartment. You can always keep a relay in the glove compartment as a spare.
Aug 24, 2014 | 2003 Toyota Sequoia - With roof spoiler -...
Mitsubishi ac keeps on turning itself off
If the compressor overheats, the clixon circuit will shut off the power to the motor to prevent damage. Then when it cools it will close the circuit and the compressor will again run to only shut down again.
The suction line going to the compressor should be cold - the cold gas returning to unit cools the hermetically sealed motor. If that line is hot you may be low on refrigerant.
Feb 19, 2014 | Heating & Cooling
Hey there. I am having problems with my Emglo Dewalt d55151 compressor. I have taken it apart and and cleaned everything up. The reason I did all this was..because the cold start valve stays open and its...
The cold start valve will close when volume of air from compressor is sufficient to overcome spring under pin (allows the motor to come up to speed). Evidently your compressor is producing very little air. Usually the problem is leaking or broken reed valves or gaskets. Remove the head and look for torn/ leaking gaskets and replace as needed. Examing the reed valves and seats and look for broken cracked reeds or worn seats. Some of the valve plates used in Dewalt compressors are made of aluminum and would fail. Parts are available at www.toolpartsdirect.com or local dewalt service center. Good luck with your repair.
Apr 25, 2011 | Dewalt d55151 factory reconditioned emglo...
Manually set and programmed temperatures but when turned to heat only cold air...is it the compressor?
maybe or its had a gas leak so get a refrigeration mechanic there i am one but found out how much trouble refrigeration is i would go gas or wood for heating it was designed for heating where air con's are fridges with a reversing valve in them they were made to keep things cold, so if it is the compressor i would get rid of it and change to a wood or gas heater, as i said i am a refrigeration mechanic by trade but only move heat pumps to other locations to put in gas or wood or just remove the air con all together, and our clients arte always much happier with the change there also cheaper to buy and maintain than air con so i would seriously look towards getting rid of it, if it is a ducted system they can be changed for gas very easily you also want to look at other options if you went this way but seriously refrigeration is for keeping things cold to try and heat with it on adds extra value to thier sales and thats the hard truth about a hetaing device that in most cases on a very cold day is useless!!!!!
Dec 16, 2010 | Honeywell Heating & Cooling
I have a 2002 Acura RSX that has AC Problem. Blows very cold air, but not all the time. As long as RPM is running at drive speeds, I have cold air. However, at stop lights the air temp goes warm. If I...
your ac compressor is freezing up try not putting it on cold all the way. put thermostat towards the red jus a lil but still on the cold side to see if that helps
Apr 03, 2010 | 2002 Acura RSX
My bottom freezer has stopped producing cold air, fan still works, any thoughts ideas, Daniel
if the compressor keeps switching on and off in short bursts, its your gas thats finished. it may need a regas. gas being finished may be from either standing a long time, it being an old freezer, or a gas leak. you'll need a repairman to regas it and also for checking for leaks.
Oct 29, 2009 | Sub-Zero 611 / O Bottom Freezer...
My 40 l does not wan to keep stuff cold teh motor kicks in only mometarily, can it be in need of a gas refill and does it ide normal aircon gas? It can get cold by itself but if you stick it with drinks...
If The motor is switching on for short periods, you either have a faulty compressor or a blockage. My money is on a blockage. Once cover is removed to allow you to see the compressor, look for a small fat copper tube that has a small 1/4 inch copper pipe on one side and a thin capillary tube connected on the other side DRIER). Flex this very thin pipe connected to the small fat tube(DRIER) untill it breaks.Gas will come out. Wait untill all gas is out then reswitch on and see if compressor still continues to switch off on short intervals. If it can run for at least 1 min without switching off, then get a Refr.Tech to come and replace drier and regas unit.
Sep 23, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge does not stay cold
If the compressor is running continually, could be short of gas , or a compressor problem, ie not pumping properly,make sure it has plenty of ventilation
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Fan running but not keeping cold
check to see if the compressor is running, if not you may need a start kit, (relay,overload) If the compressor is running take the back freezer panel off and check to see if there is a frost pattern, might be out of gas if frost pattern has receeded
Nov 08, 2008 | Whirlpool ET1FHTXM Top Freezer...
Kenmore 57029 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
