Question about Whirlpool Washing Machines
WHIRLPOOL CABRIO WTW6200VW0 LEAKING WATER NEAR THE FRONT OF THE PANEL
SOURCE: Whirlpool Cabrio Leaks Water
Good luck. Mine did the same and they sent their technicians out to fix the problem. A&E comes out and replaces the tub ring. They told me the washer is now made with the tub ring in place. When he opened the washer up I noticed I now have rust inside my washer. I have spent a month trying to get Whirlpool to replace my washer but they will only replace parts. A&E came out to replace the tub ring and now my door creaks and my washer does not go back together correctly. Hopefully you can justreturn the washer to where you got it. Read other reviews on line. It sounds like this washer is a lemon. Sorry!
Posted on Sep 03, 2008
rylee_smith
  • 8619 Answers
SOURCE: Whirlpool Cabrio washer is leaking water
Hi
Error code LF means Long Fill. If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed. Press STOP/CANCEL to clear the display.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 23, 2009
jsrock516
  • 5911 Answers
SOURCE: whirlpool duet washer leaking water
If the washer is leaking around the door area, more than likely the bellow (rubber seal) is ripped or torn. If you pull back the rubber folds in the bellow and inspect, you may find a rip or tear causing your leak.
Another cause can be the rear bellow clamp (clamp that is affixed to the front of the wash tub) can come loose causing a leak between the bellow and tub. All you may have to do is tighten the clamp if this is the case.
The dispenser tube on the left hand side of the door, if not seated through the rubber correctly, can also leak during the fill or rinse cycles. The tube should be inserted through the rubber in the bellow to the flange on the tube. If not, water can fill behind the rubber and drip into the bottom washer casing.
The following link explains how to access and/or replace the the door bellow on a Whirpool Duet:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
Searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com and repairclinic.com carry the bellow. All these sites offer competitive pricing, so shop all of them for the best deal.
If you have any questions, or require addtional assistance, please let me know. I hope this helps you. NOTE: The bellow can also become mishapened over time after frequent use. This can also cause leaks around the door. Look to make sure the bellow is sealing around the door glass. If not, it should also be repalced.
Posted on Jul 30, 2009
jsrock516
  • 5911 Answers
SOURCE: My Whirlpool Ultimate Care II has water leaking
Your drain pump is leaking. They are not serviceable and cannot be repaired. The following link explains how to replace the pump:
http://www.fixya.com/support/r397092-replacing_water_pump
If you need an illustration of your washer and components, searspartsdirect.com, appliancepartspros.com, or pcappliancerepair.com usually have some excellent exploded view diagrams that you can refer to.
Prices can vary between these sites so shop around for the best deal. NOTE: Use the part number from the Sears site and use it to "Search by Part Number" on the other sites. It makes it easier to find as some sites may not have your model number listed, but will still carry the part.
Read through everything thoroughly before beginning any repairs. If you have any questions, or require additional assistance, please let me know. I hope this information is helpful.
NOTE: You can also order a repair manual for about $20 (part number 1170635) at repairclinic.com if you need more instruction.
Posted on Nov 17, 2009
vostendorp
  • 347 Answers
SOURCE: Water is leaking onto the floor underneath my
If its a small intermittent leak from the front left corner its the tub ring, whirlpool has redesigned the tub ring to fix this concern..
Posted on Sep 19, 2010
My cabrio washer is leaking badly
Call the whirlpool factory and tell them you are calling about a recall, they replaced my motherboard for free to keep me as a satisfied customer. Doesn't hurt to give it a try.
Jul 29, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer is keaking water on the front left side. I think when its draining. i had the new style top put on that stops water from spilling on to the floor when filling
check that your drain hose is tight pull machine away from wall and see if it leaks there during drain cycle if it is leaking here tighten connection/Also check that it is tight at the faucets as well
Jan 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio drains water onto floor.
I took the back cover off of the machine and found that the drain pump had a hole in it. The hole was caused by a coin that had made it's way down to the drain pump. The replacement pump cost $90.00 and was very easy to put in. If you google the words cabrio tear down you will come across a web site that has a video that shows you how to take the pump out. I have not had any leaks since. Keep the coins out of the washer, remeber to check your pockets to avoid paying out cash.
Jun 09, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Water leaking out front of maytag washer
Remove the top cover of the machine. Check to see if the three tubes going into the dispenser drawer hv not come loose. Tighten well.
Sep 11, 2007 | Whirlpool WTW6400SW Cabrio Washer
Washing Machines Logo
158 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
